Can This Proof Verify the Existence of Integers m and n for Any Real Number x?
  • Thread starter Thread starter Physics2341313
    Proof
The discussion centers on proving the existence of integers m and n such that m < x < n for any real number x. Participants reference Theorem I.27, which states that every nonempty set bounded below has a greatest lower bound. The conversation highlights the challenge of defining a set S without a maximum element and the implications for upper and lower bounds. A suggestion is made to consider the set S as integers less than x, which could facilitate the proof. The dialogue emphasizes the importance of careful assumptions about the nature of the sets involved in the proof.
Physics2341313
1. Question I 3.12 from Apostle's calculus volume 1
If x is an arbitrary real number, prove that there are integers m and n such that m<x<n
2. Theorem I.27:Every nonempty set S that is bounded below has a greatest lower bound; that is, there is a real number such that L= infS
3. Suppose x\inR and belongs to a nonempty set S with no maximum element. It follows that ∃B\inZ\stackrel{+}{} such that B is an upper bound for S. Let n=B, then we have n>x. Similarly, let -S denote the set of negatives of numbers in S. Suppose that -B\in-Z\stackrel{+}{} of -S, then by theorem I.27 -B is a lower bound of -S. Let m=-B. , such that m<x<n.
You have stated this as if you're making two assumptions about x. You should only make one: ##x\in\mathbb R##. If you need to use some other statement about x, you need to be able to prove that it follows from your one and only assumption about x.
It doesn't. Consider e.g. x=1 and S the set of integers (which doesn't have a maximum element).
I thought an inductive set could have an upper bound but not a greatest upper bound / supremum because for every x in the set x+1 is also in the set?
and to fix my assumption issue could i do something along the lines of- Suppose S is a nonempty set of real numbers and suppose there is a number B such that x\leqB so B could be an upper bound and then go an to show the lower bound as well equating m and n, the integers, as a subset of the real numbers?
The set of natural numbers is an inductive set, but it doesn't have an upper bound in ##\mathbb R##. This would contradict the result that you're trying to prove.
If you let S be an arbitrary non-empty subset of ##\mathbb R## and let B be an arbitrary real number such that ##x\leq B##, then what set would B be an upper bound of? Certainly not S. S is arbitrary, so we could have ##S=\{B+1\}##. B is an upper bound of {x}, but that's not very useful.
Edit: I'll give you a hint about one way to solve the problem. The set ##S=\{n\in\mathbb Z|n<x\}## is useful.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
