Is Lorentz Contraction Indistinguishable from Standard Relativity?
389 replies · 58K views · last reply
cfrogue said:
Are you arguing that the ships will be at a distance d' > d of the original launch frame distance after the acceleration ceases?
In the non-inertial frame I defined, yes.
cfrogue said:
If so, you have produced a paradox.
How?
cfrogue said:
The paper focuses on the accelerating frame and an instanteneous at rest frame.
Again, I didn't see anywhere in the paper where they referred to an accelerating frame. Can you provide a quote, or point to an equation that you think involves quantities measured in an accelerating frame?
cfrogue said:
This is why discussion occurs.
So, based on this paper, can you explain the Bell position and how it is consistent with this paper?
Or, are they logically inconsistent?
Bell's argument is logically consistent with the argument in the paper.
Let's start in the launch frame. In that frame we know that Maxwell's equations hold. Maxwell's equations tell us the electric field for an electric charge that is stationary in the launch frame, as well as one that is moving in the launch frame.
The field of a moving charge is "flattened" compared with the field of a stationary charge. This can be seen from http://farside.ph.utexas.edu/teaching/jk1/lectures/node26.html, Eq 265. It can also be obviously seen pictorially from http://www.cco.caltech.edu/~phys1/java/phys1/MovingCharge/MovingCharge.html by comparing the "linear" case (ie. constant velocity) with v=0 and with v=0.9.
Because of this flattening, if we imagine that electrical forces are one of the things that hold particles in a string together, we may imagine that Maxwell's equations predict that the equilibrium length of a moving string is shorter than that of a stationary string. If this is correct, then all we have made use of is Maxwell's equations in the launch frame. This is not totally correct because classical electrostatics does not predict a unique equilibrium configuration, and also because a string is held together not just by classical electrical forces, but also by quantum mechanics (eg. Pauli exclusion principle, the uniqueness of the ground state) and not just classical electrostatics. With these additional assumptions, then we can predict that a string's moving equilibrium length is shorter than its stationary equilibrium length.
An essential part of these heuristics was the flattening of the electric field of a moving charge using only Maxwell's equations in the launch frame. So a crucial question in seeing if the calculations in the launch frame and in other frames match up is: is this flattening predicted by using Maxwell's equations in the rest frame of the moving charge, then Lorentz transforming to the launch frame? The answer is yes.
cfrogue said:
Al68 said:
1) and 2) above are not generally true. The distance between the ships in this case being constant in the launch frame is specific to the scenario, just to make the point simple.
The accelerating ships are not an inertial frame and so the above logic does not apply.
Huh? That makes no sense whatsoever. I was referring to your statement that "1) The distance between objects in an inertial frame is constant and it is not the case that distance is a coordinate-dependent." and "3) If there is an accelerating frame, then the frame will experience metric expansion in the direction of acceleration. However, the launch frame will calculate a constant distance for objects in the accelerating frame." None of those statements are true generally for obvious reasons.
Al68 said:
The distance between the ships being length contracted (constant instead of increasing as in the co-moving frame) in the launch frame is due to relative velocity, which increases with time. Greater relative velocity equals greater contraction, which is why, since it is stipulated that the distance between the ships remains constant in the launch frame, it must increase with time in the co-moving frame.
I do not agree with this.
The integral for the solution only involves the accelerating frame and the instantaneous at rest frame, S'.
The launch frame is not part of the decision process in this paper.
http://arxiv.org/PS_cache/arxiv/pdf/0906/0906.1919v2.pdf
The launch frame exists as a separate entity that only concludes the distance does not change between the ships but does not participate in the integral for the solution.
Seriously? You are now objecting to anyone referring to the launch frame? None of your response even remotely explains why you "do not agree with this".
Of course the ships will be farther apart in a co-moving inertial frame than in the launch frame. Why on Earth would they "snap back" to their original distance in any frame just because they kill their engines? Magic?
How?
Because, the distance between the accelerating frame will exceed that of the launch frame.
Yea, it does not directly refer to it but does infer it.
But, what do you think this means?
We denote the spaceships as L and R, each having acceleration a(t) in the positive x direction in system S
You and I are not communicating.
You cannot refute 1 and 2, if so do that please.
Al68 said:
Seriously? You are now objecting to anyone referring to the launch frame? None of your response even remotely explains why you "do not agree with this". Of course the ships will be farther apart in a co-moving inertial frame than in the launch frame. Why on Earth would they "snap back" to their original distance in any frame just because they kill their engines? Magic?
