Is time fundamental or emergent from deeper physics?
  • Level: Graduate
  • Thread starter Thread starter Naty1
    Space Time
5 replies · 2K views · last reply
Naty1
Wondering about "time"?
...Just as acceleration and gravity have underlying symmetries, here's an interesting example of where space and time may be linked in hidden ways ...and just how "essential" time may really be...
In Fabric of the Cosmos, Brian Greene says in a footnote (Chapter 12, #7,Page 527)
It's somewhat of misnomer to speak of the "center" of a black hole as if it were a place in space...Just as you can't resist going from one second to the next in time, you can't resist being pulled to the black holes "center" once you've crossed the event horizon...Thus rather than thinking of the black holes center as a location in space it is better to think of it as a location in time...it may be true that its ...where spacetime comes to an end...if we had equations that don't break down deep inside a black hole we might gain important insights into the nature of time...
And here's another twist: (footnote # 6, Page 527)
In the central Wheeler Dewitt equation it turns out that the time variable does not appear ...so rather than having an explicit mathematical embodiment of time -as is the case in every other fundamental theory- in this approach to quantizing gravity temporal evolution must be kept track of by a physical feature of the universe (such as density) that we expect to change in a regular manner...as yet no one knows if this procedure for quantizing gravity is appropriate...is this hinting that time is an emergent conept?
"We know a lot; We understand little."
Don't base anything on black holes. Inside the event horizon, time and space don't make any sort of sense. Just do what I do and hope they are a mistake and that one day someone will prove it. :-)
The black hole example is not necessary. There are other illustrations of the concept time = space. This is a view to which I whole-heartedly subscribe, and had arrived at indepednantly before encountering it in the popular literature.
Since Einstein's Special Relativity, time and space have been unified into space-time, and concepts of simultaneity mix one observer's space with another's time. Lorentz boost transformations are effectively imaginary rotations between space and time axes. All of that is well understood.
Gravity calls attention to the fact that time differs from space, in that the primary effect of a gravitational potential is to change the effective value of c, the conversion factor between space and time, as seen from a distance, and more generally the shape of space-time.
However, what happens to time and space inside black holes (in the frame of an outside observer) is something else on any scale, involving a combination of infinite quantities and hypothetical exchanged imaginary space and time axes. You may read many mystical things about black holes, but I don't think they prove anything except the limits of our understanding.
Time and space inside a black hole make almost as much "sense" as in special and general relativity. Relativity whispers about spacetime issues which black holes seem to scream.
A black hole example IS necessary, I think, although not necessarily the example I cited, because strange "goings on" occur on this side of the event horizon and at the event horizon as well. How can mass and light, viewed from a distance, and approaching the event horizon slow and whoaaaaaaa, come to a stop before getting there! Now that's crazy, if true! In addition it's a good example because we know quantum theory and relativity don't apply under black hole conditions; that alone makes theoretical phenomena fascinating...and shows we don't know as much as we might think...Black Holes may also offer critical insights to information theory and holographic representations of matter and forces.
These two insights, whether eventually confirmed or proven wrong ,are the kinds of perspective that makes reading different physicsts thinking worthwhile...
Jonathan posted
Interesting perspective...I always thought the reverse: that the variation in c between the two meant they ARE connected in subtle ways we don't fully understand...I was just reading some "frame dragging" material and Dr Kaku says, in Parallel Worlds, Stockum's infinite rotating cylinder where spinning the cylinder at near light speed would drag space-time along with it permitting travel to the (limited) past...And the fact that supposedly traveling faster than c moves one back in time also suggests a more intimate connection between space and time than we might understand...
Either way, it's enough to give one a "physics headache".
