Integrating 2/(x-2)^3
  • Thread starter Thread starter lost_math
    Dx
8 replies · 3K views · last reply
lost_math
\ 2/(x-2)^3 dx
Basically integrating a perfect cube in the denominator with a constant in the numerator
i thought it would be a form of ln(x), but then, that would mean having atleast some x terms in the numerator which are not there, so, how do i do this? Is there a known pre-fixed solution for these things? Like exp(something)?
Use [tex]\int x^ndx = \frac{x^{n+1}}{n+1} + c[/tex]
Try writing as 2(x-2)-3. Do you know how to integrate x-3?
Thanks Arun and Cristo.
Cristo, I don't know how to integrate x^-3. (i think i might be hopeless, right?)
Arun, what is the expansion formula you just gave me called? Is there a name for solving by that method? It is applicable to negative powers as well?
Arunbg's formula is the formula for integrating a polynomial function of x. Thus, to integrate x-3 you would use that formula.
you want to integrate 2(x-2)-3
using this [tex]\int x^n = \frac{x^{n+1}}{n+1} + c[/tex]
the first thing you notice is that you add 1 to the power, then you divided by the new power
after that you multiply by the differential of what is inside the brackets
The last bit should read: you divide by the derivative of the term inside the brackets.
(I know it's probably a typo, and it doesn't matter in this case; but it may confuse the OP in future if left uncorrected)
yes definitely a typo :blushing:
you always divid by the differential of the inside of the brackets when integrating!
