Java syntax errors in array loop for month days
8 replies · 4K views · last reply
grzz
TL;DR
I cannot see why there are errors displayed in lines 22 and 23.
Java:
//program showing an advantage of using arrays
public class Arr3
    public static void main(String []args)
        System.out.println("There are 31 days in the month of Jan");
        System.out.println("There are 27 days in the month of Feb");
        System.out.println("There are 31 days in the month of Mar");
        System.out.println("There are 30 days in the month of Apr");
        System.out.println("There are 31 days in the month of May");
        /*We can make use of an array with the number of days in the month
         * and another array with the names of the months and use these two
         * loops to go through these numbers of days and these names of
           months*/
        int mdays []={31, 37, 31,30, 31};
        String months []={Jan, Feb, Mar, Apr, May};
        for(i = 0; i < mdays.length; i++)
         System.out.println("There are " + mdays[i] + " days in the month
         of " + months[i]);
I am a beginner in learning Java and hence I need some help because I cannot see the mistakes that I must have made in the above code.
Please help me.
Thanks.
grzz said:
TL;DR Summary: I cannot see why there are errors displayed in lines 22 and 23.
Read the error messages carefully. Do you know what a "string literal" is? What do you think it means when it says there is an "unclosed string literal"?
There are quite a few more errors in your code; before you go on I suggest you revise both Strings and Variable Declaration in Java.
What IDE are you using, @grzz? BlueJ? I suggest you switch to a better IDE like NetBeans (at least) or IntelliJ IDEA. Good IDEs will point out the errors even before you compile your code. BlueJ shouldn't even be considered an IDE; it's just a colourful Notepad with some buttons to compile/run code, which eliminates the use of a terminal.
Java:
public class Arr3
           months*/
        int i;
        String months []={"Jan", "Feb", "Mar", "Apr", "May"};
         System.out.println("There are " + mdays[i] + " days in the month"+
         "of " + months[i]);
I corrected my mistakes.
It was very foolish of me not to put the strings of the months in double
quotation marks but I did not know that when starting a new line with strings
one has to put again the quotation marks.
Thank you very much for the help given.
i corrected the java code.
Thanks pbuk for the help.
It was foolish of me not to put the strings for the months in double quotation marks but I did not know that one has to put these marks even when one goes to a new line.
I started with Eclipse but I found it too complicated for a beginner and so I switched to Bluej.
Eclipse is ?:). You can try NetBeans or IntelliJ IDEA. A better IDE will help you code better by pointing out your errors even before you compile the code, suggest improvements to the code, and help you view documentation with ease (which is very much necessary and not taught in most schools/courses).
There is also VS Code Editor with Java plugin support.
https://code.visualstudio.com/
https://code.visualstudio.com/Search?q=java+plugins
I've used all of these IDEs, Eclipse and IBM's extensions to it, Netbeans, and IntelliJ.
Eclipse was great at first but then you'd become enamored with a plugin's features and then the plugin became subscription based or paid for newer features. IBM's extensions would make the IDE slow to start and sometimes slow to use as plugins were loaded. IBM had added Rational plugins to the base of 50 plugins to up to 5000 Rational code analysis plugins (that's a guess) which really slowed things down causing us to seldom turn off our machines.
https://www.ibm.com/products/rad-for-websphere-software
Netbeans is Netbeans, similar to Eclipse but with the plugins you need. It works well and has a custom forms builder aka "Matisse" saving you from hand-coding a GUI for your app but always seemed to lag behind the latest Java features and was somewhat hard to find features you needed with many bells and whistles. And then they moved it to Apache which for a time made it even slower to update. It has a specific directory format for projects preferring either Ant or Maven build structures.
https://netbeans.apache.org/
IntelliJ has a free version and a paid version. I've used the free version and liked it a lot. It was fast and had a clean interface. However, my company had objections to paying for a version and more recently to it being built by a company with Russian ties.
https://news.ycombinator.com/item?id=30453689
VS Code seems to be the "go-to" editor of choice for programmers. It seems to be under active development with good support. It has a wide range of free plugins. It loads fast and supports many popular languages and does not tie you down to a specific project directory format.
More on IDE's:
https://www.techrepublic.com/article/best-ide-software/
https://www.slant.co/topics/10021/~ides
Aside from the errors already noted, you have a couple of other errors:
Line 8: System.out.println("There are 27 days in the month of Feb");
LIne 18: int mdays []={31, 37, 31,30, 31};
February has more than 27 days, and no month has 37 days. These errors won't affect the running of your code, but others may suspect you don't have a clear understanding of calendars.