I showed the math, you show yours.
More directly, if you support the proposition that the accelerating ships will retain their > d positions after the acceleration stops, you will find that the launch frame will completely disagree with your assessment since the ships maintained their distance.
So, where is your math to reconcile this?
What's paradoxical about that? The distance in the non-inertial frame began to grow larger than d from the moment they began accelerating. Anyway, you don't even need to consider a non-inertial frame here; just using the Lorentz transformation and their x(t) functions in the launch frame, you can easily show that the distance between them in other inertial frames can be larger than d. Different inertial frames always disagree on the distance between a pair of objects, just like they disagree on the time between a pair of events, that's just a feature of how the Lorentz transformation works.
How so? Do you think any of the variables in the equations they use refer to quantities in a non-inertial frame?
That quote is from p. 4, and if you look at the context it's clear that S is what we have been calling the "launch frame". Do you disagree?
Try reading the proposed scenario. The constancy of the distance between the ships in the launch frame is not a natural occurrence but a stipulation in the set up of the problem.
Apart from that there is a logical inconsistency in what you say. You say the ships will "snap back" to the original distance. This, apart from being ridiculous, assumes that they acquired a greater distance through the acceleration, which although true, refutes your argument for constancy.
Matheinste.
Matheinste.
Fine, I will argue my point from SR here.
Any logic that assumes the ships will have a greater distance after acceleration stops from the accelerating frame will contradict the launch frame that sees the distance as constant and then contracted by the normal LT calculations. You must have logic and equations to support this position.
I want to see all this.
What do you mean when you say the launch frame "sees the distance as constant and then contracted by the normal LT calculations"? The launch frame sees the distance as constant at all times, even after the acceleration stops, so why do you say "then contracted"? Do you mean the distance seen in the launch frame once the ships stop accelerating is contracted relative to the distance between them in the ships' new inertial rest frame? Of course that's true, it's why the distance is greater in the ships' rest frame!
I guess cfrogue's confusion comes from something like:
1) In SR it is not moving objects that Lorentz contract, but space itself.
2) The distance between the ships is moving, so it should Lorentz contract, since space itself contracts.
3) Yet this moving distance remains the same, thus we have obtained a contradiction.
Well, something must be wrong above. I myself never use this space itself contracts or that time itself dilates, so I don't really have an intuition where the error occurs, but maybe cfrogue can confirm that I have summarized his confusion correctly, and someone else can write the correct version of the above statements 1-3.
Why, so you can ignore them.
Matheinste.
Supporting that proposition is equivalent to supporting the proposition that the ships retain their velocity relative to earth, since their "> d positions" are due only to relative velocity.
Maybe this will be more clear:
1) The distance between the ships remained constant in the launch frame.
2) The distance between the ships increased in the new co-moving ship frame.
3) The distance between the ships after acceleration is shorter in the launch frame than it is in the co-moving frame.
The math is simple:
Distance between the ships in launch frame equals distance between the ships in co-moving frame times sqrt(1-v^2/c^2). It's that simple.
The distance between the ships will be different in the launch frame than in a co-moving frame as long as there is relative velocity between them.
If cfrogue wants some more detailed math, here it is:
Say that in the launch frame, the left ship is at position x=0 at time t=0, and the right ship is at position x=d at time t=0. At t=0 they both begin to accelerate with constant coordinate acceleration a in the launch frame, and they both stop accelerating at time t=t1 in the launch frame. Then prior to t1, v(t) for both ships will be given by v(t) = a*t, and x(t) for the left ship will be given by x(t) = (1/2)*a*t^2 while x(t) for the right ship will be given by x(t) = (1/2)*a*t^2 + d. So at time t1 when they stop acceleration, both ships will have a velocity in the launch frame of a*t1, and the position of the left ship will be (1/2)*a*t1^2 while the position of the right ship will be (1/2)*a*t1^2 + d. After that they both move at constant velocity v1 = a*t1, so after t1 x(t) for the left ship will be given by x(t) = v1*t - v1*t1 + (1/2)*a*t1^2 while x(t) for the right ship will be given by x(t) = v1*t - v1*t1 + (1/2)*a*t1^2 + d.
