Irrational or Rational [Newton-Raphson]
2 replies · 2K views
luznyr
How are you able to determine if a solution is rational or irrational
:confused:
I'm pretty sure it will be something basic I'm forgetting, thanks for any help.
If you mean that you are using the Newton-Raphson method to solve an equation, then there are two oppposite ways to answer: (1) The "solution" the Newton-Raphson method gives you- which may be only approximate is always rational because it can only give you a finite number of decimal places. (2) There is no way of determining from the Newton-Raphson method whether or not the true solution to the equation is rational or irrational because you cannot determine the true solution using the Newton-
Raphson method.
