Do i need to find the x and y components?
When a ball is shot at an angle of 55 degrees, its time in the air will be shorter compared to a vertical shot. The initial vertical velocity can be calculated by reducing the vertical component based on the launch angle. An algebraic expression for the initial vertical velocity is sufficient for the problem, rather than a numerical value. The given time of 1.34 seconds can be incorporated into the calculations to determine the impact of the angle on flight duration. Understanding these components is crucial for solving the problem effectively.
crism7
j
t = 2vi sin theta / g (i'm not sure)
Do i need to find the x and y components??
j
Welcome to PF. :smile:
You are given how long the ball stays in the air when shot vertically. What is different when it is shot up at an angle of 55 degrees? It will stay in the air a shorter time, but by how much? What is the initial vertical velocity reduced to when the launch angle is 55 degrees?
To @crism7 : Note that @berkeman is not expecting you to find a number for the initial vertical velocity. An algebraic expression will be sufficient. Then see how you can work the given 1.34 s into it.
Likes berkeman and crism7