Now we can use the formula I derived in post 134 of the twins thread, which tells us that if we pick the event E of the left ship stopping acceleration, and pick another event E' on the worldine of the right ship which is simultaneous with E in the ship's own inertial rest frame, in the launch frame where the right ship is moving at speed v1 and was at a distance of d from E when it happened, the coordinate time between E and E' must be (d*v1/c^2)*gamma^2, so if E occurred at time t1, E' occurred at time t = t1 + (d*v1/c^2)*gamma^2. Plugging this time into the x(t) for the right ship, E' must have occurred at a position of x = v1*[t1 + (d*v1/c^2)*gamma^2] - v1*t1 + (1/2)*a*t1^2 + d = (d*v1^2/c^2)*gamma^2 + (1/2)*a*t1^2 + d.
So, coordinates of E in the launch frame:
x = (1/2)*a*t1^2, t = t1.
Since v1 = a*t1, the coordinates of E can be rewritten as:
x = (1/2)*v1*t1, t = t1
Coordinates of E' in the launch frame:
x = (d*v1^2/c^2)*gamma^2 + (1/2)*a*t1^2 + d, t = t1 + (d*v1/c^2)*gamma^2.
Since v1 = a*t1, the coordinates of E' can be rewritten as:
x = (d*v1^2/c^2)*gamma^2 + (1/2)*v1*t1 + d, t = t1 + (d*v1/c^2)*gamma^2
And remember, E was an event on the worldline of the left ship--the event of it stopping its acceleration--and E' was an event on the worldline of the right ship--the event that happened simultaneously with E in the right ship's inertial rest frame once it finished accelerating. So, now we can figure out the x' and t' coordinates of E and E' in the rest frame of the ships after they stop accelerating, using the Lorentz transformation, and the difference in x' coordinates of the two events will be the distance between the ships in their final inertial rest frame once the left ship stops accelerating.
The coordinates of E in the ship's final inertial frame are:
x' = gamma*((1/2)*v1*t1 - v1*t1) = gamma*(-1/2)*(v1*t1)
t' = gamma*(t1 - (1/2)*t1*v1^2/c^2)
The coordinates of E' in the ship's final inertial frame are:
x' = gamma*([(d*v1^2/c^2)*gamma^2 + (1/2)*v1*t1 + d] - v1*[t1 + (d*v1/c^2)*gamma^2])
= gamma*(d + (-1/2)*v1*t1)
t' = gamma*([t1 + (d*v1/c^2)*gamma^2] - v1/c^2*[(d*v1^2/c^2)*gamma^2 + (1/2)*v1*t1 + d])
= gamma*(t1 + gamma^2*(d*v1/c^2)*[1 - v1^2/c^2] + (-1/2)*t1*v1^2/c^2 - d*v1/c^2)
= gamma*(t1 + [1/(1 - v1^2/c^2)]*(d*v1/c^2)*[1 - v1^2/c^2] - (1/2)*t1*v1^2/c^2 - d*v1/c^2)
So, you can see here from direct calculation that both E and E' do have the same t' coordinate in their final rest frame, regardless of whether you trusted my derivation in post 134 of the twins thread. You can also see that the difference in x' coordinate between E and E' is gamma*d, so this must be the distance between the two ships in their final rest frame, which is greater than the distance between them in the launch frame by a factor of gamma.
That was not the issue.
Does the distance remain after the acceleration.
If so, then the accelerating frame will believe the distance has grown and the launch frame after the acceleration will believe the distance has contracted as d/gamma.
But, the launch frame and prior accelerating frame will disagree about this d.
Actually, I am concerned about the distance between the ships after the accelerations stops from both POV's.
I agree with you
The math is simple:
The co-moving frame is gone after the acceleration discontinues.
Besides, one does not need a co-moving frame after acceleration is done since the two ships will be in the same frame at that point anyway.
Now, the question is using only ships1 and ship2, is the distance between them > d once the acceleration discontinues from their perspective?
I am confused. The SR acceleration equations give the following for the launch frame.
v(t) = a t / sqrt[ 1 + (a t)^2 ]
x(t) = 1/a [ sqrt( 1 + (a t)^2 ) - 1 ]
In every inertial frame, as well as the non-inertial frame I defined, the distance at the moment the last ship stops accelerating (since in many frames they do not stop accelerating simultaneously) will also be the distance at a later time when they are traveling inertially.
