Calculating Density Function of Joint Independent Exponential Random Variables
The discussion focuses on finding the probability density function (pdf) of the ratio Z = X / Y, where X and Y are independent exponential random variables with different parameters. Participants suggest starting by determining the conditional pdf of Z given Y=y, which involves using the transformation of variables technique. The next step involves averaging this conditional pdf over the distribution of Y to obtain the marginal pdf of Z. Key equations and integration techniques are discussed to facilitate this calculation. The overall goal is to derive a clear expression for the density function of the ratio of two independent exponential random variables.
MATHTAM
X and Y are independent, exponentially distributed random variables - with possibly different parameters
Determine the density func. of Z = X / Y
How to attack ?
What eqn can you write for the pdf of Z at z given Y=y?
How can you then average that out over all possible y?
The standard _A " operator" maps a Null Hypothesis Ho into a decision set { Do not reject:=1 and reject :=0}. In this sense ( HA)_A , makes no sense. Since H0, HA aren't exhaustive, can we find an alternative operator, _A' , so that ( H_A)_A' makes sense? Isn't Pearson Neyman related to this? Hope I'm making sense. Edit: I was motivated by a superficial similarity of the idea with double transposition of matrices M, with ## (M^{T})^{T}=M##, and just wanted to see if it made sense to talk...
  • · Replies 30 ·
