Is the product of two radical expressions equal to six?
  • Context: High School
  • Thread starter Thread starter anemone
The discussion centers around a problem of proving that the product of two radical expressions equals six. Participants explore the mathematical validity of the expression, its interpretation, and potential methods for proof, including the use of real versus complex roots.
  • Some participants express confusion regarding the problem, noting discrepancies with results from Wolfram Alpha, which suggests the product is not equal to six.
  • Others clarify that Wolfram Alpha treats inputs as complex values and that the real-valued root is intended in this context.
  • One participant questions the validity of the equation, suggesting that all terms except one are real and proposes interpreting the cube root with real coefficients instead of complex ones.
  • A participant presents a detailed breakdown of the left-hand side of the equation, introducing variables and relationships that may aid in proving the statement.
  • Some participants inquire about the feasibility of solving the problem without using infinite series expansions.
  • Another participant reflects on the difficulty of finding a closed-form proof, acknowledging that while computational tools can evaluate the expression, they do not provide a formal proof.
  • One participant shares a specific product of cube roots that leads to a negative value, which may impact the overall proof.
  • Several participants express anticipation for a formal solution to the problem.
Participants do not reach a consensus on whether the product equals six, with multiple competing views and interpretations of the problem remaining unresolved.
There are limitations regarding the interpretation of cube roots, particularly in distinguishing between real and complex values, which may affect the validity of the proof. Additionally, the discussion includes unresolved mathematical steps and assumptions about the nature of the expressions involved.
anemone
MHB
POTW Director
Here is this week's POTW:
Prove that $\sqrt{4+\sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}} \cdot \sqrt{8+2\sqrt[3]{19+3\sqrt{33}}+2\sqrt[3]{19-3\sqrt{33}}}=6$.
Please clarify the problem. Wolfram Alpha says this is not 6. Thanks.
I've checked with W|A and it confirms that it is really 6.
Note that W|A treats every input as complex valued and takes the principle complex root by default, while in this case the real valued root is intended. That is, we need that $\sqrt[3]{-1}=-1$ instead of $\sqrt[3]{-1}=e^{i\pi/3}$.
Thanks @I like Serena for the reply!
All the terms except
[tex](-26-6\sqrt{33})^{1/3}[/tex]
are real. I do not believe this equation holds. Should I interpret it with real coefficient -1
[tex]-(26+6\sqrt{33})^{1/3}[/tex]
not with complex coefficients, i.e.
[tex]e^{\pi i/3},e^{-\pi i/3}[/tex]
[EDIT] I got it in the post #4. Thanks.
This is just to know I got the question properly. LHS of the to be proved equation is
[tex]L:=2^{2/3}[2^{5/3}+(a-13)^{1/3}-(a+13)^{1/3}]^{1/2}[2^2+(19+a)^{1/3}+(19-a)^{1/3}]^{1/2}[/tex]
where
[tex]a=3\sqrt{33}=17.23...[/tex]
We may make use of the relations
[tex](a+13)(a-13)=a^2-13^2=128=2^7[/tex]
[tex](a+19)(19-a)=19^2-a^2=64=2^6[/tex]
For an example
[tex][2^2+(19+a)^{1/3}+(19-a)^{1/3}]^{1/2}=(19+a)^{1/6}+(19-a)^{1/6}[/tex]
Is this problem workable without infinite series expansions?
So far after spending too many hours on this I wonder if there is a doable closed form proof. Of course one can evaluate this easily with computer tools like Wolfram Alpha but proof is not the same thing. The cube roots are all irrational numbers.
I did notice that
$$\sqrt[3]{-26+6\sqrt{33}}*\sqrt[3]{-26-6\sqrt{33}} = -8$$
and $$\sqrt[3]{19+3\sqrt{33}}*\sqrt[3]{19-3\sqrt{33}}=4$$
I have tried everything. When will the proof be posted?
I am so sorry for the late reply to this POTW's thread as I have been so extremely busy with work.
Here is the solution of other and I hope that readers will appreciate the beauty of the solution as much as I do.
