Is mass a measurement of energy?
  • Context: High School
  • Thread starter Thread starter Cody Richeson
    energy mass measurement
The discussion revolves around the relationship between mass and energy, questioning whether physical objects can be considered as clumps of energy and if energy can be measured as mass. Participants explore theoretical implications, definitions, and the nature of energy in relation to physical objects, momentum, and mass-energy equivalence.
  • Some participants propose that physical objects are essentially clumps of energy and that energy is measured as mass, questioning if objects become more massive as they receive energy.
  • Others argue that energy is not a substance but a property of particles and fields, suggesting that it lacks physicality similar to temperature and charge.
  • A participant describes energy as a fluid-like property rather than a clump, using an analogy involving power transmission and the Coriolis force.
  • Another viewpoint emphasizes that objects gain momentum and energy, not mass, when pushed, referencing the equation E² = m²c⁴ + p²c² to clarify the relationship between energy, mass, and momentum.
  • Some participants challenge the premise that energy can be equated with mass, citing examples such as light, which has energy but no mass.
  • A mathematical approach is presented to quantify the mass of light using photon energy and mass-energy equivalence equations, though this is met with disagreement from other participants.
Participants express multiple competing views regarding the relationship between mass and energy, with no consensus reached on whether energy can be considered as mass or if they are fundamentally different concepts.
Some claims depend on specific definitions of energy and mass, and there are unresolved mathematical interpretations regarding the equations presented. The discussion also highlights the complexity of the concepts involved, particularly in the context of relativistic physics.
Cody Richeson
That's pretty much it. Are physical objects essentially clumps of energy, and that energy is measured as mass? And do objects become more massive as they receive more energy through push?
Energy is not a substance, it is a property of particles and fields.
When you say it is a "property of particles and fields," what exactly is being literally described? Is energy one of those fundamental abstracts that lacks an underlying framework of smaller constituents? Is it one of those concepts that is without physicality, like temperature and charge?
Yes, it seems to be so. Energy is physical object that is not a clump, but more like fluid. While a physical object is energy in clumped state.Like, for example:
A power plant, burning coal lumps, is located at north pole, a city is at equator, power lines connect the plant and the city. When power is transmitted, the power lines droop to the west, because of the Coriolis force that is affecting the stuff flowing from the pole to the equator.
No ot isn’t. It is a property of matter and radiation and that is useful in describing those. It is not even a Lorentz invariant property so it is meaningless to state ”I have X energy”.
How do we correctly describe 1000 J of energy going into a battery?
Maybe: 'Battery's energy property becomes larger'. Or 'battery becomes more energetic'.
As the battery becomes more massive in that process, I like to think the energy has mass. When energy has mass it approximately obeys Newtons law's. So it obeys same laws as matter.And how do we correctly understand the my power line example in post #4? Particularly in case of direct current?
Like this maybe:
There is an electric field and there is a Poynting-vector, and nothing is moving, when the vector points one way the lines hang one way, when the vector point the opposite way the lines droop the opposite way, and this has nothing to do with Coriolis-force?
Not exactly. Objects gain momentum and energy, not mass, when they are pushed.
The main equation relating them is
##E^2 = m^2 c^4 + p^2 c^2##
where E is energy, m is mass, p is momentum, and c is a unit conversion factor relating distance and time.
Often this is simplified to ##E = mc^2## for a case of an object at rest. But if you push an object, it is no longer at rest. Pushing is another way of saying, adding momentum to. This increases p, and by the equation must also increase E when m is constant.
Sometimes you will see statements saying mass and energy are equivalent, but as we have seen, this only makes sense for objects at rest.
Light has energy, but it has no mass. So already your premise has been shown to be false.
Zz.
correct me if I am wrong but If you combine the following equations:
photon energy: E = ħc/λ
mass–energy equivalence: E = mc2
you can quantify the mass of light as: m = ħ/λc
You're wrong.
Vanadium 50 said:
You're wrong.
would you care to correct me?
Because the correct formula (already given in post #7) is ##E^2 = m^2 c^4 + p^2 c^2##
See post #7 for the correct formulation.
  • · Replies 27 ·
  • · Replies 28 ·
  • · Replies 55 ·
