Installing an EOT crane in a factory (ceiling clearance issues)
The discussion centers on the installation of an EOT (Electric Overhead Traveling) crane in a factory with significant ceiling clearance constraints. The crane has a capacity of 10 tons and a span of 27.6 meters, but the available space is limited to 10.5 meters, with a 9-meter steel post obstructing the installation. The gap between the topmost tip of the crane and the factory ceiling is less than 50 mm, raising safety concerns and compliance with local laws. Engaging a consulting engineer is strongly recommended to address the complexities and safety implications of this installation.
  • Understanding of EOT crane specifications and configurations
  • Knowledge of local building codes and safety regulations
  • Familiarity with structural engineering principles
  • Experience in factory layout planning and optimization
  • Research local building codes relevant to EOT crane installations
  • Consult with a structural engineer for safety assessments
  • Explore options for modifying factory layout to accommodate the crane
  • Investigate manufacturers like Ganesh Engineering Co for expert advice
This discussion is beneficial for factory managers, engineers involved in material handling, and safety compliance officers who are considering the installation of EOT cranes in constrained environments.
GANESH SHETTI
PROS AND CONS OF INSTALLING AN EOT CRANES IN A LIMITED SPACE FACTORY.
Capacity of the crane is 10 TON, SPAN is 27.6 meter, 4x10 Ton Cranes for 125 meter bay.
The space limit in the factory is 10.5 meters.
There is a 9 meter steel post at the center of the factory (part of a machine).
The crane and its hook should be above 9 meter. So that there is no obstruction whatsoever.
Now we can fit the crane in the factory. But the Space between the top most tip of the crane and lowest tip of the crane is less than 50 mm. Please advice
I can think of more than 100 questions to ask about your factory. There may also be local laws and codes you must comply with.
You need a consulting engineer, not strangers on the internet.
There may be safety implications in any any direct answer to your question.
GANESH SHETTI said:
Please advice
Do you know about this website; http://www.eot-crane.com/
Ganesh Engineering Co, is a Manufacturer, supplier and exporter of EOT Crane, Double Girder EOT Crane, Single Girder EOT Crane etc.
Maybe they can answer your questions.
Thank you for replying, It doesn't matter if i don't get the exact solution. The reason I post here is to get some random thoughts related to engineering problems from strangers who are good at physics. Its an open ended problem for you guys, any answer or reply is welcome.
Your dimensional specifications are impossible to follow. You know what you mean, I cannot guess what that means without a sketch diagram. If you do not clearly specify the problem then you will not get sensible answers.
You would do better to call a company that knows how to do it.
What company do you work for and what is your current position?
Oops! My bad... Topmost tip of the crane to lowest tip of the factory ceiling/ structure is approx 50 mm. You can refer to the attachment for your kind reference. I am Training.
Looks to me like this building in its current configuration is not a good candidate for a wall-to-wall gantry crane. What's the possibility of moving or eliminating the stuff in the way?
