Is this a horribly ambiguous A Level Physics question?
In summary, the question-setter wanted something like "R is infinite because R = V/I = 2.9 / 0". This is not what was given, which is why the student and I scored no points.
ChrisXenon
60
Hi, I'm a private tutor who is not a school teacher and has no contact with schools.
I have an OCR A level "physics A" student, and we're working through past papers. Time and time again, we've come across questions which are astonishingly ambiguous and answer schemes which are in my view, astonishingly picky or just plane bizarre. I've taken some of these to OCR but got no progress.
For example they maintain that the word "rate" implies an increasing quantity, whereas I believe that "rate of pay" simply means how much you get paid. They say that "acceleration" will not do when a body is decelerating whereas I think that "deceleration" is an acceleration with a negative value and that all decelerations are accelerations.
We can't agree, but I'm not convinced I'm wrong, so I am looking for broader perspectives. If I AM wrong, then I need to know it and change my teaching accordingly. If I AM NOT wrong, then there's is something very worrying about how we measure OCR physics A level candidates.
So I'm looking for insights from teachers or physics experts.
Here is an example from yesterday's lesson. OCR Physics A H156/01 May 2016, Q27. A graph shows an I/V curve for an LED whose threshold voltage is 2.7V.
Question a: Describe and justify the variation of resistance R of the LED as the potential difference V across the LED is increased from:
(i) -1.0V to 2.6V
(ii) 2.6V to 3.0V
(iii) 3.0V to 3.4V
- but what does it mean by "and justify"?
I thought it meant "explain in terms of semiconductor behaviour", and - without prompting - my student thought the same. But in fact, the answer scheme makes clear that it wants stuff like "R is infinite because R = V/I = 2.9 / 0". OK but what is required is simply not clear from the question which in my view is horribly ambiguous. Both my student and I would have scored no points for that question. And these instances arise in every paper and sometimes more than once.
Relating to this - how do marking schemes work in practice; are they adhered to as the letter of the law or are they taken with a pinch of salt and markers go with "the right answer" as they see it. Actually either is worring but for different reasons.
So - any insights you can offer, on this question in particular, or the examples above it, or on exam querstions & marking - would be very welcome.
Thanks
Likes Merlin3189, PeroK and berkeman
Science news on Phys.org
You are correct on both counts and I also agree with your analysis of the other problem you mentioned.
I've often found this kind of idiocy on "standardized" tests, which often seem to have been formulated by bureaucrats, not teachers.
Likes Merlin3189 and berkeman
Regarding rates, they usually mean how some quantity is changing relative to some other quantity, where the "other quantity" is often time, but could be something other than time. In your example, "pay rate" is not just how much you get paid -- there is an implied time period. If my hourly pay rate is $30, this rate is actually ##\frac{$30}{\text{hour}}##.
Regarding acceleration, I agree that acceleration could be negative, zero, or positive, but if the question specifically asks whether an object is accelerating or decelerating, and a < 0, then the correct answer would be "decelerating," IMO.
But that's not an "increasing quantity" which is what he asked about
fair point.
The salary/wage paid is increasing -- at a rate of $30/hour in my example.
Likes DEvens and krater
fair point.
Guys thanks for your comments so far. Mark44 - thanks - you have helped me to understand what the OCR question-setter was saying.
In that case, the marking scheme forbade the term "rate of acceleration". In that context I still see the point but I feel it is very weak. When someone says "rate of acceleration" I take it to mean the rate of change of veolicty with time.
I think this may be a case where tying down words so specifically can impede the freedom od markers to behave intellignelty. Of course physics is a world where language must be used carefully to precisely express concepts and demonstrating understanding must be done through the written word so care is mandatory but in my view, this stipulation is wrong.
Interestingly, in the next part of that question "rate" is allowed. They felt is was unfair to penalise it's incorrect usage twice.
Actually (and rhetorically, maybe) if we think rate means change then why do we so often say "rate of change"?
For completeness, in case anyone's interested, here is the complete context of the "rate" question as originally sent to OCR:
A velocity/time graph shows an upward-curving line between t=0 & 2, and a straight descending line between 4=2 & 7. The question invites the student to describe the motion of the object.
That seems clear enough until you see the answer scheme. Two things puzzle me:
1. It FORBIDS any answers using "rate of acceleration". Please explain why. Later on (Q2a), you accept that same term. What is wrong with it?
