Instantaniouse center of 0 velocity
  • Thread starter Thread starter joemama69
    Center Velocity
The discussion centers on calculating the velocity of point B with respect to point A using the method of instantaneous center of zero velocity. Given points A = (0.5, 1.5), B = (1.5, 1), and an instantaneous center (IC) at (0.5, 2) with an angular velocity (ω) of 4 rad/s, the absolute velocities are determined as V(A) = 2 m/s and V(B) = 4.4721 m/s. The relative velocity of B with respect to A is calculated using vector subtraction, resulting in a final velocity of 3.6568 m/s in normal notation.
  • Understanding of instantaneous center of zero velocity
  • Familiarity with vector notation and operations
  • Knowledge of angular velocity and its application in linear motion
  • Proficiency in basic calculus for deriving velocities
  • Study the application of the instantaneous center method in different mechanical systems
  • Learn about vector addition and subtraction in the context of relative motion
  • Explore angular velocity calculations in rigid body dynamics
  • Investigate the implications of counterclockwise rotation on velocity vectors
Students and professionals in mechanical engineering, physics enthusiasts, and anyone involved in dynamics and kinematics analysis.
joemama69
Solve using the mothod of instantaneous center of zero velocity
Point A = (.5,1.5), B = (1.5,1) and IC = (.5,2), w = 4 rad/s
Determine the velocity of B with respect to A
v=wr
V(a) = wr(a) where w = 4 rad/s and r(a) = .5
=2
V(b) = wr(b) hwere w = 4, and r(b) = (x^2+y^2)^1/2
V(b) = 4.4721...
How do i find the velocity of B with respect to A
v=wr
=2
V(b) = 4.4721...
The Velocities are vectors. A is directed positive X and B is directed 45° above positive X.
So ... Vb relative to Va is Vb - Va isn't it?
I'm confused. My book does not mention anything about vectors in this section.
How are u able to say that A is headed possitive x and B is headed 45 above x.
But i'll take ur suggestion and see hwat happens
vector A = 2i, vector B = 3.162i + 3.162j
vector B - vector A = 2i - (3.162i + 3.162j) = -1.162i + 3.162j
Doesnt seem right.
Look at point A: if the object id 'rotating' counterclockwise about the IC, then what direction is A moving in at this instant ? Surely both points are moving to the right..right?
Now, relative motion equations say that:
{the absolute velocity of point B}=
{the absolute velocity of point A}+{the velocity of point B with respect to point A}
or in vector notation:
\vec V_B=\vec V_A+\vec V_{B/A}
Solve this for
\vec V_{B/A}
Then using the IC, find \vec V_B and \vec V_A
Looking at the picture you provided, I'd say that the arrow to the Northwest looks to be counterclockwise to the center of zero motion. Drawing the displacement of A from O, then isn't the direction of motion necessarily ⊥ to the displacement vector?
That would tell me to direct that velocity along positive X if it is to be ⊥ to OA.
If this is incorrect, then my understanding of the center of zero velocity must be in error.
Ok Ok I understand the vector part now and the direction they are headed.
Absol V of B = 4.4721
Absol V of A = 2
So would the Absol V of B with resp to A = 4.4721 - 2 = 2.4721
Absol V of A = 2
Unless it is a special case, I do not think that this is correct since \vec V_B and \vec V_A are vectors and thus must be added (or subtracted) as such.
I am not sure is you will get the same answer.
ok now I am really confused. If i subtract vectors i get
If i use the absolute velocity
Absol V of A = 2
Is either of them right or wrong.
I could be making an error, here...but I am getting different numbers for \vec V_B
Using the exact same equations at the IC to find \vec V_B we have
\vec V_B=\vec V_{IC}+\vec V_{B/IC}
\Rightarrow \vec V_B=0+\vec V_{B/IC}
By definition:
\vec V_{B/IC}=\vec \omega \times \vec r_{B/IC}
Where \vec \omega=4 \hat{k} and \vec \r_{B/IC}=1\hat{i}-1/hat{j}
Thus,
\vec V_B=4\hat{i}+4\hat{j}
ahhhhhhhhhhh i gotcha calculator error
ok so then the Velocity of B with respect to A is..
2i+4j m/s in vector notation
Sounds good.
Want to run that by me again?
22+42=20
201/2=4.47
  • · Replies 26 ·
  • · Replies 18 ·
