Is Lifting and Dropping a Weight Considered Doing Work?
  • Thread starter Thread starter Reverie29
    Gravity Work
1 reply · 6K views · last reply
Reverie29
I feel like I'm missing something, specifically in regard to the total amount of work. Can someone set me straight?
Suppose you lift a heavy weight from the floor to high over your head and let it fall back to the floor. An observer says you did no work because it wound up in its original position. You disagree. Who’s right?
W = F*d
Work is equal to force * distance, or in other words, the amount of force exerted over a certain distance. Work is also a scalar quantity, which makes the direction irrelevant to the problem (there are no negative or positive signs indicating the direction). All scalars are treated as positive values. Although the weight winds up in the same position, work is still done. Therefore, the total amount of work done is equal to the weight of the weight multiplied by the distance it is lifted up, in addition to when it is allowed to fall back to the floor. However, when it is lifted up, the person lifting the object is doing work. When it is left to fall, the person is no longer doing work and gravity does work pulling the object back to the ground.
Hi Reverie29,
W = F*d
The directions of the force and displacement are very important, as work can be a negative quantity. For constant forces, the work done by a force F is
[tex] W=Fd\cos\theta[/tex]
where [itex]\theta[/itex] is the angle between the directions of F and d.
The question only asked about the work that you did on the box, and I believe you got that correct.
But to add a bit to what you have written: since the block has zero kinetic energy at the beginning and ending of the motion, the total amount of work done on the block is zero. You are right that the person does positive work on the box while lifting it up, and gravity does positive work on the box while the box falls. So what else does work on the box, to make the total work be zero?