2. Part 2 FORBIDS "constant acceleration". Why? The term "deceleration" is accepted, but any constant deceleration is also a constant acceleration whose magnitude is negative; it's still an acceleration. If I toss a ball into the air and consider its vertical velocity, we can note that it will have an initial upwards velocity (which we can arbitrarily label "positive"). It will slow down, then stop, then change direction and velocity will increase in the negative direction. If we plot its vertical velocity over that time, we'll see those velocities move from positive, through zero, to negative. Throughout this period the acceleration is a constant - g. So it has sped up, stopped, changed direction and sped up again, but it's perfectly correct to say it's ACCELERATION was constant, and it would be odd to say its DECELERATION was anything.
? that's not what you said.
I think an increasing rate of pay would be when you get a raise, but I sort of see how you are looking at it. You are considering that the PAY is increasing, not that the RATE of pay is increasing.
(i) -1.0V to 2.6V
(ii) 2.6V to 3.0V
(iii) 3.0V to 3.4V
Justify means you need to explain how you got the answer. Many students may be able to tell you the resistance is effectively infinite below the threshold voltage, but if you were to ask them why it is so, they'll say, "I don't know," because all they did was memorize a result without understanding the reasoning behind it.
As to what level of justification is appropriate, that's a part of the art of test-taking. Frankly, given the question, I think your interpretation of explaining in terms of semiconductor behavior would be overkill, but you know the test better than I do.
I think it's exactly what I said. I am distinguishing between the pay (amount of money) and the pay rate (amount of money per unit of time).
At a pay rate of $30/hour your total amount to be paid increases by $30 each hour. In terms of graphs, the pay rate is the slope of the graph of P = 30t, or 30. The total amount paid for t hours would be 30t dollars.
phinds said:
Think an increasing rate of pay would be when you get a raise, but I sort of see how you are looking at it.
In my example, the rate of pay is constant (30), but the amount paid is increasing.
Likes krater and berkeman
I have always been worried about these things, but there is no easy answer.
Today we did a question asking for two advantages of a temp probe/data logger over a thermometer. Well it has better resolution, but the second answer was that there is less chance of error with a digital display. I would be hard pressed to have picked the answer they want out of several possibilities.
I think you must have responded while I was editing my post because I realized that. Thanks.
Above, I assume you meant "straight descending line between t = 2 and 7"
On the interval [0, 2] is the graph concave up? If so, we have v > 0 and increasing, and acceleration > 0. On the interval [2, 7], we have v > 0 (I think, but don't have the graph to look at) and decreasing, but if the graph shows a straight line, the acceleration < 0. I.e., the object is decelerating.
Because acceleration already is a rate (##\frac {dv}{dt}## or the second derivative of the position with respect to time). "Rate of acceleration" implies how the acceleration is changing with respect to t.
Like I said earlier, it seems that the part 2 answer scheme wants the student to say simply whether the object is accelerating or decelerating. The simplest answer, without getting into the weeds with pos./neg. acceleration is that the object is accelerating for the first two seconds, and decelerating for the next five seconds. When humans write these questions and answers for automated-scoring tests, they don't always think of all the varied ways that other humans can respond.
Mark, yes, apologies - the straight descending line is between t = 2 and 7.
And yes, concave up for 0 to 2. [The paper is here BTW]
As before, I now understand what you and the question setter meant - rate is measurement of how one thing changes with another. And you used my own example - rate of pay - to show me how. I agree and I have moved my view somewhat - but I continue to thik that "rate of acceleration" should not be clobbered - though I think "rate of change of acceleration" should be.
On to part 2. I don't think the simplest answer is necessarily the one you give, and whether or not it is the simplest answer hasno bearing on whether or not it is the only acceptable one.I agree that people are human - and I'm not out for a linching - I'm just trying to extablishcorrect and incorrect and go from there.
You have helped me to see that question setter's viewpoint on the "rate" argument, though I think it's marginal and the marking scheme is mean. I still think he is totally wrong on part 2.
Anyway, thank you for your time and your patience with me. Before I can form a confident view of OCR's performance I'll need to look at a few more examples and hopefully people here will be as generous as you ave been.
Vela - thanks. "Justify" CAN mean "explain how you got the answer" but that is not the only possible meaning it can have. We could do an etymological analysis (Justify means "show or prove to be right or reasonable") but that doesn't really help us here. One can look at that and say "See - just what I said!" but there are still other valid interpretations.
