Jonathan Oppenheim, "A postquantum theory of classical gravity?"
The discussion revolves around Jonathan Oppenheim's proposal of a "postquantum theory of classical gravity," exploring its implications for existing theories of gravity and the nature of quantum mechanics. Participants examine the theoretical underpinnings, potential compatibility with other frameworks, and the philosophical implications of defining properties in quantum systems.
  • Some participants express that Oppenheim's hypothesis appears arbitrary, noting that all other fields are quantized.
  • There is a discussion about the uncertainty principle in quantum mechanics and how it affects which properties can be actualized, with references to the "decoherent histories" program.
  • One participant finds Oppenheim's approach interesting as it probes the consequences of exceeding the quantum maximum of fine-graining the gravitational field.
  • Concerns are raised about whether Oppenheim's theory could falsify existing theories such as string theory, loop quantum gravity, supergravity, or entropic gravity, or if it could be integrated with them.
  • Another participant emphasizes that a theory is falsified by experiment, unless contradictions within the theory itself are shown, and questions whether Oppenheim's theory represents a simpler framework.
  • Discussion includes the idea of a classical-quantum (CQ) formalism where classical variables describe spacetime and quantum variables describe everything else, with some skepticism about the consistency of this approach.
  • Participants debate the feasibility of constructing a CQ theory of gravity from existing quantum gravity theories, noting potential challenges with entropic gravity and string theory.
  • Concerns are raised about the role of renormalization and UV-completeness in defining quantum field theories within Oppenheim's framework.
Participants do not reach a consensus; multiple competing views remain regarding the implications of Oppenheim's theory and its relationship with existing gravitational theories.
Participants highlight limitations in defining gravitational variables within a CQ framework and the complexities introduced by renormalization and UV-completeness in quantum field theories.
kodama
TL;DR
the stochastic coupling between quantum mechanics and gravity
in the news
String Theory gets Competition: A New Attempt to Solve Physics' Biggest Mystery
Sabine Hossenfelder
based on
Jonathan Oppenheim, "A postquantum theory of classical gravity?",
Jonathan Oppenheim et al, "Gravitationally induced decoherence vs space-time diffusion: testing the quantum nature of gravity", Nature Communications (2023). DOI: 10.1038/s41467-023-43348-2
thoughts on A postquantum theory of classical gravity
The hypothesis is a little arbitrary. Every other field we know about is quantized.
For me, the larger issue which this borders on, is the question of which possible properties become actual.
In quantum mechanics, you can't have definite values for all observables at once - this goes back to the uncertainty principle, and the tradeoff between precision in position and precision in momentum. Which properties do become actual, is one of those basic questions, that is answered differently in different "interpretations".
One of the interesting proposals is associated with the "decoherent histories" or "consistent histories" program of Omnes, Gell-Mann, and Hartle. You have a wavefunction of the universe, and a set of possible histories, each of which is defined by a particular choice of observables and values for the observables; and you can assign an apriori probability to each history.
Consistent histories gives you a quantum formalism in which you don't need to talk about an external observer - which is good for cosmology - but it still doesn't tell you which observables become actual. So Gell-Mann and Hartle proposed that maybe our universe belongs to a set of consistent histories that is maximally fine-grained in some sense. That is, although not all possible properties can be definite at the same time, thanks to the uncertainty principle, you can suppose that you squeeze in as many definite properties as quantumly possible. This was called a principle of "maximality".
In Oppenheim's combination of classical gravity and quantum fields, the gravitational field will have "more" or "a greater density of" definite properties, than is possible in a theory with quantized gravity. I could find this aspect of what Oppenheim is doing, conceptually interesting - it's probing the consequences of going beyond the quantum maximum of fine-graining the gravitational field.
But gravity is different as in GR it is the result of spacetime geometry.
if Jonathan Oppenheim theory is correct, does it falsify string theory, loop quantum gravity, supergravity, or even entropic gravity, or could it be combined with the other approaches?
Jonathan Oppenheim theory of gravity + QFT and standard model + any dark matter or MOND = TOE?
In my world, a theory is falsified by experiment, unless you can show contradictions within the theory itself. However if a theory that solves the same set of problems can be formulated in a simpler framework, I would consider today's theories redundant.
is Jonathan Oppenheim theory a simpler framework?
The prototype for what Oppenheim is doing, is the general idea of something classical (with all properties always definite) interacting with something quantum (that is described by something out of the quantum formalism). There are general formalisms, that Oppenheim calls CQ (classical-quantum), for this kind of interaction. Oppenheim's approach to gravity, is to have a CQ formalism in which the classical variables are those that describe space-time (such as the metric), and everything else is quantum. The prevailing attitude has been that this is simply inconsistent, but in papers like the one above, he and his coauthors single out conditions under which such an interaction is well-defined.
To construct a CQ theory of gravity from an existing theory of quantum gravity, you have to single out the variables in the theory that are gravitational, and make them classical while keeping everything else quantum. Possibly you could do this with supergravity or loop quantum gravity, since the gravitational variables are distinct. Entropic gravity could be a problem because gravity is supposed to be emergent - there aren't fundamental variables that are specifically gravitational. As for string theory, again it seems difficult because the gravitational modes of the string are so intimately related to all the other modes. It would almost be easiest to do this, not for space-time gravity, but for the topological "gravity" on the worldsheet.
