Is Complex Differentiation Defined for Linear Transformations?
4 replies · 2K views · last reply
r731
Let z = [a b]^T be in the 2-dimensional vector space over real numbers, and T a linear transformation on the vector space.
Consider
$$\lim_{z'\rightarrow \mathbf{0}} \frac{T(z+z')-T(z)}{z'}$$
I argue this could be an alternative definition for complex derivative.
To illustrate this, z as a complex number ##a+bi## is a vector [a b]^T and z' is a tiny vector parallel to z. Taking the limit, z+z' approaches z and the limit approaches the rate of change of T at z.
<Moderator's note: please use the proper wrappers, ## ## and $$ $$, for LaTeX.>
Is there a particular reason why you would need an alternative definition for the derivative of a complex function?
In your formula, it is not clear what you mean when you divide by ##z'## when ##z'## is regarded as an element of ##\mathbb{R}^2##. For multivariable functions, the difference quotient definition of the total derivative is not useful.
In any case, any reasonable definition of the derivative of a linear transformation of ##\mathbb{R}^2## at a point will reproduce that linear transformation itself.
Incidentally, this is useful to find out how to embed ##\LaTeX## in your posts here.
The reason is I want to get rid of the difficulties with the complex log multi-function.
An example: The derivative of ##z^2 = (a + bi)^2## equals ##2z##. Let ##z := [a\;\;\;b]^T## and ##T([a \;\;\; b]^T) := [a^2 \;\;\; b^2]^T##.
##\lim_{\delta z\rightarrow \mathbf{0}} \frac{T(z+\delta z)-T(z)}{\delta z}=
\lim_{\delta z\rightarrow \mathbf{0}} \frac{[(a+\delta a)^2\;\; (b+\delta b)^2]^T}{[\delta a \;\;\; \delta b]^T}##
Simplifying and factoring out yields
##\lim_{\delta z\rightarrow \mathbf{0}} \frac{[2a\delta a\;\; 2b\delta b]^T}{[\delta a \;\;\; \delta b]^T} =
2[a\;\;\; b]^T.##
##2[a\;\;\; b]^2## corresponds to ##2z##.
Your example is not a linear transformation, violating the conditions of post 1. I don't understand why you wanted this to limit to linear transformations anyway, but you did.
The fraction of a vector and a vector is generally undefined.