If you feel this is wrong, I'd appreciate you explaining why it CANNOT mean "explain what is happening in the semiconductor".
Thing is - this could be easily fixed by clarifying the question to something like "by referring to the graph, justify your answer" or "explain your answer in terms of the data shown in the graph".
phinds said:
? that's not what you said.I think an increasing rate of pay would be when you get a raise, but I sort of see how you are looking at it. You are considering that the PAY is increasing, not that the RATE of pay is increasing.
I agree with you Phinds - whilst Mark's interpretation is strictly correct, I don't think it would be the common interpretation - that would be the pay raise interpretation. Of course, appeaking to "common interpretations" is dodgy ground in the physics world where common parlance is woefully inadequate, but I continue to think that the stipulation to punish "rate of acceleration" is wrong.
And in fact, if rate DOES mean that - then what on Earth does "rate of change" actually mean? Or is it tautological?
I'm curious to know if you work in teaching Phinds, if you're willing to say.
Technically, however, acceleration is a vector. There are no cases, IMO, where acceleration in a physics context is invalid and deceleration valid.
Also, deceleration is not where ##a < 0##. Deceleration is where, in 1D motion, acceleration and velocity have opposite signs.
Or, more generally in 3D motion, where the magnitude of the velocity is decreasing.
For example.
A body falling under gravity is subject to a constant acceleration. There can be no argument about this. This is not an incorrect statement, whatever the OCR exam board thinks.
The idea that the only valid description is that the body decelerates on the way up and accelerates on the way down is not physics.
Likes Merlin3189 and ChrisXenon
No, but my wife does and has shown me some tests, in addition to my own personal experience.
I have some experience in tutoring young people who are studying for their high school equivalency degree (used to be GED but is now called TASC in New York).
Just the other night I was looking at a new teaching manual that they are not yet required to use but are going to be required to use sometime soon and it is HORRIBLE. One of the first problems I looked at was a supposedly simple word problem at the 4th / 5th grade level and it was so confusing that I could not figure it out so I asked the lady there who had been teaching and tutoring math for 30 years and she could not figure it out either. The answer and discussion they gave for the question at the end of the section made no sense at all. She said the whole new set of books is almost that bad throughout. And this is just NY state. I hear others (not all of course) are just as bad or worse
Likes berkeman
Thanks. That is very depressing. One wonders what kind of an organisation can oversee such stuff. One whic hshould be packed full of intelligent well-motivated professionals, and yet - one which clearly isn't.
For example.
Extremely well put.
ChrisXenon said:
Extremely well put.
PS one further point is that the concept of deceleration is dependent on the reference frame. An aircraft taking off is accelerating relative to the surface of the Earth, but if it is traveling west it is decelerating in an inertial frame where the Earth is rotating west to east.
Again this shows the limited value of the whole concept of deceleration to physics. The acceleration is frame-invariant. Whereas the magnitude and direction of the velocity are not.
Likes berkeman
Agreed.
Likes berkeman
I can't think of any solution to this problem that I would not preface with HORRORS.
1 HORRORS no standardized tests. Every teacher invents his own standard.
2 HORRORS every standardized test grader decides for himself which answer is correct.
3 HORRORS the wordings of questions and answer choices is designed by committee.
4, 5, 6, ... there is no end to horrible choices.
Could it be that the underlying evil is the multiple choice question?
Likes pbuk
@ChrisXenon, I don't agree with all your points, but definitely quite a number of them. Just wondering - do you have problems with A-levels boards other than OCR? Are the marking schemes consistent across different A-level boards?
We don't need to do an etymological analaysis, every exam board in the UK publishes their definition of these command verbs and OCR tells us that when they say "justify" they mean "present a reasoned case for actions or decisions made". I think it is likely that if the examiner was looking for something else, he would have said "explain" or "explain in terms of semiconductor behaviour" EDITED but as semiconductor behaviour isn't in the A level OCR syallbus, this shouldn't be a concern. You haven't given the full background to your 'rate of acceleration' issue (the question, the marking scheme and the examiner's report should all be available on line) so it is harder to see what is going on here.
