Is the Alcubierre Warp Drive possible?
The discussion centers around the feasibility and implications of the Alcubierre warp drive, a theoretical concept that suggests the possibility of faster-than-light travel through the manipulation of spacetime. Participants explore various aspects of this idea, including the necessity of exotic matter, the mathematical foundations, and the potential consequences for causality.
  • Some participants express skepticism about the Alcubierre warp drive, suggesting it may be "junk science" and emphasizing the lack of detected exotic matter required for its operation.
  • Others acknowledge that while the mathematical solutions to the Einstein field equations (EFE) may be valid, they likely have no physical realization due to the instability of exotic matter.
  • There is a discussion about whether the warp drive allows for faster-than-light (FTL) travel, with some arguing that it does not result in FTL travel in a local reference frame, while others suggest it could lead to FTL effects in a broader context.
  • Participants note that the existence of FTL travel could lead to causality violations, raising concerns about the implications of such travel on the nature of time and causality.
  • Some argue that the term "FTL" is misleading, suggesting that the warp drive operates within a curved spacetime that does not conform to traditional notions of FTL travel.
  • Several participants engage in a nuanced discussion about the implications of closed timelike curves and whether they represent true causality violations or merely challenge common intuitions about causality.
Participants do not reach a consensus on the feasibility of the Alcubierre warp drive or the implications of its theoretical framework. Multiple competing views remain regarding the nature of FTL travel, the role of exotic matter, and the consequences for causality.
Limitations include the dependence on speculative physics regarding exotic matter, unresolved mathematical steps in the discussion, and varying interpretations of causality in curved spacetime.
  • #61
PeterDonis said:
Do you?
https://en.wikipedia.org/wiki/Causality
PeterDonis said:
Then you are contradicting yourself, since you said:
"I'm stipulating, that a light ray could reach B from A, not going throuth the warp bubble."
That referred to points A and B in space, not in spacetime (you already confused that in #45). I have to admit it was not a good idea to reuse the same symbols for events in a later post. In order to fix that, let me explain it again with a better notation:
Let's say we have four points A, B, C, D in space (not spacetime!). The points form a rectangle. The long edges A-D and B-C have a length of 5 LYs. The short edges A-B and C-D have a length of 1 LY. All points remain at rest in a frame of reference K.
At the time t = 0 a light signal is submitted from A to D. At the same time a spaceship starts from A to B at a speed of c/2. This is event X.
After 2 years the ship arrives at B, starts its warp engine and arrives C halve a yeat later. Than it goes with c/2 to D and arrives at t = 4.5 a. That is event Y.
The light signal (which is assumed to remain in flat space) reaches D at t = 5 a. That is event Z.
The events X and Y cannot be connected by any timelike or null paths that do not go through the warp bubble.
  • #62
DrStupid said:
Wikipedia is not a valid reference.
In any case, the word "causality" is not the important point; the physics is.
Ok, that makes it clearer what scenario you intended.
  • #63
DrStupid said:
With two events A and B, where one of them is the cause of the other, causality is violated if the order of the events is frame dependent.
Now that you've clarified your scenario, I can respond to this. Your statement is only true in flat spacetime. The spacetime in your scenario is not flat. The fact that you have a "basically flat" region in it that the light signal between events X and Y traverses does not make the spacetime as a whole flat.
What you have is a spacetime where there is a pair of events, X and Y, which (a) are connected by a timelike path (through the bubble), and (b) have a frame-dependent ordering in some "inertial" frame ("inertial" is in quotes because there are no global inertial frames in a curved spacetime, but we can construct frames that, outside the warp bubble, are "inertial enough" given the asymptotically flat nature of the spacetime--we have to stipulate some restriction on the frame because it is always possible to construct non-inertial frames with different orderings for some chosen pair of events). In flat Minkowski spacetime, this would not be possible: any pair of events whose ordering is frame-dependent in different inertial frames cannot be connected by any timelike or null path.
