Is the Given Equality True Only for an Isosceles Triangle?
  • Topic:
  • Thread starter anemone
    Value
anemone
MHB
POTW Director
In the triangle ABC, the following equality holds:
$\displaystyle \sin^{23}\left(\frac{A}{2}\right) \cos^{48} \left(\frac{B}{2}\right)=\sin^{23} \left(\frac {B}{2}\right) \cos^{48} \left(\frac {A}{2}\right)$
Determine the value of $\dfrac {AC}{BC}$.
Hi all, the huge values of the exponents make me cringe to try to solve the problem. I want to ask if this is obvious that one of the possibilities is that the given equality is true iff the measures of both the angles A and B are equal. Is this true? That is, we're dealing with an isosceles triangle where $\dfrac {AC}{BC}=1$?
Hey anemone! (Malthe)
Let's rewrite that equation a bit.
$$\frac{\cos^{48} \left(\frac {A}{2}\right)}{\sin^{23}\left(\frac{A}{2}\right)}=\frac{ \cos^{48} \left(\frac{B}{2}\right)}{\sin^{23} \left(\frac {B}{2}\right)}$$
(Note that the denominator will not be zero if the angles are between $0$ and $\pi$.)
The left hand side and right hand side both represent the same function.
If that function is invertible (strictly monotonous) on its domain, that means that A and B have to be the same.
When we analyze that function (or graph it with Wolfram) we see indeed that it is monotonous on $(0,\pi)$ which is the range of the angle in a triangle.
So yes, it is an isosceles triangle with AC=BC.
Thanks, I like Serena...I understand what you say and I appreciate your response to my post! :)