Huh? Why do you think answering yes to "does the distance remain after the acceleration" would imply the launch frame thinks the distance contracts? Again, in any of these frames, the distance at the moment the last ship stops accelerating is the same as the distance later when both ships are moving inertially, so since the launch frame sees the distance as d throughout the acceleration, it will continue to see the distance as d once they are both moving inertially. If you define d' as the distance between the ships in their new inertial rest frame after they stop accelerating (which is the same as the final distance between them in the non-inertial frame I defined), then it is true that the d in the launch frame is equal to d'/gamma, but no one will measure a distance of d/gamma (again assuming d is defined as the constant distance between them in the launch frame while they were accelerating).
Please don't mix your uses of the symbol d! If d refers specifically to the distance in the launch frame, then you shouldn't refer to the distance in the non-inertial frame as "this d". Anyway, it is certainly true that the final distance d in the launch frame is different than the final distance d' in the non-inertial frame, but if this is all you're saying, then again I don't see why you consider this a paradox.
cfrogue said:
I agree with you
So do you also agree that nowhere in the paper do they use any variables or do any calculations that involve a non-inertial frame?
That's for constant proper acceleration, I was assuming constant coordinate acceleration, which makes the math simpler. The Bell spaceship paradox doesn't specify anything about the detailed nature of the acceleration beyond the fact that both ships have identical coordinate acceleration at any given moment in the launch frame, so assuming constant coordinate acceleration (which implies increasing proper acceleration) is fine.
How can you do this?
The launch frame does not know a d'.
How does the launch frame conclude d'?
Because, the launch frame will not longer know the correct value to perform d/gamma.
This is simple.
I agree with you.
I do not understand what you mean with this.
d' is not measured in the launch frame! What I wrote was "If you define d' as the distance between the ships in their new inertial rest frame after they stop accelerating"
This is simple.
Frames are just coordinate systems and don't "know" anything about other frames, but intelligent beings such as ourselves can certainly relate distances in one frame to distances in another, that's what the length contraction equation [tex]l' = l/\sqrt{1 - v^2/c^2}[/tex] does after all.
Do you understand the difference between coordinate acceleration and proper acceleration? Coordinate acceleration is just the rate the coordinate velocity is changing (derivative of v(t) in that frame), and coordinate velocity is just the rate the coordinate position is changing with coordinate time (derivative of x(t) in that frame). Proper acceleration at any given moment is defined as an object's coordinate acceleration in the object's instantaneous inertial rest frame at that moment, not in any other frame. If an object has constant proper acceleration, its coordinate acceleration in the launch frame is decreasing, as you can see from the http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html equation v = at / sqrt[1 + (at/c)^2]. But there is nothing in the statement of the Bell spaceship problem that says they must have constant proper acceleration, it only says their coordinate acceleration must be identical.
Here, instead of all this background noise, do you believe this extra distance holds between the ships after the acceleration discontinues yes or no.
In any frame where the distance increases as they accelerate (i.e. not the launch frame), the distance will stay increased after the acceleration discontinues, yes. I already told you that in post 290:
That what Max Tegmark was talking about the 'mere labels': when we say
F=ma
We think that Force F equal to (m)*** multiplied by (a)cceleration.
The same formula
Ы=Я*Ж
wont tell you anything
But in TOE if won't be important.
Of course the distance will be different for different frames. That's what length contraction is.
(1) Constant distance between the ships in the launch frame is stipulated in the scenario.
(2) Also stipulated is that the velocity of the ships will increase relative to the launch frame.
(3) The ratio (gamma) between "ship frame distance" and "launch frame distance" increases with velocity, ie "Ship frame distance" > "launch frame distance" for any velocity > 0.
1+2+3= Distance between the ships in the ships' final inertial frame is greater than the distance between the ships in the launch frame.
Absolutely, assuming that d is the distance between the ships in the launch frame.
For example, if the ships are 600 km apart in the launch frame, accelerate to 0.8 c while maintaining the 600 km distance in the launch frame, then the distance between the ships in their inertial frame after they cut their engines will be 1000 km.
Then the launch frame cannot correctly calculate LY once the acceleeration is finished since the launch frame still has the original d as the distance between the ships.
Then how does the launch frame correctly apply LT after the acceleration.
Should the launch frame calculate a new d and abandon the old d?
In the same way as during the acceleration, based on the current speed of the rockets.
Isn't d constant?
No, because the distance between the ships from the launch frame does not agree with the ships assessment.