Every board publishes syllabi and teaching materials geared to those syllabi. Now one can argue that this just gives them a license to print money, and this system is a terrible way to teach and examine scientific knowledge, however this is not going to help your pupils get a better exam grade. To do that you need to accept the fact that any system for teaching and examining hundreds of thousands of pupils a year is going to have imperfections and do your research on the exam board's specifications and requirements. You then need to pass on this knowledge to your pupils to pass the exam.
That doesn't mean that every marking scheme for every question is perfect of course, far from it, and where there is a clear problem you can be sure that many teachers whose pupils have sat those exams will have challenged them and asked for re-marks. But pick your battles - if you want to challenge an exam board about what they are expecting to see as an answer, first check what they have TOLD you about what they are expecting to see.
Note that these comments only apply to UK GCSE and A-level examinations, I have no knowledge of other systems. Note also that I am not suggesting that science teachers should only teach pupils to pass exams - they must also impart understanding of and enthusiasm for the subject, and I am sure the latter is what motivates most good teachers to teach. But to be a good teacher, you must also (however unwillingly) embrace the former.
I have looked at the mark scheme for that paper: assuming you described correctly the increasing and decreasing resistance, you would have scored at least 3 of the 4 marks available for that question. If the marker had time to read your explanation of semiconductor physics and liked it you might have got the 4th mark but as semiconductor theory is not in the OCR A level Physics syllabus it is unlikely.
pbuk - are you saying that markers are at liberty to award marks olutside of the marking scheme - for general awesomeness?
pbuk this reply is very helpful for me and goes some way to explaining how things may not be as bad as I feared.
Whilst I have degree level physics, I do not work in a school and I have taken an ad hoc approach to teaching A level physics. You have exposed a flaw in that appoach which I thank you for. I did not know there were board definitions for action verbs or any other part of Enligh language. I will need to obtain them an use them in my teaching, and I will have to be on my guard for defficiencies like this in the future.
HOWEVER I agree that this is a DREADFUL way to conduct education. My student clearly did not and does not have any knowledge of these special verb usages, and so I imagine, neither do his teachers. Whatever the intended outcome, the actual outcome is shambolic in a way which could fail him. My student, by the way, is attending a very expensive public school (which in the UK means one you pay to go to, outside of taxes).
Any system which finds the need to redefine the English language is, in my view, idiotic. What is wrong with using the existing language effectively? Why not say "justify by reference to the graph"? I can confidently say that there is a hell of a lot wrong with saying "Justify*" and then - in some place no student will ever see, have this:
* Note: Any and all words may not have their normal meaning. The OCR board reserve the right to re-define English to the utter bewilderment of humanity. No responsibility accepted. Your mileage may vary. My dad's a policeman.
The rated of acceleration question is here and the marking scheme is here
I note your point about basically accepting the system for what it is and leanring to succeed within it, and to a degree I accept it. As I mentioned, I DO need to get that verb list and apply it. However, a genetic fault I have is being unable to swallow a stinking status quo, which is why I have approached OCR (and have subsequently pointed them to this thread) and why I have no friends. :H
I want the board to fix their flaws; I think it's a better solution for the planet than the planet learning to accept the OCR's flaws, and if they don't want to play that game, then I'd quite like to wipe them off the face of the globe, because the current approach is arrogant, complacent, and highly damaging.
And I think being a good teacher might involve inspiring critical thinking in one's students and giving them the iron it takes to make a stand in the world.
But - big picture - you are cleary knowledgeable in both physics and the ways of the OCR and so you're a huge asset and I appreciate your time here.
UPDATED: You say [when they say "justify" they mean "present a reasoned case for actions or decisions made".] OK I've explained why I think it'a wrong to use words then offline their special meaning, but even if they had said "present a reasoned case for " instead of "justify" - it doesn't move us forward at all, does it? I still don't se ehow it can't mean "present a reasoned case in terms of semiconductor physics".
I only have one A level student and I would not have him but for historical circumstances, and he is with the OCR, so I don't know if I would have a problem with another board.
  • #31
Sorry I don't understand your point.
  • #32
This thread will shortly become unmanagable but here's the latest crank of the handle with OCR. My inline response to the question setter begin with >>
Thank you for your continued correspondence on mark schemes [...]
Note that the question is not about LEDs in general, but about a particular LED.
>> I understand but do not see the relevance of your distinction.
