Integrating with U-substitution
  • Thread starter Thread starter zooboodoo
    Integrating
6 replies · 2K views
zooboodoo
Find the integral of (1-x)((2x-x^2)^.5) dx
I am kind of hazy on U substitutions but I thought that was the right way to go here:
let u=2x-x^2
du=2-2x
(1/2) Integral of (u)^.5 du < i wasn't sure if I went wrong here, Since i had (1-x) in the original equation and my du=2(1-x) can i put du in my substitution as long as I put (1/2) to balance the equation?
using this I got (2x-x^2)^(3/2)/(6) + C which was marked wrong. any insight would be appreciated
Your original integral is:
[tex]\int{\frac{1-x}{\sqrt{2x-x^2}}dx[/tex]
You did the substitution well.
[tex]u=2x-x^2[/tex]
[tex]du=(2-2x)dx=2(1-x)dx[/tex]
So [itex]dx=du/2(1-x)[/itex]
Now just substitute back in the integral (for dx and u)
[tex]\int{\frac{1-x}{\sqrt{u}}*\frac{du}{2(1-x)}}[/tex]
oh no the initial integral is (1-x)Squareroot(2x-x^2) all in the numerator
[tex] \int{{1-x}{sqrt{2x-x^2}}dx[/tex]
Hi zooboodoo! :smile:
(have a square-root: √ and try using the X2 tag just above the Reply box :wink:)
zooboodoo said:
… (1/2) Integral of (u)^.5 du < i wasn't sure if I went wrong here, Since i had (1-x) in the original equation and my du=2(1-x) can i put du in my substitution as long as I put (1/2) to balance the equation?
Yes, you've done everything perfectly, except you got the factor, 6, wrong at the end …
differentiate what you have (using the chain rule), and you'll see. :smile:
wah it was supposed to be /3 wasn't it :-x so frustraating
zooboodoo said:
… so frustraating
yeah … it's so easy to make a mistake like that! :frown:
always check any integration problem by differentiating your answer, and making sure you get back to where you started! :wink:
