Is Infinity Possible Within Our Finite Universe?
  • Context: Undergrad
  • Thread starter Thread starter pelletboy
    Infinity
76 replies · 23K views
russ_watters said:
Any property that has a zero value has an inverse property with an infinite value. E.g., resistivity/conductivity.
Hi Russ:
Thank you. You make a good point. I understand that it is commonly said that at some very cold temperatures the resistivity of some material becomes zero. (I.e., superconductivity.) If that is true, then that is a good and useful example, and I will need to adjust my perspective. Just a few questions to clarify my understanding.
Is it "certain" that the the resistivity becomes zero rather than just a very small positive value.​
Is there any substance and condition with zero conductivity?​
Regards,
Buzz
Astronomy news on Phys.org
Buzz Bloom said:
So, this is what I believe that I know at the present time.
Based on the data described in the cited document, I know that the probability is ~1/3 that the universe is finite and ~2/3 that it is infinite.
From my perspective this is qualitatively and scientifically different than, "We don't know, for example, whether the universe itself is a finite or infinite."
Fair enough; however, I wasn't using 'know' in the sense of epistemic certainty, either. In my opinion, if in future we know whether space as we experience it is or is not curved enough (and does or does not have other characteristics sufficient) to make it topologically closed, while that would be a very significant piece of new knowledge, and would weigh strongly in favor of a finite theory, would not ipso facto resolve the question of finiteness or infiniteness of space, in any of the senses of 'know' that you have referenced.
Buzz Bloom said:
Hi russ:
I get that the math deals with infinities. From many discussions here on the PF it has been made clear that in a small space in which some point has an infinite value for some property, such a point is called a singularity, and within a small space around the singularity it is said that the mathematics does not apply to the physics. It is in this sense that I am trying to make the point that aside from the possibly infinite size of the universe, there are no possible infinity values for physical properties.
Regards,
Buzz
We know that the speed of light is finite, and we also know with high precision what its speed is, but we don't know its maximum frequency, or even for sure that it has a maximum frequency, although I think that we may learn in future that there is in fact physically a finite maximum frequency, and minimum time interval, and minimum distance, and to some degree of precision what those physical limits are.
Buzz Bloom said:
It it "certain" that the the resistivity becomes zero rather than just a very small positive value.
I think it's exactly zero with superconductivity, but I'm not sure.
Another example: Light transmittance/absorbance. AKA Beer's law:
https://teaching.shu.ac.uk/hwb/chemistry/tutorials/molspec/beers1.htm
Incidentally, I've been using Beer's Law totally incorrectly.
Buzz Bloom said:
Do you know of any other physical context in which it is uncertain about infinite or finite?
Conditions at ##r=0## in a Schwarzschild black hole? It's a reasonable conjecture that some other physics is involved at sufficiently small values of ##r## to keep everything finite, but that is certainly not observationally confirmed and there is no compelling candidate theory.
Buzz Bloom said:
I think the confusion is between (a) the absence of a limit, or (b) having a infinite value for a property.
Much of the problem here is in the informal English-language term "having an infinite value", which is somewhere between too vague to reason accurately with and just plain meaningless. Infinity is not a value (unless you happen to be an IEEE 854 nerd - irrelevant here) so anyone who is using that phrase is necessarily saying something else... and this is one of the times when the mathematicians' insistence on rigor produces better results than the physicists' lawless coercion of the math.
Nugatory said:
It's a reasonable conjecture that some other physics is involved at sufficiently small values of rr to keep everything finite, but that is certainly not observationally confirmed and there is no compelling candidate theory.
Hi Nugatory:
Have two questions regarding the quote.
1. Would it be correct to say that it is impossible to observe any phenomena inside the event horizon?
2. Is it theoretically possible for there to be a compelling theory? That is, what could make a theory about what goes on inside the event horizon compelling?
Regards,
Buzz
If you dive in, you can observe. You just can't report back.
Hi Nugatory:
In what way is the following assertion "too vague to reason accurately with and just plain meaningless"?
