Implicit differentiation, find y''
4 replies · 2K views
apiwowar
the problem is to find y'' or d2y / d2x
the equation is y2 = x2
first i found the first derivative dy/dx = 2x / 2y = x / y
then i found the second using the quotient rule and got
y'' = (y - x(dy/dx)) / y2
i plugged in y' into y'' and got
y'' = (y - (x2/y)) / y2
but then I am stuck after that because when i simplify i get
y'' = (y2 - x2) / y3
i don't know how i can plug the original equation back in.
did i go wrong somewhere?
This looks fine.
This looks fine, too.
This above is correct, but can be simplified. If y2 = x2, then y2 - x2 = ?
Take care, you have to exclude x=y=0.
The original equation is y2=x2. What do you get when you plug that in?
ehild
does x2-y2 = 0 or 1?
and the book shows that the answer is 3y/4x2 = 3x / 4y, hows that possible? shouldn't the answer be y'' = ...?
If two numbers are equal, then subtracting one from the other leaves zero.
Yes, they're asking you for y'', so the answer should start with y'' = ...
I don't see how they got 3y/4x2 = 3x / 4y.
Going back to the original problem, you have y2 = x2, which is equivalent to two equations: y = x or y = -x. For the first, y' = 1, and for the second, y' = -1. What do these tell you about y''?
