Is grad F normal or tangent to a contour?
  • Level: Graduate
  • Thread starter Thread starter aero&astro
    Grad Nabla Operator
1 reply · 3K views
aero&astro
In my notes it says that grad F will give you a vector normal to the contour. Howver I thought grad F would give you a vector tangent because the path is aligned with the vector field. Is it different when talking about contours and paths?
If you find grad F of a function F does that give you a vector tangent or normal to the contour/path?
Hi aero&astro! :smile:
Yep.
grad F on a path will give you a vector tangent to the path.
grad F on an equation will give you a normal to a contour satisfying the equation.
Actually, the gradient gives you the vector in which F increases.
A path "increases" in the direction of the path.
The equation-value of a contour increases perpendicular to the contour.
Consider for instance y=x2.
Its path is given by f(x) = x2 and its contour-equation is F(x,y) = x2 - y = 0.
grad f(x) =2x, which gives you the direction f(x) increases with increasing x.
grad F(x,y)= (2x, -1), which gives you the direction F(x,y) increases with changing (x,y).
In the first case you "walk the path".
In the second case you move to a higher level contour given by F(x,y)=c.