Assuming that (a) the GR models of the universe are correct, and (b) that future astronomical data results in a mathematically correct calculation that the average curvature of the universe is positive with a confidence of 99.99%, it would then be also be known with a confidence of 99.99% that the volume of the universe is a value that is an infinite number of cubic meters.
Regards,
Buzz
Hi jbriggs:
Thank you for the insight. I will change my question to take your observation into account.
Would it be correct to say that it is impossible to observe from the outside any phenomena inside the event horizon, and also from the inside any phenomena happening closer to the center of the black hole than you are?
Regards,
Buzz
Buzz Bloom said:
Hi Nugatory:
Regards,
Buzz
Putting a mathematical hat on, I'd be more comfortable saying that we would have high confidence that there are subsets which have more than any specified finite volume. [We would have to nail down with some precision what sort of subsets we had in mind and what volume measure we'd use].
That avoids the need to treat "infinity" as a value.
[rant]
I think that mathematicians should accept some of the responsibility for non-rigor; for example, treating the infinitesimal as non-zero when it's among the infinity of infinitesimals being summed, and then treating it as exactly zero when it's being disregarded at the asymptote, is formally inconsistent, and leads to absurdities that offend both rigorous and non-rigorous understanding, such as saying that having zero probability is not the same thing as being impossible, but impossible things are among those which have zero probability, and insisting on using zero to designate both of those kinds of zero without acknowledging that there must be more than one meaning in mathematics for zero, that zero in fact means one of the numbers on the continuum from the negative infinitesimal to the positive infinitesimal inclusively, with what is ordinarily meant by zero being the midpoint of that interval, and what is meant by zero in the statement 'the probability of choosing a rational number at random from within any interval within the reals is zero', is actually some number greater than the midpoint of the interval from the negative infinitesimal to the positive infinitesimal, whereas the impossible has a probability which is not even infinitesimally greater than zero, and so has what may be called a 'strictly not greater than zero' probability.
[/rant]
Hi jbriggs:
I may be mistaken, but it seems to me to be impossible to define any such subset without saying either (a) "the subset is infinite in some appropriately defined dimension, or (b) the length value of some dimension is greater than any finite number.
Would it be satisfactory to you saying, "The volume of a GR universe with positive curvature is greater than any finite volume"? This avoids "infinite" by using instead a definition for infinite.
Regards,
Buzz
sysprog said:
It's common knowledge that there are infinities in the mathematics that describe physical phenomena. We don't know whether anything physical is actually infinite. Your post questioned why there appeared to be a fixation on extension of space as to whether it is finite or infinite, and I presented an example of similarly unknown matters on the smallness scale as distinguished from the largeness scale; just as we don't know whether the universe is infinitely large, we don't know whether distances or durations can be infinitely or infinitesimally small.
Then this is an issue that is not falsifiable, and thus, a topic in philosophy. Have fun going around in circles!
Zz.
"Compelling" is a matter of opinion and aesthetic preference, but I'd take as an operational definition that a theory is compelling if only a crackpot would argue, in the absence of a well-reasoned alternative, that we shouldn't be applying it.
I personally would not hesitate to trust classical E&M (applied within a sufficiently small region in a free-fall frame) on either side of the event horizon... for the same reason that we were willing to trust it to work on the far side of the moon before the era of space-travel. True, it hasn't yet been tested in that domain, but only a total crackpot would have suggested that it wasn't applicable and in that sense the theory was compelling.
We don't have a theory that as convincingly extends to extreme densities and pressures... but there's no reason why such a thing couldn't be discovered tomorrow.
Zz.
A theory that a particular something is infinite may well be falsifiable. We know that some things once theorized to be infinite are in fact finite, for example, the speed of light. Similarly, we might in future learn of a minimum distance, a minimum time interval, and a consequent maximum frequency of light. I think we may not ever be able to prove anything physical to be infinite; however, some things may long resist every effort to prove them finite.
