Integrating e^(2 theta)sin(9 theta) d theta
  • Thread starter Thread starter tangibleLime
    Integrating Theta
2 replies · 8K views · last reply
tangibleLime
Integrate.
[tex]\int e^{2\theta}sin(9\theta) d\theta[/tex]​
Integration by Parts
[tex]\int udv = uv - \int vdu[/tex]​
I started out with integration by parts (IPB).
[tex]u = e^{2\theta}[/tex]
[tex]du = 2e^{2\theta} d\theta[/tex]
[tex]v = \frac{-1}{9}cos(9\theta)[/tex]
[tex]dv = sin(9\theta) d\theta[/tex]
[tex]uv - \int vdu = -\frac{1}{9}cos(9\theta)*e^{2\theta}+\frac{2}{9}\int cos(9\theta) d\theta[/tex]​
Noticing that the new integral on the right is just about the same as how I started (sin just turned into cos), I did IPB once again.
[tex]v = \frac{1}{9}sin(9\theta}[/tex]
[tex]dv = cos(9\theta) d\theta[/tex]
[tex]uv - \int vdu = \frac{1}{9}sin(9\theta)*e^{2\theta}-\frac{2}{9}\int sin(9\theta)*e^{2\theta} d\theta[/tex]​
Combining all of this into the equation so far...
[tex]-\frac{1}{9}cos(9\theta)*e^{2\theta}+\frac{2}{81}sin(9\theta)*e^{2\theta}-\frac{2}{9}\int sin(9\theta)*e^{2\theta} d\theta[/tex]​
Noticing that this new integral on the right is the exactly equal to what I started with, I added it to both sides in order to remove it from the right side. I mentally noted that the left version could have a coefficient of [tex]\frac{9}{9}[/tex], and added the right side's coefficient of [tex]\frac{2}{9}[/tex] to give me the final coefficient for the left version of [tex]\frac{11}{9}[/tex].
[tex]\frac{11}{9}\int e^{2\theta}sin(9\theta) d\theta = -\frac{1}{9}cos(9\theta)e^{2\theta}+\frac{2}{81}sin(9\theta)e^{2\theta}[/tex]​
To get that [tex]\frac{11}{9}\[/tex] out of the left side of the equation to get my original integral back, I multiplied both sides by it's reciprocal, [tex]\frac{9}{11}[/tex]. Then I tacked on the constant of integration to arrive at my final answer.
[tex]\int e^{2\theta}sin(9\theta) d\theta = \frac{9}{11}(-\frac{1}{9}cos(9\theta)e^{2\theta}+\frac{2}{81}sin(9\theta)e^{2\theta}) + C[/tex]
This was marked wrong, even after I simplified the answer (which I did not do here, but I checked the simplification with WolframAlpha). Any suggestions?​
If you differentiate your result, you get 85/99 e2tsin 9t, which is almost what you started with, so it looks like you just made an arithmetic or algebra error somewhere. Your method is correct.
Thanks, I figured as much, that's usually my downfall :D As long as I know my method is correct, I'm okay with it.
