Is Anti-Gravity Levitation Possible for Human Transport?
  • Context: Undergrad
  • Thread starter Thread starter Robin07
    Anti gravity Gravity
The discussion centers on the feasibility of anti-gravity levitation for human transport, emphasizing that current technology only allows for suspension rather than true levitation. Participants highlight that mechanisms like spinning tops and electromagnets create the illusion of floating but are not independent of Earth's rotation. The conversation explores the theoretical application of electromagnetic pulses on diamagnetic materials, specifically water, but concludes that the required magnetic field strength for practical levitation is prohibitively high. Ultimately, while the physics may support the concept, the practical implementation remains unfeasible.
  • Understanding of diamagnetism and its properties, particularly in materials like water and superconductors.
  • Familiarity with electromagnetic principles and their application in levitation technologies.
  • Knowledge of Earth's rotation and its effects on objects in motion.
  • Basic physics concepts related to force and motion, including Newton's laws.
  • Research the principles of diamagnetism and the diamagnetic strength of various materials.
  • Explore the applications of superconductors in magnetic levitation technologies.
  • Investigate current advancements in electromagnetic propulsion systems.
  • Study the physics of motion in relation to Earth's rotation and its impact on airborne vehicles.
This discussion is beneficial for physicists, engineers, and researchers interested in advanced transportation technologies, particularly those exploring the boundaries of levitation and propulsion systems.
Robin07
Fictious meaning that we doen't have anything, as of yet, that can levitate not above a mechanism that aids in its apparent floating capability. Such as a levitating spining top and the base that it needs to float on. Or an electomagnet that turns on and off repeadedly to give the illusion of foating, which I find is more suspension than levitation. No, I'm taking about a free floating platform of sorts that you can stand on, ballanced. And perhaps when you should tilt your head one way or the other you would then be tipping yourself off of the center of gravity so that you would be able to experience locamotion.
My question would be if a person is independent of Earths rotation. Would that person then be standing still as the Earth rotates underneath? This would be 1000.7 km/h at the equator in an west to east direction and going in a tight circle at the poles. Yes? I hope that this is not the case...
Absolutely, That never came to mind. Like the helicopter floats on air, independent of Earth.
Thanks.
Thanks.
Except that the air is connected to the Earth (it is rotating with the Earth), so it is not independent of the Earth.
Good point, So then would it be entirely possible to have a strong enough electromagnetic pluse or sucessive pulses, that would be directed to a diamagnetic material such as water. To levitate over? What type of form would this pulse be or better yet, what if any would be expected to happen to the waters' surface. Since its' being induced into a bouant, diamagnetic. If I undersatnd this train of thought. This would give an equal, and opposite force that it originated from. In therory would that be correct?
While the physics seem to work, the idea is simply unfeasible. See the following article and look at the table that lists the diamagnetic strength of certain materials. http://en.wikipedia.org/wiki/Diamagnetism
Notice that water is at -0.91 and that a superconductor is at -105. This means that a superconductor is repelled from a magnetic field over 100,000 times more strongly than water is. So while you can levitate a small piece of superconducting material over a permanent magnet, the strength of the field you would need to levitate a magnetic platform over water is unimaginably high.
I thought the helicopter would move together with the rotation of the Earth firstly not because of the air but because it had moved with it while it was standing, and kept its momentum when it lifted off.
Absolutely.
  • · Replies 27 ·
  • · Replies 55 ·
16K
  • · Replies 19 ·
