Jensen inequality fails for 1/X with discrete random variable
6 replies · 3K views
giglamesh
Hi everyone
I don't know if I can find someone here to help me understand this issue, but I'll try
the jensen inequality can be found here http://en.wikipedia.org/wiki/Jensen%27s_inequality
I have the following discrete random variable [itex]X[/itex] with the following pmf:
x 0 1 2 3
pr(x) 0.110521 0.359341 0.389447 0.140691
and the summation is (1).
defining the function [itex]Y=\frac{1}{X}[/itex]
Then finding the [itex]\bar{X}=\sum_{i=0}^{3}{iPr(i)=1.560308}[/itex]
Now calculating [itex]E[Y]=E[\frac{1}{X}]=\sum_{i=1}^{3}{\frac{1}{i}Pr(i)}=0.6009615[/itex]
then:
[itex]Y(\bar{X})=\frac{1}{\bar{X}}=\frac{1}{1.560308}=0.640899105[/itex]
According to Jensen inequality what should happen:
[itex]E[\frac{1}{X}] \geq \frac{1}{E[X]}[/itex]
but what I got is the opposite case!:cry:
Now also I have to mention the function [itex]Y=\frac{1}{X}[/itex] is convex given that the second derivative is strictly larger than zero.
Do I misunderstand the Jensen inequality? or is there something wrong with the convixity assumption?
Any idea?
Without having looked at the details of your calculations, you certaintly have a problem with Y = 1/X for X=0
Yes you are right to assume it but in the calculation I assumed X>0 when calculating Y.
Even with this assumption I can't approve the opposite inequality.
This can be thought like: choosing one message from X messages problem.
Thanks for reply
Well, you cannot simply "remove" X=0 by setting 1/0=0. Then your function is not convex any more, and this is the source of your problem.
thanks winterfors
But why it's not convex
is there a way to prove that it's concave?
Maybe you mean it's non differentiable at X=0
thanks for reply
I suggest you look up the definition of a convex/concave function. A function does not have to be differentiable to be convex, for instance is f(x)=abs(x) convex even though is it not differentiable at x=0. Also, that a function is not convex does not imply it is concave, or vice versa.
I know dear
that's why I asked about why setting Y=0 when X=0 caused the problem
You said the function is not convex any more, here I didn't get it, does it mean now it's concave?
the second derivative is positive since X>0
Anyway thanks for reply I'll do more research on that
