Imaginary fraction questions. lost.
The discussion revolves around complex numbers and their manipulation in the context of circuit analysis, particularly focusing on simplifying expressions involving imaginary fractions. Participants are examining specific examples from a midterm study handout.
  • Participants are attempting to simplify complex fractions and question the steps involved in the process. There is confusion regarding the notation used for imaginary numbers and the application of distributive properties. Some participants suggest clarifying the mathematical expressions for better understanding.
There is an ongoing exploration of the problems presented, with some participants providing insights on notation and simplification techniques. However, there is no explicit consensus on the correct approach or final answers, as participants are still working through the reasoning and calculations.
Participants note the importance of consistent notation when dealing with imaginary numbers, as mixing symbols can lead to confusion. There is also mention of the need to rationalize denominators in certain expressions, indicating a potential gap in understanding the underlying principles.
ahhgidaa
im studying for my circuits midterm and the proff has handouts with questions and answers but not detailed answers. i can't figure out how he went from a fraction to an answer.
(-j2)(2+j2)/-j2+2+j2 the answer on the paper is 2-j2
i do not know what I am allowed to do with the 2 next to the j with the distributive properties.
another example i was stuck on was i= -j2/1+j the answer here was rad2 at an angle of -135
and the above equation came from -j2+(2-j4) I_2 + (I_1 + I_2)j6=0 with I_1 =1
and insight or help would be appreciated. thakns
First off, you need to learn how to write mathematical expressions so that they mean what you intend. I am willing to bet that on the handout it looks like this:
[tex]\frac{-2j(2 + 2j)}{-2j + 2 + 2j}[/tex]
If you write fractions like this without using LaTeX to format them, put parentheses around the entire numerator and the entire denominator.
If you write 2j, people will be likely to mistake this for j2, which is something different.
For this problem, the first thing to do is to simplify the denominator.
I'm guessing you mean i = -2j/(1 + j).
Look for an example where they rationalize the denominator by multiplying by the conjugate over itself.
i ended up with -2j-j^2 which i^2 is -1 so i finally got the answer 2-2j and i copied it exactly how it was but ure way of putting it help me with the math. idk why he writes it like that
1) Don't mix "j" and "i".
2) -2j- i^2= 1- 2j, not 2- 2j.
3) I think Mark44 meant to say that some would confuse "j2" with "j^2", not "2j".
The OP is in an electronics class - they write j for the imaginary unit, probably because i is used for electrical current. Still, the advice is good. Use one or the other consistently, but don't use both.
Mark44 said:
Right, that's exactly what I meant.
  • · Replies 16 ·
  • · Replies 21 ·