Your interpretation of this is that "causality" is violated in Alcubierre spacetime. But the proper interpretation of this is that your definition of "causality" is too limited, since it only works for spacetimes that satisfy a condition (the one I just described above) which Alcubierre spacetime violates. (Which just illustrates why you should not get your definitions from Wikipedia.) Since you asked for a reference earlier, if you want the definitive treatment of "causality" for general curved spacetimes, check out Hawking & Ellis, which treats the subject in exhaustive detail. They point out that there are multiple possible causality conditions on spacetimes; of those, globally hyperbolic is the strongest, and it is the one satisfied by Alcubierre spacetime, as was pointed out earlier in the thread. The brief summary in the Wikipedia article is not bad as a quick overview, but of course leaves a lot out:
https://en.wikipedia.org/wiki/Causality_conditions
  • #64
PAllen said:
It seems to me the only thing missing from Everett's paper is a more explicit demonstration that the combined metric tensor he constructs is a valid metric tensor. It would not be expected to preserve the global hyperbolicity of the one bubble metric. I would find it totally convincing if there were an argument that the candidate metric he writes in equation (10) [ confusingly using upper case G for something that is clearly meant as a metric] has the same signature everywhere. Everything else would hang together, IMO, if this were demonstrated. Continuity and such are already demonstrated (and G being symmetric is also obvious), and there are very minimal requirements to simply declaring some tensor on a manifold be treated as the fundamental tensor. Unchanging signature is the only nontrivial requirement that would not obviously hold in this case.
Thinking a little more about this, I think the above issue is dealt with in the paper, if a bit obliquely. The two bubbles are arranged to be displaced from each other, with essentially flat spacetime between them. The closed timelike curve takes a timelike path out of one bubble and into another. The non overlap of the each bubble’s contribution to the metric makes it obvious that there is no signature change issue. Thus I claim there are no substantive issues with the paper. Obviously, it passed peer review to appear in Phys. Rev. D.
  • #65
The problem I see with this reasoning is that, if the bubbles really don't overlap, then the spacetime containing two bubbles should be globally hyperbolic since the spacetime containing one bubble is. But you can't have CTCs in a globally hyperbolic spacetime.
The part I think it might be worth focusing in on is the "timelike path out of one bubble and into another". I'm not sure this is actually possible in a way that allows a CTC to form given the other restrictions involved (that the bubble's don't overlap and that spacetime is basically flat outside the bubbles).
  • #66
I don’t think this claim is true. Consider two flat topologically trivial Minkowski spaces. Cut a section of each and out them together right and you have Minkowski space with CTCs due to nontrivial topology. Everetts’s construction joins a cut of two globally hyperbolic solutions together, the cut being in the essentially flat region of each. There is no expectation this will necessarily preserve global hyperbolocity. The physical claim is that the procedure simply amounts to building two warp bubbles using exotic ingredients at different relative speed in near flat spacetime. If one is possible, why not two, arranged as described?
They discuss the timelike path from one bubble to the other in some detail.
  • #67
It is known that this can be done, but I don't think it's relevant here since Everett's solution does not appear to involve nontrivial topology.
In general there is no theorem that says what kind of cutting and joining of globally hyperbolic solutions will preserv global hyperbolicity, true. But in this specific case I think it should.
Global hyperbolicity is equivalent to the existence of a Cauchy surface for the spacetime. In flat Minkowski spacetime, any surface of constant coordinate time in an inertial frame is a Cauchy surface. In a spacetime with a single warp bubble, otherwise flat, the same should be true: any surface of constant coordinate time in a frame which is inertial far away from the bubble should be a Cauchy surface. But if this is true for one bubble, it should also be true for two bubbles that do not overlap. So the two-bubble spacetime Everett describes should also have a Cauchy surface.
I'm not disputing that a two warp bubble spacetime could be created if a one warp bubble spacetime could. The question is only about whether a two warp bubble spacetime can contain CTCs.
  • #68
I disagree with this. It is precisely the existence of two shortcuts with the right relation to each other that breaks global hyperbolicity. That is, it is the two bubbles boosted relative to each other that allow what was a Cauchy surface for one bubble to have two intersections by a causal curve, thus making it no longer a Cauchy surface.
