Issues finding time in acceleration problem
The discussion focuses on solving a physics problem involving a car's braking distance and acceleration. The user correctly calculates that the car travels 8 meters in 0.5 seconds before applying brakes, but struggles to determine the total stopping time and the necessary acceleration to stop at the intersection. There is confusion regarding the calculation of time, with a suggestion that the result of 16 seconds is inaccurate and should be closer to 15 seconds. The importance of significant figures in calculations is emphasized, reflecting the instructor's grading criteria. Overall, the user is encouraged to refine their calculations and apply basic physics principles to solve the problem effectively.
bracing
You are driving to the grocery store at 16 m/s. You are 130 m from an intersection when the traffic light turns red. Assume that your reaction time is 0.50 s and that your car brakes with constant acceleration.
x1 = 0 m
v1 = 16 m/s
t1 = 0 s
x2 = ?
v2 = 16 m/s
t2 = 0.50s
x3 = 130 m
v3 = 0 m/s
t3 = ?
(a) How far are you from the intersection when you begin to apply the brakes?
(b) What acceleration will bring you to rest right at the intersection?
(c) How long does it take you to stop?
for (a)
(x2-x1) = ((v1+v2)/2)*(t2-t1)
(x2-0m)=((16m/s+16m/s)/2)*(0.50s-0s)
x2=(32m/s/2)*0.50s
x2=16m/s*0.50s
x2 = 8m
for (c)
(x3-x2) = ((v2+v3)/2)*delta t
122m=(16m/s/2)*delta t
16s=delta t
for (b)
a=delta v/delta t
a=-16m/s/16s
a=-1 m/s^2
I know (a) is correct, where I am having issues is computing the final time so I can then obtain the acceleration.
Thanks,
Bracing
Hello Bracing,
Welcome to Physics Forums!
These are really part of the problem statement, not the relevant equations. But now I'm just being nitpicky...
for (a)
x2=(32m/s/2)*0.50s
x2=16m/s*0.50s
x2 = 8m
You have calculated that the car travels 8 m in 0.5 seconds, which is fine. But the problem statement is asking you how far away the car is from the intersection. (But I see from below that you have already figured out it is 122 m. If you wanted to get that value from your equation directly, you could do it by putting in the 130 m into your (x2 -x1) term somewhere.)
for (c)
16s=delta t
Be careful of your math. 122/8 isn't exactly 16.
for (b)
a=delta v/delta t
a=-16m/s/16s
a=-1 m/s^2
Your approach is sound. But you'll need to correct that previous mistake first (the time isn't exactly 16 seconds)
16s is rounded to significant figures as my instructor instructed the class on how he wanted it. I personally think I'm losing a bit by doing it but he continually stresses that we do.
I am dumb-founded over this as every example given in class had a stated acceleration, then my homework questions posted only do not.
Well okay, if that's what your instructor wants. But I'm just saying that 122/8 is actually a little closer to 15 than it is 16.
But apart from the rounding stuff your solution looks okay to me.
Oh, but that's part of the joy of physics. By learning some basic principles, you can figure problems out from scratch, even without specific examples. That's one reason why physics is phun! :smile:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