When it comes to coupling classical gravity to quantum fields, like those in the standard model, I'm not sure that Oppenheim's procedure for constructing a CQ gravity theory is well-defined. He supposes that there is a Hilbert space for the quantum part of the theory, and then at each point of classical space-time, a certain kind of operator from that space is attached. My issue is the role that renormalization plays in defining quantum field theories, it's an extra complication that may not fit his framework. The other issue for the standard model is UV-completeness. Even if we suppose that a CQ gravity theory could be constructed if the quantum variables were a UV-complete field theory like pure QCD, the actual standard model also contains a U(1) hypercharge gauge field, and U(1) quantum fields aren't UV-complete because of the "Landau pole".
Also, on the gravity side, I wonder how generally applicable the CQ framework is. In general relativity, a classical space-time geometry is deterministic only if it is "globally hyperbolic". Any deviation from this might also cause problems for a CQ theory.
arXiv:2401.05514 (gr-qc)
[Submitted on 10 Jan 2024]
Diffeomorphism invariant classical-quantum path integrals for Nordstrom gravity
Jonathan Oppenheim, Andrea Russo, Zachary Weller-Davies
The excellent paper "Gravitationally induced decoherence vs space-time diffusion: testing the quantum nature of gravity" of Oppenheim, J., Sparaciari, C., Šoda, B. et al. (Nat Commun 14, 7910 (2023). https://doi.org/10.1038/s41467-023-43348-2)
could perhaps be more accessible to the lesser gods (like me in the first place) if some remarks could be taken into account: Matters Arising: On Testing the Quantum Nature of gravity: manuscript and support material
what would be the reason to To construct a CQ theory of gravity from an existing theory of quantum gravity? CQ theory of gravity is to do away with quantum gravity
doesn't string theory posit smooth space like GR?
In their paper they claim their theory can explain MOND, also why the cosmological constant is small but nonzero, and why the MOND acceleration constant is proportional to the square root of the cosmological constant.
Sabine Hossenfelder already rebutted the claim of obtaining MOND. The arguments for the latter two claims are on page 5 but I haven't gone over them yet.
a minute later Sabine Hossenfelder admit possible for being wrong
Well, the cosmological constant might really be zero theoretically, but our universe is experimented and our machines are fallible and not perfect as in theory.
There's a saying I heard once :"There's nothing more practical than a good Theory".
comment on the mechanism for MOND in GR
3 recent 2024 papers on the mechanism for MOND in GR and no abstract
arXiv:2403.03227 [pdf, other]On GR dragging and effective galactic dark matterFederico Re, Marco GaloppoComments: 28 pages, 4 figuresSubjects: General Relativity and Quantum Cosmology (gr-qc)
Anomalous contribution to galactic rotation curves due to stochastic spacetime
Subjects: General Relativity and Quantum Cosmology (gr-qc); Astrophysics of Galaxies (astro-ph.GA); High Energy Physics – Theory (hep-th)
arXiv:2402.19459 [pdf, other]
arXiv:2403.13019 [pdf, ps, other]Many body gravity and the galaxy rotation curvesS GaneshComments: 13 pages, 6 figuresSubjects: General Relativity and Quantum Cosmology (gr-qc); Astrophysics of Galaxies (astro-ph.GA); High Energy Physics – Phenomenology (hep-ph); High Energy Physics – Theory (hep-th); Mathematical Physics (math-ph)
may be considered combining MOND in GR
] arXiv:2407.13820 [pdf, html, other]
Emergence of phantom cold dark matter from spacetime diffusion
Jonathan Oppenheim, Emanuele Panella, Andrew Pontzen
Comments: 21 pages + appendix
Subjects: General Relativity and Quantum Cosmology (gr-qc); High Energy Physics - Theory (hep-th); Quantum Physics (quant-ph)
A way to reconcile general relativity and quantum field theory without quantising the geometry is to demand the metric evolve stochastically. In this article, we explore the consequences of such a proposal at early cosmological times. We find the stochastic evolution results in the spatial metric diffusing away from its deterministic value, generating phantom cold dark matter (CDM). It is produced primarily at the end of the inflationary phase of the Universe's evolution, with a statistical distribution that depends on the specifics of the early-times cosmological model. We find the energy density of this phantom cold dark matter is positive on average, a necessary condition to reproduce the cosmological phenomenology of CDM, although further work is required to calculate its mean density and spatial distribution. If the density is cosmologically significant, phantom dark matter acts on the geometry in a way that is indistinguishable from conventional CDM. As such, it has the potential to reproduce phenomenology such as structure formation, lensing, and galactic rotation curves. We conclude by discussing the possibility of testing hybrid theories of gravity by combining measurements of the Cosmic Microwave Background with tabletop experiments.
  • · Replies 26 ·
  • · Replies 105 ·
17K
