Is Infinity Possible Within Our Finite Universe?
  • Level: Undergrad
  • Thread starter Thread starter pelletboy
    Infinity
76 replies · 33K views
pelletboy
Einstein mentioned that our universe if a finite spherical universe inside an infinite space. If this said infinite space is, as said, infinite, then infinity is possible? How do you explain the science of infinity?
  • Skeptical
Astronomy news on Phys.org
I doubt Einstein said that since it is absolutely not in accordance with modern cosmology. There is no "outside". The universe is everything there is. It may be infinite in extent or it may not. Infinite seems to be the general consensus these days but it is not a known fact. If it is finite, the topology is not known.
Sorry, this question is not clear, you need to elaborate.
russ_watters said:
Infinity is a mathematical concept, not a scientific one.
Infinity and related words refer to a set of conceptual abstractions which need not be restricted to mathematics. The question whether physical space is finite or infinite is not resolvable as simply a misapplication of the terms. It's a reasonable formulation of a question the correct answer to which is not known to be known.
Hi sysprog:
I wonder if "the correct answer" is not only not known but also not scientifically knowable. I cannot imagine a scientific method that would result in certainty that that the universe was in fact infinite, or in fact finite. However, I think there are methods that can produce an approximation of the probability that the universe is infinite or is finite.
I understand that the universe model that best fits the currently available astronomical data gives a value for the average spatial curvature that is close to zero on the side that corresponds to a hyperbolic (infinite) spatial geometry. This value also comes with a range of error. From these values (and assumptions about the probability distribution) one can calculate the probability that the geometry is not hyperspherical, which means it is not finite.
I apologize for not citing a well known reference on this topic, and the numerical values, but I do not now have the time to look it up.
ADDED
https://arxiv.org/pdf/1502.01589.pdfFrom abstract
The spatial curvature of our Universe is found to be very close to zero, with|ΩK|<0.005.​
6.2.4 Curvature
(49) The combined constraint shows impressive consistency with aflat universe: ΩK=−0.005+0.016−0.017(95%,PlanckTT+lowP+lensing).​
I confess I do not know the correct method for working with an with different value for + and -. I am making a guess that since the two values are close, if I use the average 0.0165 as standard deviation and assume a Gaussian distribution, then the probability will approximately be
P(ΩK > 0) ~= erf(0.005/0.0165) = ~erf(0.303) = ~0.332.​
Thus, based on the calculations of this reference, the probability is ~1/3 the universe is finite and ~`2/3 it is infinite.
Regards,
Buzz
There are "infinities" in the mathematics everywhere that describe our world. This exists even in the electronics and materials that you use everyday (look up van Hove singularity in the density of states of material). In fact, if you look at ordinary conductors, the concept that produces Ohm's law requires that the single-particle spectral function be a delta function!
So why is everyone fixated only on "space" and such exotica?
Zz.
  • Wow
It seems to me that proof of spatial finiteness in a spatially finite universe would be more likely to be attainable than would be proof of spatial infiniteness in a spatially infinite universe; if space is bounded, then we could imagine observing effects indicative of the existence of the boundary, but if space is unbounded, our not observing anything indicative of the existence of a boundary would not establish that there isn't one.
Zz.
We also don't know whether time and space at any scale are ultimately continuous or discrete.
Hi ZapperZ:
What causes my "fixation" is that I find it difficult to conceptualize about the geometry of the universe as being uncertain with respect to being finite or infinite. I am unaware of any other scientific question that has this particular uncertainty.
BTW, I added a reference and numbers to my previous post.
There are plenty of examples of physics that are so unlike our daily experience that we can never conceptualize them. Evolution did not wire our brains to conceptualize everything However we can understand them via the language of mathematics.
Buzz Bloom said:
Hi ZapperZ:
But you are not the OP, who questioned the "science of infinity". I pointed out that one doesn't need to look at issues of "space time" to discover that "infinities" exist almost everywhere in the mathematics of our physics. So do you and the OP also have no problems in accepting those infinities in your conductors and semiconductors, but only have problems with your concept of the "geometry of the universe"?
I find this very puzzling. People seem to think that such "exotic" properties only occurs in "exotic" physics, without realizing that the very things they use everyday exhibit similar properties.
Zz.
sysprog said:
... proof of spatial finiteness in a spatially finite universe would be more likely to be attainable than would be proof of spatial infiniteness in a spatially infinite universe; if space is bounded, then ...
I believe you have a misunderstanding about finiteness. The surface of the Earth is finite but it has no boundaries. A finite universe is similar except that the finite space is three dimensional rather than two.
Regards,
Buzz
That has no connection with what I wrote. I don't need to know such thing to show you that there are infinities in the mathematics that describe the semiconductors that you are using to write this on your modern electronic devices.
Zz.
Regards,
Buzz
In the sense in which I was using the terms 'bounded' and 'boundary', the volume of the Earth is bounded, and the surface of the Earth is its boundary.
Hi anorlunda:
I agree with the above quote, but you missed the critical point to my reason for "fixation". It is the uniqueness of this particular uncertainty. Do you know of any other physical context in which it is uncertain about infinite or finite? (Please do not use QM interpretations as an example. I have given up on trying to conceptualize in that context.)