I think you have mistaken the notion I was describing. None of the subsets involved need be infinite.
I am suggesting something very much like a limit. We play a game. You specify a volume (one cubic meter, one cubic light year, one hundred megaparsecs cubed, a cube with each side the factorial of Graham's number meters in length or whatever). Then I say "yes, there is a subset of the universe with at least that volume".
"For every volume V > 0, there is a subset with a volume at least that great".
That avoids not just the need to speak of infinity but also the need to speak of a numerical volume of the universe.
Edit: The above is just about definitions. I make no claim whether the universe really is or is not infinite in this sense.
Buzz Bloom said:
I would appreciate seeing an example of such physical infinities. I am guessing there may be another misunderstanding that I may be able to explain.
I find myself wondering how many directions an averaged magnetic field is oriented in as I spin a magnet (relative to something else).
"For every volume V > 0, there is a subset [of the ##\mathbb R^3## spatial universe] with a volume at least that great".
(bracketed referent added)
Clearly, if and only if the universe is infinite (not volume-bounded), you and the other player (the immortal versions) can forever keep playing this game. But if it's finite, you'll at some point be blocked from completing your next turn, unless the last volume specified by the other player and acceded to by you were to be the actual finite limit, at which point the game would be concluded, unless the size of the universe were to increase.
I don't see how how it accomplishes either of these. The game progressively increases the lower volumetric bound of the hypothetical ##\mathbb R^3## spatial universe, but it doesn't eliminate the consideration of whether there is physically an upper bound to the volumetric size. In ordinary vernacular, if there is, the universe is finite, and if not, it isn't.
Me neither. :oldwink:
jbriggs444 said:
There is no progression. The question is which player has a winning strategy.
The progression I envisioned would be that each volume magnitude proposed by player 1 and acceded to as a lower bound by player 2 would be greater than that on the previous turn.
As to the winning strategy question, the second player always gets to make use of the first player's efforts, and gets to use the 'greater than or equal to' property to ensure that he is never wrong unless the first player has already erred.
Citing the 'high confidence' conjecture from your post ...
... we would have high confidence that there are subsets which have more than any specified finite volume. [We would have to nail down with some precision what sort of subsets we had in mind and what volume measure we'd use]
... you appear to be postulating a universe whose size is at least countably infinite, wherein there would be no winning strategy for such a game, but in the case of a finite universe, the advantage would be to the second player, who would always come out with at least a draw.
There are no turns. You get one go.
That's an arbitrary and unwarranted constraint.
jbriggs444 said:
Multiple turns is unnecessary.
In that case, my earlier answer (from post #51) seems sufficient to me:
Looking at the case in which player 1 specifies 1 stere (##1m^3##) as the volume, player 2 wins, for any reasonable implementation of your earlier proviso:
Assuming that you aren't just being facetiously or smugly pedantic about expositing the idea that if the universe is volumetrically finite, it is apt to be much larger than any finite number we could specify, I don't see much of a point to your game.
jbriggs444 said:
The point is to produce a definition of "infinite" which does not use the term "infinity"
I don't see how or why that's helpful. There are many such definitions. For example, to specify infinity iterations, one could say: the number of iterations that will occur before the following program halts:
Code:
10 goto 10
What's wrong with posing the question 'does the universe have infinite volume?'?
Code:
10 goto 10
A course in real analysis might be of use.
hutchphd said:
It would be remiss to not mention here the name Georg Cantor who showed there are infinitely many kinds of infinity. He has pre-worried about some of this for you. Wrap your head around that...here's a start:
https://www.britannica.com/science/transfinite-number
His primary works are relatively approachable without too much pain.
It bears reiteration that Einstein and fellow scientists had the benefit of German mathematician Georg Cantor's development of set theory. Understanding sets, particularly construction and metrics, answers the basic question asked in this thread.
I don't see how or why that's helpful. There are many such definitions. For example, to specify infinity iterations, one could say 'the number of iterations that will occur before the following program halts'
Code:
10 goto 10
Please explain why.
