Is f(x,y) = x²/y a linear transformation?
7 replies · 2K views · last reply
negation
Piecewise definition of f: R^2 to R, mapping (x, y) to x^2/y if y is not 0, and to 0 if y = 0.
I don't think I'm interpreting the question correctly. Maybe someone can point me in the right direction?
There are 2 conditions: if y =/=0 then f(x,y) = x^2/y and if y=0 then f(x,y) = 0
Let u =(1,1) and v = (1,1)
f(v) = f(1,1) = 1^2/1 = 1
f(u) = f(1,1) = 1
f(u) + f(v) = 2
f(u+v) = 2
testing for the second condition: if y=0 then f(x,y) = 0
let u = (1,0) v = (1,0)
f(u) = 0 since if y = 0, f(x,y) = 0
f(v) = 0
f(u) + f(v) = 0
f(u+v) = f(2,0) = 0
I assume that the goal is to check whether ##f## is linear. So your approach is fine:
f(u) = f(1,1) = 1
f(u) + f(v) = 2
OK so far.
f(u+v) = 2
No, ##u+v = (1,1) + (1,1) = (2,2)##. What do you get when you evaluate ##f## at this point?
[edit] Oops, I miscalculated. Yes, you get 2. So this shows that ##f(u+v) = f(u) + f(v)## for that particular choice of ##u## and ##v##. But to conclude linearity, you need to show that it is true for all choices of ##u## and ##v##.
Hint: try another choice of ##u## and ##v##.
OK so far.
I presume we are referring to the first condition in the question where x^2/y ?
I tried a few values but they all preserve addition.
Yes, the ##y=0## case is unlikely to provide a counterexample for additivity.
You should be able to find a simple counterexample using points of the form ##(a,1)## and ##(b,1)##
That "[itex]x^2[/itex]" makes me suspicious! So I would try u= (2, 1) and v= (3, 1).
What are f(u) and f(v)? What is f(u)+ f(v)?
u+ v= (5, 2). What is f(u+ v)?
Halls!
Any reason as to why you chose those values for u and v? Are they just arbitrary?
f(u) = f(2,1) = 4 f(v) = f(3,1) = 9
f(u) + f(v) = 13
u + v = (5,1)
f(u+v) = 25
Almost any choice of u and v will work, but the calculation of ##\frac{(u_1)^2}{u_2}+\frac{(v_1)^2}{v_2}## is easier when ##u_2=v_2##, and is especially easy when ##u_2=v_2=1##.
negation said:
Halls!
f(u) + f(v) = 13
u + v = (5,1)
You added ##(2,1)## to ##(3,1)## and got ##(5,1)##?
