Homework Helper
- Messages
- 8,770
- Reaction score
- 2,191
Yikes, interference in Product State statistics? In polarization outcomes on distinguishable photons in a beam splitter?Morbert said:The signatures are the same, but our inference changes depending on what measurement is carried out.
1. When a BSM is carried out, then
(HH b"c") implies |Φ-⟩
(VV b"c") implies |Φ-⟩
2. but when an SSM is carried out
(HH b"c") implies |HH⟩ = (|Φ+⟩ + |Φ-⟩)/√2
(VV b"c") implies |VV⟩ = (|Φ+⟩ - |Φ-⟩)/√2
You can see that in one case we are discarding all runs that aren't |Φ-⟩, but in the other case we are instead discarding all runs that aren't (|Φ+⟩ + |Φ-⟩)/√2 or (|Φ+⟩ - |Φ-⟩)/√2. See how |Φ+⟩ gets mixed in to the SSM runs but not the BSM runs?
3. Counterfactual definiteness is unfortunately always a concern whenever we are considering scenarios where a choice has to be made between complementary measurements. In this case, if we perform an SSM and a run is kept, we cannot say that if we had instead done a BSM the run would still have been kept.
1. This is correct.
2. This is absolutely not correct. An HH (or VV) outcome from measurements on 2 photons that are distinguishable and have never interacted are NEVER a sum (or difference) of 2 entangled states. In fact, your assertion implies that all photons everywhere are in one or the other of a maximally entangled state - a result that violates MoE.
And besides, makes no sense at all. Again, these photons have not interacted so interference is obviously not a factor. And as I have already documented, a beam splitter will not change a V to H or vice versa anyway - entangled or not.
And because these photons are distinguishable in the SSM mode: They are in a Product state, so you cannot use terms like "(|Φ+⟩ + |Φ-⟩)/√2" to describe them. This is basic, nothing really to debate here.
The statement that would be correct is as follows: (HH b"c") implies we have an equal superposition of circular polarization Product states with |LL>, |LR>, |RL>, |RR> outcomes. Etc.
Hopefully, you will rethink this and retract without argument.
3. As I said, Counterfactual Definiteness (CD) is not an assumption in this experiment - any more than it is in any scientific experiment anywhere at any time. This is hand-waving at its worst. I can't stop you from believing it yourself, but I will challenge you to back it up for experiments of this type.
We are physically testing an A/B setup with a single independent variable. Flip a switch, and the results change. If I do this experiment with a classical setup, there is no scientific difference versus doing it with a quantum setup. I set my criteria for what I am testing, and record the results. With the switch is on, the results are different than when the switch if off. CD does not matter for scientific experiments of this type.
