Is a matrix diagonalizable if A^2009 + A^2007 = 0?
  • Thread starter Thread starter talolard
    Form
4 replies · 2K views · last reply
talolard
edit, sorry its not jordan form, I misplaced words.
Hey,
Let A be an nxn matrix over some field F. [tex]A \neg 0[/tex] and [tex]A^{2009}+A^{2007}=0[/tex]. Is a diagnizable?
Attempt at solution
we can notice that [tex]A^{2009}+A^{2007}=0 \iff A^{2007}(A^2+I)=0 \iff A^{2007}=0 or A^2=-I[/tex]
If [tex]A^2 = -I[/tex] then a is a diagnol matrix with eigenvalues i and -i (i is defined as the sqaure root of -1 in the field. if the field does not have sucha number then A is not diagnizable).
If [/tex] A^2 \neq -I [/tex] then[tex]A^{2007}=0[/tex] but the A is nillpotent and so has less the n eigenvectors, so A is not diagnizable. q.e.d.
Is this correct?
Thanks
Tal
You are omitting a possibility. For square matrices A and B, it is possible for AB = 0 where neither A nor B is the 0 matrix.
Here's a simple example.
[tex]\left[ <br /> \begin{array}{c c} 0 & 1 \\ 0 & 0 \end{array} \right]<br /> \left[ <br /> \begin{array}{c c} 0 & 2 \\ 0 & 0 \end{array} \right] = <br /> \left[ <br /> \begin{array}{c c} 0 & 0 \\ 0 & 0 \end{array} \right][/tex]
Hi Mark,
thanks for your input. I think I'm missing your point.
As I see it, I am only talking about AA, and not Ab, two different matrices. if B= A^2006 abnd AB=-0 tehn AB=A*A*A&2006=A^2007=0 which still leaves A nilpotent.
If that is not the case then we need A^2=-I which still means that A is diagnozable iff sqrt(-1) exists in the field.
What am I missing?
Thanks
Tal
You are talking about two different matrices: A2007 and A2 + I. You said that since A2007(A2 + I) = 0, then it must be that A2700 = 0 or A2 + I = 0.
What I said was that it is possible for the product of two matrices to be zero, where neither matrix is the zero matrix.
It is true that if A = 0 or B = 0, then AB = 0, but the converse is not necessarily true, as my example shows.
Ok, here's an improvment:
Assume A is diagnizable. Let v be an eigenvector of A with an eigenvalue, c, that is not 0. then we have
[tex](A^{2009}+A^{2007})\vec(v) =A^{2009}\vec(v) + A^{2007}\vec(v) = c^{2009}\vec(v) + c^{2007}\vec(v)=0 \iff c=i or c=-i[/tex]
If A is a 2x2 matrix over a field where i exists then the matrix is diagnizable. otherwise it i not.
if RkA> 3 then for A to be diagnizable it would need other eigenvalues but none would atisfy the condition.
Is that correct?
Thanks
Tal
