Can This Proof Verify the Existence of Integers m and n for Any Real Number x?
  • Thread starter Thread starter Physics2341313
    Proof
The discussion centers on proving the existence of integers m and n for any real number x, specifically that there exist integers m and n such that m < x < n. The participants reference Theorem I.27, which states that every nonempty set bounded below has a greatest lower bound. They explore the implications of choosing a nonempty set S of real numbers without a maximum element and the conditions under which integers can serve as bounds. The conclusion emphasizes the utility of the set S = {n ∈ ℤ | n < x} to demonstrate the existence of such integers.
  • Understanding of real numbers and integer sets
  • Familiarity with the concept of greatest lower bounds in real analysis
  • Knowledge of basic set theory and inductive sets
  • Proficiency in mathematical proof techniques
  • Study the implications of Theorem I.27 in real analysis
  • Explore the properties of upper and lower bounds in set theory
  • Investigate the construction of sets of integers relative to real numbers
  • Learn about the completeness property of real numbers and its applications
Mathematics students, educators, and anyone interested in real analysis and the foundations of mathematical proofs will benefit from this discussion.
Physics2341313
1. Question I 3.12 from Apostle's calculus volume 1
If x is an arbitrary real number, prove that there are integers m and n such that m<x<n
2. Theorem I.27:Every nonempty set S that is bounded below has a greatest lower bound; that is, there is a real number such that L= infS
3. Suppose x\inR and belongs to a nonempty set S with no maximum element. It follows that ∃B\inZ\stackrel{+}{} such that B is an upper bound for S. Let n=B, then we have n>x. Similarly, let -S denote the set of negatives of numbers in S. Suppose that -B\in-Z\stackrel{+}{} of -S, then by theorem I.27 -B is a lower bound of -S. Let m=-B. , such that m<x<n.
You have stated this as if you're making two assumptions about x. You should only make one: ##x\in\mathbb R##. If you need to use some other statement about x, you need to be able to prove that it follows from your one and only assumption about x.
It doesn't. Consider e.g. x=1 and S the set of integers (which doesn't have a maximum element).
I thought an inductive set could have an upper bound but not a greatest upper bound / supremum because for every x in the set x+1 is also in the set?
and to fix my assumption issue could i do something along the lines of- Suppose S is a nonempty set of real numbers and suppose there is a number B such that x\leqB so B could be an upper bound and then go an to show the lower bound as well equating m and n, the integers, as a subset of the real numbers?
The set of natural numbers is an inductive set, but it doesn't have an upper bound in ##\mathbb R##. This would contradict the result that you're trying to prove.
If you let S be an arbitrary non-empty subset of ##\mathbb R## and let B be an arbitrary real number such that ##x\leq B##, then what set would B be an upper bound of? Certainly not S. S is arbitrary, so we could have ##S=\{B+1\}##. B is an upper bound of {x}, but that's not very useful.
Edit: I'll give you a hint about one way to solve the problem. The set ##S=\{n\in\mathbb Z|n<x\}## is useful.
  • · Replies 22 ·