  • #69
I'll have to work through the paper again, because I'm not really seeing how this can work. I understand the author is claiming basically this, but the paper is too sketchy for me to accept that claim at face value.
  • #70
Note that the 2 bubble CTCs only cause only 'some' partial cauchy surfaces to have two intersections with a causal curve. 'Most' partial Cauchy surfaces fail be be Cauchy surfaces because some points in the future or past of the surface have causal curves through them that don't intersect the partial Cauchy surface at all. This makes the surface fail the condition that D+ U D- U S be the whole manifold, so it is not a Cauchy surface. In this case, the CTCs created by the two bubbles will not be in this set, for most candidate Cauchy surface.
I really don't see any basis to claim that you can't join two sections of spacetimes each globally hyperbolic in such a way that the result is not. The more I think about it, the less reason I see for any objection.
Can you try to clarify why you think there should be a problem with Everett's construction?
  • #71
I'm not making this claim as a general claim; as a general claim it would be way too strong. I'm only making it in the specific case of Everett's construction.
I'm not saying there's a problem with the construction in itself. I'm questioning whether the construction Everett describes will actually contain CTCs. I need to go through the paper again and see if I can fill in the details he leaves out.
  • #72
One thing I found is that several papers published in major journals decades after Everett's paper cite it as an established, non-controversial result.
  • #73
I know it is limited to Minkowski spacetime. That's why I added above that it is only works within the spacetime that is not affected by the Alcubierre warp drive. It just means that an observer who is not aware of the bubble would conclude that causality is violated and that the spaceship travels faster than light. For some observers it would even look like the ship travels back in time. In that case it should always be possible for the ship to go all the way back and connect event X at position D with another event X' at position A with X' preceding X.
  • #74
This is a spacetime with two warp bubbles, not one. One warp bubble can only go in one direction.
  • #75
Yes, I assumed that to be obvious.
  • #76
1977ub said:
One such vehicle leaves Earth and goes to alpha centauri, arriving sooner than a photon emitted from Earth at the same moment. Also let's say you have another such vehicle leaving alpha centauri toward earth, also arriving sooner than a photon emitted at the launch event. As the two vehicles pass one another, interactions could occur which violate causality.
What if the bubble denies any ability for a photon to traverse it in the lateral direction? Then it wouldn't violate causality.
  • #77
no photon is traversing it. if it is a small unit carrying a communication at "FTL" then causality will be violated.
  • #78
Due to an egregious error in an earlier posting, I have been studying Kerr metrics. It appears (although I have doubts) that the mathematics of spinning black holes has: escapes clauses, something similar to negative energy (repulsive regions), and closed time-like orbits/areas/curves. To me, that indicates that Alcubierre type of arrangements is not excluded by GR.
So if you have a spare couple of solar systems laying around to convert to a spinning black hole...
or you can wait for the great meeting at the "great attractor"; you could see if the physics is correctly described by GR.
Really..really (??) closed timelike curves occurring naturally without new physics? I am still studying.
  • #79
Yes, but only inside the inner horizon, which is not considered a physically reasonable portion of the spacetime.
Of course it's not "excluded by GR"; the Alcubierre spacetime is a perfectly valid solution to the Einstein Field Equation. Nobody is disputing that. But this perfectly valid mathematical solution is not considered physically reasonable, just as the region of Kerr spacetime inside the inner horizon is not.
  • #80
Yes, but if the model, GR, is broken inside and somebody came up with an alternative, I would expect that the alternative would be testable in gravity wave signatures. I realize our detection is primitive so far, but one can hope for future experiments. Gravity probe B; that took a long..long time to implement.
  • #81
It's not true that you can't communicate or have to wait till the end of time; the detection of gravity waves indicate that one could probe a black hole with disturbances and detect the resulting gravity waves. A little presumptuous in terms of technology but when has that stopped dreaming?
  • #82
This is way out of scope for this thread, and indeed this forum.
  • #83
Yes, in principle this could be done, but it's going to be a while before we have the technology to throw neutron stars into black holes and watch the gravitational waves that get produced.
(Btw, it's "gravitational waves", not "gravity waves"; "gravity waves" refers to something completely different.)
  • · Replies 171 ·
