Homework Helper
- 2,139
Morbert said:1. I don't know if we disagree here or are just misreading each other. On page 14 of Ma et al, the time-evolution through the set up is shown for when swap = on. You can see that the evolution relates the detected signatures at the end of the run, in spatial modes b'' and c'' to the state that was in the incident spatial modes b and c. This is also made clear by Fig. 2 where we can see the ordering of b c b' c' b'' c''. We see from these evolution rules that Victor uses the signatures in b" and c" to resolve a BSM in b and c. Similarly, when the quarter wave plate is off, the signatures in b'' and c'' resolve an SSM in b and c.
2. I don't understand [the quoted paragraph in bold]. ... If photons 1 and 2 are measured in different, unbiased bases, no correlation will be observed.
3. Yes, if a swap occurs, then photons 2 & 3 are projected onto Φ-, as are photons 1 & 4. If no swap occurs, no such projection occurs. We both agree with this.
4. Where we diverge is the interpretation of the projection. You interpret it as a very literal ontic event. But there are alternatives. E.g. The Copenhagen interpretation frames the projection as Victor updating the information he has about the outcomes of measurements on 1 and 4. The statistical ensemble interpretation frames the projection as the identification of a subensemble that will exhibit correlations between measurements on 1 and 4. When no swap is carried out, no such information can be learned about 1&4, and no such subensemble can be identified. At most, if an SSM is carried out, then a subensemble with correlations like Fig 3b is identified.
1. Ma, explaining how the EOMs I mentioned control the BSM vs SSM choice: "With opposite voltages on EOM1 and EOM2, we realize a π/2 phase change of the MZI (corresponding to Bell-state measurement) when EOM1 is applied with +EV and EOM2 with –EV, and no phase change(corresponding to separable state measurement) when EOM1 is applied with -EV and EOM2 with +EV."
However, this difference in how we understand turning swapping on and off has no real significance to our debate. How they do it isn't as important as we agree they are doing it as far away from Alice and Bob as needs be. This particular incarnation of Entanglement Swapping highlights delayed choice (failure of Einsteinian causality), but could just as easily highlight distance apart.
2. You: "If photons 1 and 2 are measured in different, unbiased bases, no correlation will be observed."
Me: "...the circular polarization of photon 1 is in a separable Product state with the vertical polarization of photon 2 after initial creation via PDC. ... There is no possibility of any statistical relationship in such a product state, [and they will be uncorrelated.]"
We're saying the exact same thing. It is a fact that photons 1 and 2 are initially entangled as Ψ-. However, photon 1 and photon 2 are entangled only on identical polarization bases. Bases L/R and H/V are different. Consequently, we must agree: there can be no correlation between Photon 1's L/R and Photon 2's H/V. They are in a Product state.
3. Yay!
4. We disagree on the interpretation of the projection (ontic vs epistemic), that too. You mention:
-The Copenhagen interpretation frames the projection as Victor updating the information he has about the outcomes of measurements on 1 and 4.
-The statistical ensemble interpretation frames the projection as the identification of a subensemble that will exhibit correlations between measurements on 1 and 4. When no swap is carried out, no such information can be learned about 1&4, and no such subensemble can be identified. At most, if an SSM is carried out, then a subensemble with correlations like Fig 3b is identified.
"Updating the information" is scientifically meaningless. Every experiment requires bringing information together. Hardly a description invoking locality.
"Identification of a subensemble" is precisely what I have said is impossible, and should be dropped as an argument to explain entanglement swapping using locality. We agreed that there is no statistical correlation between the L/R polarization of photon 1 with photon 2's H/V polarization; and the L/R polarization of photon 4 with photon 3's H/V polarization. Consequently, and there can't really be any question about this: you cannot learn anything about photon 1 and photon 2's L/R polarization by measuring the H/V polarizations of photon 2 and photon 3.
But where we really disagree is twofold:
A) A physical change to a setting *here* leads to a change in observed statistics *there*, holding all parameters constant other than the swap/no swap mechanism. Now I know you claim it is a different selection criteria being applied in the Ma experiment (you're wrong though). But the Megadish experiment reports the same result as Ma, but uses a different swap/no swap mechanism that is NOT subject to your critique. (There is no changing of a beam splitter, no change of wave plates, no optical change at all.)
B) It is canonically impossible for there to exist "hidden correlations" that are merely identified via BSMs. We should agree on this at this point - see point 2 above.
