DaveC426913
2025 Award
- 24,659
- 9,027
Yes. Google "Einstein rings" and "gravitational lensing".smokeee77 said:I can visualize the spacetime model as a sheet stretched out with large depressions formed by the stars, ect. In this model I can see how the path of light would dip from the plane with the curve created by a depression, causing the light to essentially bend to follow the spacetime model.
...and should cause an observer a mirage of some sort.
Don't confuse refraction through a medium with bending of space-time. While they may seem similar, they are not the same things. That is where your common sense will get you into trouble.smokeee77 said:For the same reason you see a mirage of sorts when light changes meduim. Such as observing a pencil sticking out of a bowl of water. Which to the observer, the light(pencil) appears to bend.
If lights' speed doesn't change; then the light must be traveling a longer distance through the denser meduim. Just as it appears to do near a celestial body.
This seem more like common sense once I add in the right variables.
