Is $I$ an Ideal in a Ring $R$?
  • Context:
  • Thread starter Thread starter mathmari
5 replies · 2K views
mathmari
MHB
Hey! :o
Let $R$ be a ring and let $I\subseteq R$ the unique maximal right ideal of $R$.
I want to show the following:
  1. $I$ is an ideal
  2. each element $a\in R-I$ is invertible
  3. $I$ is the unique maximal left ideal of $R$
For 1. we have to show that $I$ is also a left ideal, right? (Wondering)
Could you give me some hints how we could show that? (Wondering)
mathmari said:
Hey! :o
  1. $I$ is an ideal
For 1., let $r\in R$. What can you say about the set $rI$?
We have that $I$ is a right ideal, so it is an additive subgroup of $R$, so when $i,j\in I$ then $-i, i+j\in I$.
Let $a,b\in rI$, then $a=ri_1, b=ri_2, \ i_1, i_2\in I$.
Then we have the following:
$$-a=-(ri_1)=r(-i_1)\in rI \\
a+b=ri_1+ri_2=r(i_1+i_2)\in rI$$
So, $rI$ is an additive subgroup of $R$. For $x\in R$, $a'=ra\in rI$ we have that $a'x=rax\in rI$, since $I$ is a right ideal and so $ax\in I$.
That means that $rI$ is also a right ideal, right? (Wondering)
That is correct. For the next step, what I'm hoping is true is that every right ideal should be contained in a maximal right ideal ...
Since $I$ is a maximal right ideal, $rI$ is either a subset of $I$ or it is the entire ring $R$.
If $r$ has not a right inverse in $I$, then $rI$ doesn't contain $1$, so it must be $rI\subset I$.
Is this correct? (Wondering)
What if $r$ has a right inverse? (Wondering)
There are the following cases:
  1. If $rI\neq R$, then it must be $rI\subseteq I$, since $I$ is the unique maximal right ideal of $R$.
    If $rI\subseteq I$, then $ri\in I, \forall i\in I, \forall r\in R$.
    So, $I$ is a left ideal.
    Since $I$ is a right and a left ideal, it follows that $I$ is an ideal.
  2. If $rI=R$, then $ri=1$ for some $i\in I$.
    We have that $ir\in I$ since $I$ is a right ideal, so $ir\neq 1$.
    Then I thought to use post #8 of http://mathhelpboards.com/linear-abstract-algebra-14/statement-true-18331.html#post84301 to say that since $1-ir$ has no right inverse, it follows that $(1-ir)R\neq R$.
    Then $(1-ir)R$ is contained in the maximal right ideal, i.e., $(1-ir)R\subseteq I$. Then $1-ir\in I$.
    We have that $1=ir+(1-ir)\in I$, a contradiction.
    So, $rI\neq R$.
    But at the other post they told me that the argument of post #8 is not true... Do you maybe have an other idea how we can reject the case $rI=R$ ? (Wondering)
