Integrating with U-substitution
  • Thread starter Thread starter zooboodoo
    Integrating
The problem involves finding the integral of the expression (1-x)√(2x-x^2) dx, which falls under the subject area of calculus, specifically integration techniques including U-substitution.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts a U-substitution with u=2x-x^2 and expresses uncertainty about incorporating the (1-x) term in their substitution. They question whether they can balance the equation with a factor of (1/2) when substituting for dx.
Participants have provided feedback on the original poster's substitution approach, with some confirming the correctness of the substitution while others point out a mistake in the final factor of the integral. There is an ongoing exploration of the implications of these adjustments.
There is a noted frustration regarding the accuracy of the final answer, with participants discussing the importance of verifying integration results through differentiation. The original poster's integral setup and the presence of the (1-x) term are central to the discussion.
zooboodoo
Find the integral of (1-x)((2x-x^2)^.5) dx
I am kind of hazy on U substitutions but I thought that was the right way to go here:
let u=2x-x^2
du=2-2x
(1/2) Integral of (u)^.5 du < i wasn't sure if I went wrong here, Since i had (1-x) in the original equation and my du=2(1-x) can i put du in my substitution as long as I put (1/2) to balance the equation?
using this I got (2x-x^2)^(3/2)/(6) + C which was marked wrong. any insight would be appreciated
Your original integral is:
[tex]\int{\frac{1-x}{\sqrt{2x-x^2}}dx[/tex]
You did the substitution well.
[tex]u=2x-x^2[/tex]
[tex]du=(2-2x)dx=2(1-x)dx[/tex]
So [itex]dx=du/2(1-x)[/itex]
Now just substitute back in the integral (for dx and u)
[tex]\int{\frac{1-x}{\sqrt{u}}*\frac{du}{2(1-x)}}[/tex]
oh no the initial integral is (1-x)Squareroot(2x-x^2) all in the numerator
[tex] \int{{1-x}{sqrt{2x-x^2}}dx[/tex]
Hi zooboodoo! :smile:
(have a square-root: √ and try using the X2 tag just above the Reply box :wink:)
zooboodoo said:
… (1/2) Integral of (u)^.5 du < i wasn't sure if I went wrong here, Since i had (1-x) in the original equation and my du=2(1-x) can i put du in my substitution as long as I put (1/2) to balance the equation?
Yes, you've done everything perfectly, except you got the factor, 6, wrong at the end …
differentiate what you have (using the chain rule), and you'll see. :smile:
wah it was supposed to be /3 wasn't it :-x so frustraating
zooboodoo said:
… so frustraating
yeah … it's so easy to make a mistake like that! :frown:
always check any integration problem by differentiating your answer, and making sure you get back to where you started! :wink:
  • · Replies 27 ·
  • · Replies 105 ·
12K
  • · Replies 22 ·
