Induction proof that n! > 2^n for all n > 3
  • Thread starter Battlemage!
    Proof
13 replies · 3K views · last reply
Battlemage!
Show that n!>2n for all n>3.
I will attempt to use induction.
We want to show that n!>2n for all n>3.
Consider the case when n=4.
[tex]4! = 24 > 2^4 =16.[/tex]
We want to show by way of induction that if the inequality is true for some k greater than 4, it is true for k+1.
Assume the inequality holds for k>4. Then,
[tex]2^k < k![/tex]
[tex]2*2^k < 2k![/tex]
[tex]2^{k+1} < 2k![/tex]
for k>4.
But 2k! < (k+1)! for all k>4. Therefore
[tex]2^{k+1} < (k+1)![/tex]
and so by induction it follows that n! > 2n for all n > 3.
Proof is ok, but I'm going to be annoying:
[tex]2^k < k![/tex]
Why?
for k>4.
Why?
Why?
Thank you. That always helps.
micromass said:
Why?
The reason I assumed it held for k>4: 4 is the very first integer greater than 3. I figured if I can establish by induction that it holds for 4, then 5, 6, 7,...k, k+1,... then it must hold for all numbers greater than 3. There is no upper bound on k. I did spin my wheels a bit at first since I'm used to the base case being k=1.
As for the second part, I multiplied by 2 because that would allow me to easily get the k+1 case because the base for the power is 2, and xax = xa+1. (also I don't believe the way everything relates to the number 2 here is coincidental. I think there might be a deeper relation between the base of the power and when it is larger than the factorial).
micromass said:
Why?
Because I multiplied both sides by a positive integer, so the inequality should remain. The multiplication was done so I can get the k+1 case for the exponent. I then kind of lucked into the next part. I knew I had to get to some point where the left was less than the target quantity, and this worked out well.
micromass said:
Why?
Because:
[tex]\lim_{n\rightarrow ∞ } \frac{2n!}{(n+1)!} = 0[/tex]
*EDIT I had n approaching zero for some reason
and as for k =3,2,1 and 0, I manually tested them. k>4 is overkill for this part. But I figured that in order remain consistent I'd stick with k >4, since it is necessary for comparing the exponential to the factorial.
[tex]2^k < k![/tex]
for k>4.
There is, however, a small but significant error in your original proof. This is not related to insufficient justification, but is a genuine flaw.
Big hint: what happened to the case ##n = 5##? Where did you cover that?
Math_QED said:
This is wrong.
I wrote it wrong. It's supposed to be as n approaches infinity.
That means that for all ##\varepsilon>0##, there is an ##N## such that if ##n>N## we have ##2n! <\varepsilon (n+1)!##.
Your claim is that for all ##n>3## we have ##2n!<(n+1)!##. Those are very distinct statements.
Oh I see what you're saying.
For that part when I answered your why question by posting the limit I just meant that because I knew that limit was zero it led me to the idea of trying to set up an inequality where
2k+1 < 2k! < (k+1)! for k>4.
I did not actually give a mathematical reason haha. I will think on it and try to articulate a better one.
[tex]2^k < k![/tex]
If you mean ##2 \times 2^k < (2k)! ## then that does not follow from the previous line. If you mean ##2 \times 2^k < 2 \times k!## then that does follow.
@Battlemage!
PeroK's question has been ignored. It raises an important point!
Yes that's what I meant. I figured a factorial was only grouped with other terms if there were parentheses, but then again it's not like a factorial is in PEMDAS so I would be ignorant of such rules.
SammyS said:
@Battlemage!
I post these questions at work and unfortunately ran out of time. I was thinking about it, though. Sadly I'm at a loss. More information below...
Okay... let me see...
I have manually tested 5 and it works. 5! = 120 >25 = 32.
Likewise with my last step, 25 = 32 < 2(5!) = 240 < (5+1)! = 6! = 720.
As for the induction process, I've never done it where the base case wasn't one. Did I do it wrong with my base case of 4?Since I included k greater than 4, doesn't that already include 5. I don't quite understand what you're getting at. Any other hints? :/
EDIT- since we're here, I did find a different way to do it working the other way.
[tex](k +1)! = (k + 1)k! > (k + 1)2^k[/tex]
and since k > 4 then
[tex](k + 1)! > 2^k * 2[/tex]
[tex](k + 1)! > 2^{k+1}[/tex]
What you did was:
a) Showed it was true for ##n = 4##
b) Showed that if it was true for ##k > 4## it was true for ##k+1##
But, ##k > 4## starts at ##k =5##. So, you didn't cover the step ##P(k = 4) \ \Rightarrow \ \ P(k = 5)##.
The inductive stage of your proof should have been for ##k \ge 4##.
On the other issues, I think you have let the questions confuse you and over-elaborated your answers. Your proof depended only on (if ##a, b## are positive):
##a < b \ \Rightarrow \ 2a < 2b##
And
##k > 2 \ \Rightarrow \ 2a < ka##
You must see this, but recognising these simple facts and stating them simply and mathematically is something that generally does not seem to come naturally to many people.
On a final point, I would tend to write either ##2(k!)## or ##(2k)!## to avoid any ambiguity. Like you, I don't know what PEMDAS has to say about factorials.
PeroK said:
What you did was:
So essentially if I replace the > with a ≥ that would fix the issue?
And
So I could have omitted this part?
Yeah I think I'll do that from now on.
I appreciate the help by the way.
Yes, but you should see that yourself.
There was nothing you could have omitted. You just needed to justify what you were doing a little more.