Let $x=\sqrt[3]{a+\sqrt{b}}+\sqrt[3]{a-\sqrt{b}}$ so that we get $x^3-3\sqrt[3]{a^2-b}x-2a=0$.
Now, let $p=\sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}$ and $q=\sqrt[3]{19+3\sqrt{33}}+\sqrt[3]{19-3\sqrt{33}}$. We then obtained $q^3-12q-38=0$ and $p^3+24p+52=0$.
Then what we are required to prove becomes $(4+p)(4+q)=18$.
It is then not hard to prove that both $q^3-12q-38=0$ and $p^3+24p+52=0$ have only one real roots.
That means $4+q$ and $4+p$ are the only real root of the polynomials $f(x)=(x-4)^3-12(x-4)-38=x^3-12x^2+36x-54$ and $g(x)=(x-4)^3+24(x-4)+52=x^3-12x^2+72x-108$.
So we have $f\left(\dfrac{18}{x}\right)=-\dfrac{54}{x^3}g(x)$, i.e. $f\left(\dfrac{18}{4+p}\right)=g(4+q)=0$.
Hence, $\dfrac{18}{4+p}=4+q$ and the proof follows.
For confirmation of post#11
Thanks. Before I look at it I want to report on the direction I took but I could not finish it.
$$\sqrt{4+\sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}} \cdot \sqrt{8+2\sqrt[3]{19+3\sqrt{33}}+2\sqrt[3]{19-3\sqrt{33}}}=6$$
Let $$z= \sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}$$ and
$$z' = \sqrt[3]{19+3\sqrt{33}}+\sqrt[3]{19-3\sqrt{33}}$$
we can write it as
$$\sqrt{4+z} \cdot \sqrt{8+2z'}=6$$
or $$32 + 8z + 8z' + 2zz' = 36$$
solving for z' we get
$$z' = \frac{2 - 4z}{4 + z}$$
we put in z in the expression
$$z' = \frac{2 - 4\sqrt[3]{-26+6\sqrt{33}} -4\sqrt[3]{-26-6\sqrt{33}})}{4 + \sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}}$$
then try and simplify. Wolfram Alpha says it does simplify to exactly z' but so far I have not been able to do it.
[\SPOILER]
I finally have finished my proof in a direct form.
given
write it as
$$\sqrt{4+ a + b} \sqrt{8+2c + 2d} = 6$$
expand
$$ \sqrt{32 + 8(a + b + c + d) + 2(ac + ad + bc + bd)} = 6$$
then
##a = \sqrt[3]{-26 + 6\sqrt{33}}\hspace{0.5cm} b= \sqrt[3]{-26 - 6\sqrt{33}}\hspace{0.5cm}c = \sqrt[3]{19 + 3\sqrt{33}} \hspace{0.5cm}d= \sqrt[3]{19 - 3\sqrt{33}}##
Details of the working out of these expressions are in the appendix below.
##ac = 1 + \sqrt{33}\hspace{0.5cm}bd = 1 - \sqrt{33}\hspace{0.5cm}ad = -4\sqrt[3]{17-3\sqrt{33}}\hspace{0.5cm}bc = -4\sqrt[3]{17+3\sqrt{33}}##
Evaluating the sum of terms it is convenient to add ##a+d## and ##b+c## separately.