Regards,
Buzz
But the point stands. Looking for evidence of finiteness by looking for a boundary is misguided. Finite but unbounded spaces (such as the surface of the earth) exist. We can never prove that the Earth's surface is finite by looking for an edge.
What we could do would be to get out our surveying equipment and look for triangles with internal angles that add to more than 180 degrees. Or we could just sail around the world.
Zz.
It's common knowledge that there are infinities in the mathematics that describe physical phenomena. We don't know whether anything physical is actually infinite. Your post questioned why there appeared to be a fixation on extension of space as to whether it is finite or infinite, and I presented an example of similarly unknown matters on the smallness scale as distinguished from the largeness scale; just as we don't know whether the universe is infinitely large, we don't know whether distances or durations can be infinitely or infinitesimally small.
Hi sysprog:
I apologize for my failure to be clearer. The volume of the Earth is not analogous to the volume of a finite universe. However, the surface is a two dimensional analogue of the three dimensional hyper-surface of a four dimetional sphere. The interior volume of the four dimensional hypersphere is not part of the universe. It is only the three dimensional hyper-surface which approximates the shape of a finite universe based on a general relativity (GR) model.
Regards,
Buzz
Hi sysprog:
I would appreciate seeing an example of such physical infinities. I am guessing there may be another misunderstanding that I may be able to explain.
Regards,
Buzz
Buzz Bloom said:
Hi sysprog:
Regards,
Buzz
What is the highest possible frequency, or shortest possible wavelength, of light? We can say mathematically that as frequency goes to 0, wavelength goes to infinity, and vice versa, but we don't know what physically is the shortest or longest possible time or distance.
I agree that the specific question about the universe is in the realm of physics, but the one I responded do, as worded, seemed broader. We've had similar discussions such as "does infinity exist in the real world?" IMO, it is a useful descriptive tool, but the question leads to more problems than answers and is better left go.
Right. This is a commonly argued example that I just find so unnecessary. Many/most models assume infinitely divisible - whatever - but I see no real value in a debate over whether, for example, the infinitenumber of points on a ruler is physically "real". More often than not, this leads to misunderstandings such as Zeno's paradox.
It would be remiss to not mention here the name Georg Cantor who showed there are infinitely many kinds of infinity. He has pre-worried about some of this for you. Wrap your head around that...here's a start:
https://www.britannica.com/science/transfinite-number
His primary works are relatively approachable without too much pain.
It could be if we regard the space-distortional effects of mass as part of what is on a universal scale a mere local phenomena set. We don't know, for example, whether the universe itself is a finite or infinite Euclidean or non-Euclidean space, inside which everything so far observable to us is a mere speck.
Hi sysprog:
I think the confusion is between (a) the absence of a limit, or (b) having a infinite value for a property. In the universe example, the size (e.g volume) is either infinite or it is a finite value (possibly changing over time). For a photon, its frequency and its wavelength are never infinite (and also never zero). Do you get the distinction?
Regards,
Buzz
The basic point of calculus is dealing with continuous change by incorporating infinities/infinitessimals. It would be hard to find a non-steady physical process that doesn't have to deal with infinity in its modeling.
Infinity is often regarded as way too exotic/mysterious and we're seeing a lot of that in this thread. That was largely the point of my first post.
russ_watters said:
The basic point of calculus is dealing with continuous change by incorporating infinities/infinitessimals. It would be hard to find a non-steady physical process that doesn't have to deal with infinity.
Hi russ:
I get that the math deals with infinities. From many discussions here on the PF it has been made clear that in a small space in which some point has an infinite value for some property, such a point is called a singularity, and within a small space around the singularity it is said that the mathematics does not apply to the physics. It is in this sense that I am trying to make the point that aside from the possibly infinite size of the universe, there are no possible infinity values for physical properties.
Regards,
Buzz
Buzz Bloom said:
...I am trying to make the point that aside from the possibly infinite size of the universe, there are no possible infinity values for physical properties.
I would think any property that has a zero value can have an inverse property with an infinite value, even if not always named/defined/useful. E.g., resistivity/conductivity.
Hi sysprog:
I have underlined "know" in the quote. This is to highlight what I understand to be a fundamental concept regarding all of science. The point is that "know" is a misleading word to use about science. In practice it has a usage meaning that is quite different from what is commonly intended as its meaning. In science a "fact" is believed to be true with a high degree of confidence, but also with the understanding that it is possible that at some future time (multiply reconfirmed) an observation with show that the fact is not true, or at least is not completely true. One excellent example from history is Newtonian mechanics.
A commonly used example of this understanding is that when a value is measured, or calculated from other measurements, an error range is also given. (See for example the values in the paper I cited in post #6.) The value and its error range allows a reader to calculate a probability that the actual value is in some specified range. I did that calculation in post #6.
So, this is what I believe that I know at the present time.
Based on the data described in the cited document, I know that the probability is ~1/3 that the universe is finite and ~2/3 that it is infinite.​
From my perspective this is qualitatively and scientifically different than, "We don't know, for example, whether the universe itself is a finite or infinite."
Regards,
Buzz
