Undergrad What is Integer Complexity and Why Does It Matter?
  • Thread starter Thread starter SSequence
    Complexity Integer
Integer complexity, introduced in the 1950s, refers to the minimum number of 1's needed to express a natural number using basic arithmetic operations. Examples illustrate that the complexity of 12 is 7 and that of 6 is 5, based on their arithmetic representations. The discussion raises questions about the allowed operations and the implications of including subtraction and division, suggesting that complexity may be bounded when using a fixed set of symbols. Additionally, it touches on the relationship between integer complexity and logarithmic functions, indicating that the lower bound for complexity is proportional to log n. The conversation highlights the mathematical intricacies and ongoing exploration of integer complexity.
SSequence
Not a question as such, but an interesting notion that I came upon (maybe some other people would find it interesting too). It seems to have been introduced in 1950's and seems a good amount of work has been done on it.
For example:
12=(1+1+1)*(1+1+1+1)
So the complexity of 12 is 7 since it can be represented by a minimum of seven 1's in an arithmetic expression (that only uses 1's). Similarly:
6=(1+1+1)*(1+1)
So the complexity of 6 is 5 since it can be represented by a minimum of five 1's in an arithmetic expression (that only uses 1's).
I don't know how well this notion is known. I guess it would depend on interest/knowledge of specific area (e.g. someone with interest/knowledge of combinatorics would have more likely heard of it).
Likes r731 and Delta2
Mathematics news on Phys.org
Isn't this just the sum of the prime factors of each number?
Likes Delta2
The sum of the prime factors of ##2^{82,589,933}-1## is ##2^{82,589,933}-1##, but its complexity is at most ##2*82,589,933+1## or ##165,179,867##.
I suppose OP could have given more illuminative examples, though 😁
  • Love
Likes Delta2
What exactly is allowed in the arithmetic expression? Addition and multiplication obviously, I guess subtraction and division as well. Something else?
There is some complexity in choosing that expression on its own.
If you allow all common mathematical symbols then numbers have a bounded complexity, because it's possible to express all of them with a suitably long combination of square roots and similar things using a fixed set of "1".
Is this the largest known prime number of the form ##2^n-1##?
Likes suremarc
As I have been able to understood the definition, valid arithmetic expressions with the following five alphabet (base symbols):
{ ( , ) , *, +,1 }
So for a given number ##n \in \mathbb{N}^+##, we would write all the expressions which evaluate to the value ##n## and count the number of ##1##'s in each of those expressions. There will be one or more expressions containing the smallest number of ##1##'s. That would be the (integer) complexity of ##n##.
Good point w.r.t. minus and division. I am wondering how much things would change with allowing minus and division.
I didn't understand this. Any example?
With regards, to more non-trivial examples, here are few I found in a paper (in the introduction part). I am just copying the examples (and assuming these are expressions with minimal number of 1's):
## 75025 = (1 + 2^2)(1 + 2^2)(1 + 2(1 + 2^2)(1 + 2^2)(2^2.3(1 + 2^2)))##
complexity=1+4+1+4+1+2+5+5+7+1+4=35
and:
##2^{27}−1 = 134217727 = (1 + 2·3)(1 + 2^3·3^2)(1 + 2^9·3^3(1 + 2·3^2))##
complexity=1+5+1+6+6+1+18+9+1+2+6=56
Likes Delta2
Upon inspection, it felt to me as if the lowest possible complexity should be proportional to ##\log n##. I assumed the best possible case was ##2^n## with a complexity of 2n. Actually, this has been solved according to the Wikipedia article, which gives upper and lower bounds that are proportional to ##\log n##. Turns out the lower bound is ##3n\log_3(2)\approx 1.89n##, which is just shy of ##2n##. Neat stuff.
Affirmative.
After thinking about it, I don’t know if this is true. Addition, subtraction, multiplication, addition, and exponentiation are all binary operations, so you can only express a finite amount of numbers using them. And the square root can be applied only a finite amount of times if the codomain is restricted to the integers, so I think adjoining a square root would not change this.
If the complexity were bounded, there would have to be some ##k## for which there are infinitely many numbers with complexity ##k##.
If I would have rememberd the exact method I would have posted it. Anyway, I found it again:
$$n = \frac{-2}{\ln(4)} \ln\left( \frac{\sqrt{\sqrt{\dots\sqrt{4}}}}{ln(4)} \right)$$
where you need n square roots and 2 and 4 can be expressed with 1s in the trivial way. This is coming from the challenge to express natural numbers with 4 "4", you can probably convert this to use 2 instead of 4 to reduce the number of "1"s. Anyway, it's a finite set if square roots and logarithms are allowed.
@suremarc: There are more common mathematical symbols and no one required the expression to operate purely in the integers.
I don't understand why the author chose such a confusing notation for 75025.
75025 = 5*5*(1+2*2*2*3*5*5*5).
Writing 5 as 1+22 does nothing to make things simpler and writing identical factors in different places isn't going to help either.
Likes suremarc
For the sake of reference, here is the paper I copied the examples from: https://arxiv.org/abs/1404.1850
(the examples can be found at the beginning of second page)
Likes Delta2
So the domain and co-domain of the complexity function ##C## is the set of positive integers and (among other properties) it satisfies
1) ##C(1) = 1##
2) ##C(x + y) \le C(x) + C(y)##
3) ##C(xy) \le C(x) + C(y)##
Does it satisfy any interesting inequalities of the form ##C(x) \ge## ...? or ##C(x+y) \ge##...? or ##C(xy) \ge##...?
https://oeis.org/A005245
There is the trivial ##C(x) \geq 3 floor(\log_3(x))## with equality for powers of 3.
I don't have a tool to explore this numerically, but I could imagine that C(xy)>C(x) is not always true. Good candidates would be x=(3n+1)/2 and y=2 (with n>4).
Edit: C(1486)=22, C(743)=22
743 is a prime, instead of multiplying it by 2 we write 1486 as 1485+1 and 1485 = 33*(1+2*33) has a nice composition.
This is the only counterexample up to 1600 that I found looking for a factor 2.
Edit: How could I forget that.
C(x)=min(C(z)+C(y)|z+y=x ##\lor## z*y=x)
Likes suremarc
C(x)=min(C(z)+C(y)|z+y=x ∨ z*y=x)
I wrote this down too, but don’t know how to get anything useful out of it.
It's a fast method to calculate C(x) for all x from 1 to N.
  • · Replies 0 ·
