I'm getting the wrong inner product of Fock space
The discussion centers on discrepancies in calculating the inner product of two-particle states in Fock space as presented in Tom Banks' modern Quantum Field Theory (QFT). The user correctly identifies that the expected factor of 1/2 in the two-particle state inner product is absent in their calculations, leading to confusion. The consensus is that Banks' formulation is flawed, as corroborated by S. Weinberg's work, which does not include the factorial in the expression for fermions. The correct approach involves recognizing that factorials are only necessary for bosons when multiple particles occupy the same state.
  • Understanding of Quantum Field Theory (QFT) principles
  • Familiarity with Fock space and its inner product structure
  • Knowledge of creation and annihilation operators in QFT
  • Comprehension of delta functions and their role in particle states
  • Study S. Weinberg's "The Quantum Theory of Fields I" for accurate formulations of QFT equations
  • Review "Quantum Theory of Many-Particle Systems" by Fetter and Walecka for operator formalism
  • Explore the implications of factorials in bosonic and fermionic state calculations
  • Investigate the role of delta functions in normalization of quantum states
Physicists, graduate students in theoretical physics, and researchers focusing on Quantum Field Theory and particle physics who seek clarity on Fock space inner products and operator formalism.
hideelo
I am trying to follow modern QFT by Tom Banks and I am having an issue with literally the first equation.
He claims that beginning from ## |p_1 , p_2, ... , p_k> \: = \: a^\dagger (p_1) a^\dagger (p_2) \cdots a^\dagger (p_k)|0> ## with the commutation relation ##[a (p),a^\dagger (q)]_\pm \: = \: \delta^3(p-q)##, (+for fermions, - for bosons) I can reproduce the following equation
$$<p_1 , p_2, ... , p_k|q_1 , q_2, ... , q_l> \: = \: \frac{\delta_{kl}}{k!}\sum_\sigma (-1)^{S\sigma}\delta^3(p_1-q_{\sigma(1)}) \cdots \delta^3(p_k-q_{\sigma(k)})$$Where S = 1 for fermions and 0 for bosons. I can show that for the 1 particle state I get ##<p|q> \: = \: \delta^3(p-q)##, but as soon as I get to the two particle state my result differs from his.His formula tells me that for the two particle state I should get:
$$<sr|pq> \: = \: \frac{1}{2} \left( \delta^3(p-s)\delta^3(r-q) \mp \delta^3(r-p) \delta^3(q-s) \right)$$
But I am getting
$$<sr|pq> \: = \: \delta^3(p-s)\delta^3(r-q) \mp \delta^3(r-p) \delta^3(q-s) $$
missing the factor of ##\frac{1}{2}##
$$<sr|pq> \: = \:<r|a(s)a^\dagger(p)|q>\: = \:<r|[a(s),a^\dagger(p)]_\pm |q> \mp <r|a^\dagger(p)a(s)|q> \:= $$
$$ \delta^3(p-s)<r|q> \mp <r|a^\dagger(p)a(s)|q> \: = \: \delta^3(p-s)\delta^3(r-q) \mp <r|a^\dagger(p)a(s)a^\dagger(q)|0> \: = $$
$$ \delta^3(p-s)\delta^3(r-q) \mp <r|a^\dagger(p)[a(s),a^\dagger(q)]_\pm |0> \pm <r|a^\dagger(p)a^\dagger(q)a(s) |0> \: = $$
$$ \delta^3(p-s)\delta^3(r-q) \mp <r|a^\dagger(p)|0> \delta^3(q-s) \: = \: \delta^3(p-s)\delta^3(r-q) \mp <r|p> \delta^3(q-s) \: = $$
$$ \delta^3(p-s)\delta^3(r-q) \mp \delta^3(r-p) \delta^3(q-s)$$
Whats going wrong?
Are you happy where the k! comes from? ( As that seems to be the difference)
No, it's the k! that's bothering me
Isnt it there to avoid double counting?
That's what I thought, but when I worked it out I found no double counting
Maybe I’m not understanding your notation, but which operator in your first line annihilates the q state?
The convention I am using (and I think its standard) is that ##a^\dagger(q)## creates a state with momentum q and annihilates a costate with momentum q i.e.
$$a^\dagger(q)|0> = |q>$$
and
$$<q|a^\dagger(q) = <0|$$
Similarly ##a(q)## annihilates a state with momentum q and creates a costate with momentum q i.e.
$$a(q)|q> = |0>$$
and
$$<0|a(q) = <q|$$
Great thanks for confirming that. So wouldn’t you need four operators for 2 particles? Two to annihilate the two original states and two to create the new ones?
In general yes, but what I'm doing is in only "pulling out" one creation operator. So while it's true that ## |pq> =a^\dagger(p) a^\dagger(q)|0>## I can then let the ##a^\dagger(q)|0> =|q>## which gives me what I have up there ## |pq> a^\dagger(p) |q>##
I think that was OK to do...
Quantum Field Theory for the Gifted Amateur by Lancaster and Blundell doesn’t have the 1/2, which is interesting! In that text the factors only appear when calculating the wave-function. So something is wrong with one of them...
For fermions there shouldn't be any factorials since each single-particle state can only be occupied with at most one particle. For bosons you have factorials for normalizing the states which occur only when a single-particle state is occupied by more than one particle. In the infinite-volume limit this leads to trouble. So you should keep all the momenta (labeled with ##p## and ##q## in your formula) general. The proper expression comes out right due to the ##\delta## distributions. So in the standard meaning of the creation and annihilation operators there should be indeed no ##k!## in the formula in the OP. So you are right with your calculation.
For a very nice and careful treatment of the operator formalism, see
Fetter, Walecka, Quantum theory of many-particle systems
For this calculational technique it doesn't play a role whether you consider relativistic or non-relativistic QFT (Fetter&Walecka is non-relativistic).
  • · Replies 0 ·
