Is throwing dice a stochastic or a deterministic process?
In summary, the conversation discusses the difference between stochastic and deterministic processes. It is mentioned that games of chance are often best modeled stochastically, but with enough information and computing power, the outcome can be predicted. The example of roulette is given, where classical physics and initial conditions can predict the outcome once the ball is set in motion. However, there is also a mention of Claude Shannon's roulette exploits using a wearable computer. The conversation concludes by stating that saying throwing dice or playing roulette or tossing coins is either stochastic or deterministic depends on how one tries to describe it, and that even seemingly deterministic processes can have unpredictable outcomes due to small deviations.
Aidyan
180
As far as I understand it a stochastic process is a mathematically defined concept as a collection of random variables which describe outcomes of repeated events while a deterministic process is something which can be described by a set of deterministic laws. Is then playing (classical, not quantum) dices a stochastic or deterministic process? It needs random variables to be described, but it is also inherently governed by classical deterministic laws. Or can we say that throwing dice is a deterministic process which becomes a stochastic process once we use random variables to predict their outcome? It seems to me only a descriptive switch, not an ontological one. Can someone tell me how to discriminate better between the two notions?
It depends on how you want to model it. It is frequently profitable to try to model it both ways -- sometimes you'll get the same result but different insights (e.g. with the heat equation) depending on how you look at it.
Sometimes one way will be a dead-end -- e.g. for monitoring games of craps, to my knowledge casinos use very little physical modelling and a lot of probability.
I have concerns that the motivation for this thread is on the border of philosophy
Games of chance are often best modeled stocastically even though we know given enough information and computing power we can predict the outcome.
For casinos this results in being ever vigilant against those players who might buck the odds using inside knowledge of the game mechanics and playing to certain weaknesses found.
Roulette play is probably a better example where once the ball is set in motion then classical physics and initial conditions can predict outcome.
Heres how some folks tipped a stochastic game to be a more predictable:
http://mentalfloss.com/article/60922/8-casino-scams-actually-worked
also of interest, Claude Shannon's roulette exploits with the first wearable computer:
https://www.cs.virginia.edu/~evans/thorp.pdf
Likes jedishrfu
So, as I understand it, saying that throwing dice or playing roulette or tossing coins is not a stochastic process but a deterministic one, makes no sense. It depends on how one tries to describe it. (?)
Aidyan said:
So, as I understand it, saying that throwing dices or playing roulette or tossing coins is not a stochastic process but a deterministic one, makes no sense. It depends on how one tries to describe it. (?)
It is a deterministic one but you won't get even near the chance to know all parameters. E.g. how would you model the thermodynamic behavior of air? And this for every molecule!
Thus the result will be a probabilistic process, simply because your ingredients are already probabilistically modeled. But even without, we have made some serious progress since Laplace, and it's not quantum mechanics alone. See e.g. chaos theory. The French mathematicians Henri Poincaré and Jacques Hadamard discovered as early as the end of the 19th century that even simple dynamic systems such as the three-attracting body lead to very complicated trajectories. And even in elementary physical processes such as the movement of a mass point along geodesics, small deviations of the initial angle lead to any large changes in the result.
Likes Aidyan
Mentor note: "Dices" is a word in English, but is unrelated to the small cubes with spots. You can have one die or two or more dice. I have edited several posts in the thread to fix this minor problem.
Likes Aidyan
1. Is throwing dice a stochastic or a deterministic process?
The answer to this question depends on the context in which the dice are being thrown. In a controlled environment, such as a laboratory, throwing dice can be considered a deterministic process because the outcome is based on the initial conditions and the laws of physics. However, in a real-world scenario, where factors such as air resistance and surface imperfections come into play, throwing dice can be considered a stochastic process because the outcome is not entirely predictable.
2. What is the difference between a stochastic and a deterministic process?
A stochastic process is one in which the outcome is influenced by random variables and is therefore not entirely predictable. On the other hand, a deterministic process is one in which the outcome is entirely determined by the initial conditions and the laws of nature, making it predictable.
3. Can a deterministic process exhibit stochastic behavior?
Yes, in certain cases, a deterministic process can exhibit stochastic behavior. This can happen when there are unknown or unaccounted for variables that affect the outcome, making it appear random or unpredictable.
4. Why is it important to understand whether throwing dice is a stochastic or a deterministic process?
Understanding whether throwing dice is a stochastic or a deterministic process can help in making more accurate predictions and decisions. For example, in gambling or game scenarios, knowing the nature of the process can help in devising better strategies. In scientific experiments, it is crucial to know whether the outcome is influenced by random variables or not in order to draw accurate conclusions.
5. Can a process be both stochastic and deterministic?
Yes, a process can exhibit both stochastic and deterministic behavior. This is known as a semi-stochastic process, where some elements of the process are influenced by random variables while others are entirely determined by the initial conditions and the laws of nature.
  • Set Theory, Logic, Probability, Statistics
  • Quantum Interpretations and Foundations
