Integrating exp(sin(t))/(1+t²)
  • Thread starter Thread starter NeedPhysHelp8
    Integration
4 replies · 2K views
NeedPhysHelp8
Integrate: [tex]\exp(\sin(t)) / (1 + t^2)[/tex]
The attempt at a solution
Ok so I tried substituting u=sin(t) du=cos(t)dt but I end up with (1 + arcsin^2(u)) on the bottom and I don't know how to integrate that.
I also tried letting t=cos(u) dt=-sin(u)du but then I end up with e^(sin(cos(t)) which I've never seen before!
If anyone knows how to do this please just give me a hint or the first step to take and I will try to do the rest! Thanks
I don't think you can integrate that analytically. Is this integral part of a larger problem?
Ok well it was a differential equation problem that I reduced to that but here is the initial problem:
[tex]dy/dt + y\cos(t) = 1/ (1+t^2)[/tex]
so I got an integrating factor of [tex]e^(sint)[/tex] which led to this integral! Hope this helps maybe I did something wrong in first part.
Hmm, perhaps you're expected to leave the solution in terms of the integral.
I don't think so since the prof asked to solve it in terms of t explicitly. Maybe she made a mistake in writing the problem if this cannot be solved analytically.
