In which point between Earth and Moon is gravity field zero
25 replies · 8K views
adok
I already searched for solution and i found similar one but I'm still confused.
-In which point between Earth and Moon gravity field equals 0 if distance between moon and Earth is 60.3 * radius Earth and mass of the Earth is 81 * mass of the moon.
ɣ*M/(d-x)2 =ɣ*m/x2
[/B]
O----------------------o
M...(d-x)...|...x...m
consider this a sketch, (d-x) is distance between Earth and that point, x is distance between moon and that point. M is mass of the earth, m is mass of the moon.M/(d-x)2=m/x2
81/(d-x)2=1/x2
81x2=(d-x)2 /root
9x=d-x
10x=d
10x=60.3Re (Radius of the earth)
x=6.03Re
not sure if i made mistake or my book author where he says it has 2 solutions and isn't near as simple as my answer.
Your answer is correct if you take Earth and Moon as static objects in space. If you account for their rotation around each other, then it gets more complicated and you get 5 solutions of co-rotation (they are called Lagrange points).
adok said:
81x2=(d-x)2 /root
9x=d-x
The second equation is not correct. It should be ## \pm 9x = d - x ##, and that gives you two solutions. You need to be able to choose the correct solution, and explain why it is the correct one.
Thank you both, this is solution from my book and it doesn't match with mine at all.
http://pokit.org/get/img/2a25e10dddd37ab72b3d28fde419fecb.jpg
Don't confuse 'net field zero' with Lagrange points. Motion of the bodies does not affect the instantaneous field.
The long equation in the middle of the page is wrong. The multiplying out has been done incorrectly. Your answer is right.
Did you see the "co-rotation" in my post? The motion does not influence the field in a significant way[/size], but stationary points in the rotating reference frame need a net force.
I did not what the book calculated to get a difference, so I made a guess.
Non-inertial frame if you don't want motion, inertial frame if you prefer circular motion (but then it is also important that Earth and moon move). Same thing, different ways to express it.
this problem is in part before we learned about inertial and non-inertial systems(frames?) and it isn't mentioned in problem so my solution is correct? it can't be -6.03Re, it doesn't make sense
The negative value simply means it is on the other side of the Moon. That alone could be sensible. You need some other consideration to rule it out.
If you look through your working, you can see that the equation you started with only says that the two forces have the same magnitude. That's why you get two solutions (but the other solution is not -6.03).
The given data look screwy, which to be sure is not a prime concern for the problem as given, but it is well known that the center of mass of the earth-moon system lies INSIDE the earth.
EDIT: OK there are two points where net gravity = 0, and the OP has the right other point. Since the problem stated "between the Earth and the moon" I guess the point inside the Earth doesn't count.
Still, the c.g. of the earth-moon system is inside the earth, i.e. the two bodies rotate about that point in (essentially) circles.
So what? We don't look for this point here. This point is not a point of zero net gravity.
There is one point inside earth, true, but at that point you get crushed and boiled so much you probably don't care about gravity.
rude man said:
It's not? I beg to differ ...
D = earth-moon distance, M = Earth mass, m = moon mass, R = Earth radius.
There is a point of zero net gravity at distance x < R from Earth's centre where ##\frac{M x}{R^3} = \frac{m}{(D-x)^2}##.
If y is the distance of the CoM from Earth's centre then ##My = m(D-y)##.
If we treat Earth as a point mass then there is only one solution for zero net gravity, the one in the OP.
Have I misunderstood?
Your formula assumes uniform density within the Earth which of course is not the case.
However, thank you for seconding my contention that such a zero-net-gravity point exists somewhere inside the earth.
A third source of support would be Dr. Feynman's Lectures in Physics where he explains why there are two tides per day, which I must admit I never did quite figure out, but is based on the c.g. of the earth-moon system as located inside the earth.
It is not.
The barycenter of the earth/moon system is roughly at 2/3 the radius of Earth (as distance from the center of earth). Even with a uniform mass distribution, you would feel 2/3 g towards the center of earth, with a negligible contribution from the moon (because it is both much more distant and much less massive). With the non-uniform distribution, you actually feel something close to 1g - but certainly not zero g.
This becomes more obvious if we imagine the moon at a distance of 81 times the radius of Earth - the barycenter would be at the surface of earth, but we certainly would not float away.
The barycenter takes the linear distance as weight, whereas gravitational force takes inverse squared distance as weight.
The actual point of zero net gravity is very close to the center of earth, less than 1km away (assuming a spherically symmetric mass distribution, which is probably wrong at that level of precision).
No, those two things are completely unrelated.
mfb said:
It is not.
See haruspex's last entry which gives the accurate zero-g point assuming uniform Earth density.
I think the argument is because your post #13 gave the impression you were saying that the common mass centre was a point of zero g. I also was not sure why you mentioned the position of the common mass centre.
Sure, and it is not at the center of mass.
haruspex said:
I think the argument is because your post #13 gave the impression you were saying that the common mass centre was a M point of zero g. I also was not sure why you mentioned the position of the common mass centre.
I acmit toconfusion onthis point.nthispoint.
Agreed. I confused those two points. Apologies to all.
Can I just confirm as a simple minded Physical Science teacher that the answer will be 3.845 EXP 7 metres between null point and moon or 3.46 EXP 8 metres between null point and earth?
Hi allan19740813,
Welcome to Physics Forums.
Regardless of credentials, the rules here preclude simply providing answers or confirmation of what may be guesswork. Sorry about that. If you could show how you arrived at your results then we could comment on the work.
The solution that I have calculated and attached as a picture below is intended to act as a brainteaser for Grade 11 learners, so I have tried to simplify as much as possible. Please bear this in mind when commenting but most importantly I need to know if its correct