##a + d = \sqrt[3]{17+3\sqrt{33}}\hspace{0.5cm}b + c = \sqrt[3]{17-3\sqrt{33}}##
therefore
$$ \sqrt{32 + 8\sqrt[3]{17+3\sqrt{33}}) +8\sqrt[3]{17-3\sqrt{33}}+ 2\left( 1 + \sqrt{33} + 1 - \sqrt{33} -4\sqrt[3]{17+3\sqrt{33}} -4\sqrt[3]{17-3\sqrt{33}}\right)} = 6$$
giving
$$ \sqrt{32 + 4} = \sqrt{36} = 6$$
Appendix:
Again;
$$ac = \sqrt[3]{-26 + 6\sqrt{33}} \sqrt[3]{19 + 3\sqrt{33}} = \sqrt[3]{-26*19 +18*33 +(6*19-3*26)\sqrt{33}} = \sqrt[3]{100 + 36\sqrt{33}} = \sqrt[3]{(1 + \sqrt{33})^3} = 1 + \sqrt{33}$$
likewise
$$bd = \sqrt[3]{-26 - 6\sqrt{33}} \sqrt[3]{19 - 3\sqrt{33}} = \sqrt[3]{-26*19 +18*33 +(-6*19+3*26)\sqrt{33}} = \sqrt[3]{100 - 36\sqrt{33}} = \sqrt[3]{(1 - \sqrt{33})^3} = 1 - \sqrt{33}$$
$$ad = \sqrt[3]{-26 + 6\sqrt{33}} \sqrt[3]{19 - 3\sqrt{33}} = \sqrt[3]{-26*19 -18*33 +(6*19+3*26)\sqrt{33}} = \sqrt[3]{-1088 + 192\sqrt{33}} = \sqrt[3]{64(-1 7+ 3\sqrt{33})} = -4\sqrt[3]{17 - 3\sqrt{33}}$$
likewise
$$bc = \sqrt[3]{-26 - 6\sqrt{33}} \sqrt[3]{19 + 3\sqrt{33}} = \sqrt[3]{-26*19 -18*33 -(6*19+3*26)\sqrt{33}} = \sqrt[3]{-1088 - 192\sqrt{33}} = \sqrt[3]{64(-1 7- 3\sqrt{33})} = -4\sqrt[3]{17 + 3\sqrt{33}}$$
Now for the sum ##(a + d)## we use the relation ##(a + d)^3 = a^3 + d^3 +3a^2d + 3ad^2##
##a^2d = a (ad) = -4\sqrt[3]{(-26 + 6\sqrt{33})(17 - 3\sqrt{33})} = -4\sqrt[3]{-1036 + 180\sqrt{33}} = \sqrt[3]{66304 - 11520\sqrt{33}} = \sqrt[3]{(28 - 4\sqrt{33})^3} = 28 - 4\sqrt{33}##
##ad^2 = (ad)d = -4\sqrt[3]{(17 - 3\sqrt{33})(19 - 3\sqrt{33})} = -4\sqrt[3]{620 - 108\sqrt{33}} = -\sqrt[3]{39680 - 6912\sqrt{33}} = \sqrt[3]{(-20 + 4\sqrt{33})^3} = -20 + 4\sqrt{33}##
so ##(a + d)^3 = -26 + 6\sqrt{33} + 19 - 3\sqrt{33} +3(28 - 4\sqrt{33}) + 3( -20 + 4\sqrt{33}) = -7 +3\sqrt{33} +84 -12\sqrt{33} -60 +12\sqrt{33} = 17 +3\sqrt{33}##
thus ##(a + d) = \sqrt[3]{ 17 +3\sqrt{33}}##
Likewise for the sum ##(b + c)## we use the relation ##(b + c)^3 = b^3 + c^3 +3b^2c + 3bc^2##
##b^2c = b (bc) = -4\sqrt[3]{(-26 - 6\sqrt{33})(17 + 3\sqrt{33})} = -4\sqrt[3]{-1036 - 180\sqrt{33}} = \sqrt[3]{66304 + 11520\sqrt{33}} = \sqrt[3]{(28 + 4\sqrt{33})^3} = 28 + 4\sqrt{33}##
##bc^2 = (bc)c = -4\sqrt[3]{(17 + 3\sqrt{33})(19 + 3\sqrt{33})} = -4\sqrt[3]{620 + 108\sqrt{33}} = -\sqrt[3]{39680 + 6912\sqrt{33}} = \sqrt[3]{(-20 - 4\sqrt{33})^3} = -20 - 4\sqrt{33}##
so ##(b + c)^3 = -26 - 6\sqrt{33} + 19 + 3\sqrt{33} +3(28 + 4\sqrt{33}) + 3( -20 - 4\sqrt{33}) = -7 -3\sqrt{33} +84 +12\sqrt{33} -60 -12\sqrt{33} = 17 -3\sqrt{33}##
thus ##(b + c) = \sqrt[3]{ 17 -3\sqrt{33}}##
[\SPOILER]