Candidates have been provided with a graph of the I-V characteristic of this LED and would be expected to
use it in their response. We are always careful to make sure that it is clear whether a question
refers to a specific object or a class of objects, as has been done here.
>> OK but again - I don't see the relevance here
The command “Describe and justify...” requires candidates to do two things for each potential
difference range. First they must describe the variation of resistance, and second they must
provide some evidence for that variation with the expectation that this comes from the
information given to them in the question, ie the graph.
>> You are describing your intended interpretation. I already knew it once I read your marking scheme.
But the significant fact is that I did not know it before - it was not evident from the question.
Someone on the physics forum has said OCR publishes a set of verbs and special meanings.
Is that true? Where would I find it? Honestly, I HATE that idea - it is all wrong. Use the existing language
effectively and unambiguously - don't redefine it in an appendix which no one will ever see then punish them for misunderstanding it!
The mark scheme and examiner’s report are clear that this sort of response is exactly what was given by candidates, and therefore that
the question was not found to be ambiguous.
>> If most students got it right, then I suppose most students gave the interpretation you intended.
But I am surprised if that is so, and it doesn't change the fact that the term "justify" could legitimately mean a multitude of things.
To satisfy me you'd need to explain why the questions CANNOT mean "explain this behaviour in terms of semiconductor physics".
The answer given in the main part of the scheme is generally a minimally acceptable answer,
with clarification in the guidance column. It is very likely that a more discursive response about
the general properties of semi-conductors would be awarded all four marks since it would
contain the necessary information. Since the given mark scheme would cover such a response,
there would not be any need to include any mention of it in the mark scheme.
>> You seem to be saying (I paraphrase with no intention to offend you):
"It is OK to ask an ambiguous question because in a lengthy written answer the candidate is likely to provide what is required inadvertently"
I assume I must have misunderstood you. Please clarify.
Regards
Chris
  • #33
My point is similar to what you said in a later post.
The language of physics is mathematics. This thread discusses an exam question posed verbally, with multiple choice answers given verbally. Then we run into problems because natural language is imprecise and subject to interpretation.
The solution would be the old fashioned type of exam where the student is required to derive his/her own equations and solve for the answer. The symbols used are the student's choice. We use math as much as possible in the question and the answer. It is the technical analog to "essay" type questions.
Of course that type of exam means many fewer questions are possible in the allotted time. It is also much more demanding and time consuming on the person doing the grading. It also introduces some grading subjectivity. (Should I allow 8 out of the max 10 points for this answer?) But it avoids exactly the dependency on word definitions you are complaining about.
I always thought that the drift towards multiple choice verbal exam questions, is motivated by the ease of machine grading. Multiple choice also allows more questions in the exam, e.g. 100 shallow questions instead of 10 in-depth questions.
Likes sysprog
  • #34
By now your student should have a pretty good idea of what is expected of him when answering a question; and that includes how to interpret the verbs.
It is important to note that when studying for an A level in a subject in the UK the students are NOT taking a "general" A-level course. Everything -including the syllabus- is set by a specific exam board. Hence, if the teacher has done his/her job right the students will from day one be asked questions of the same type, where the same language is used.
The way the system is set up it is certainly not about learning physics; it is about learning how to pass an exam from a specific exam board.
At my step-sons school they stopped teaching them new material back in November; for the past few months they have only been revising; it reality practicing how to answer questions in the exams (which start in June).
They also spent a couple of months preparing for the mocks in year 1. Hence, out of a two year course a little over half is spent on revising and preparing for the exams; NOT learning new material.
So yes, the system is broken (by design) but there isn't much you can do about it.
Likes berkeman
  • #35
f95toli, my commments inline with yours:
>> Well, by now I should be slimmer and more patient - but I ain't either. The reality is that he has had no training in the special use of English foisted upon us by OCR. And, as I've mentioned that arbitrary reality is also un-necessary and tiresome.
>> Same commens as above. What should be and what is are not related here.
>> The two should be very closely allied or soemthing is very wrong. What's a physics A level FOR, for goodness sake? I suggest it should not be to prove someone can learn and apply some alternate Engloid language.
I don't see anything with revising or consolidating mateial or techniques. What I'm objectgivnig to is the use of ambiguous questions and non-standrard inter[retations of English.
>> I thinh there is a lot people can do when they try.
Likes PeroK
  • STEM Educators and Teaching
  • Other Physics Topics
17K
  • STEM Academic Advising
