Kavina's question at Yahoo Answers regarding an initial value problem
The discussion focuses on solving an initial value problem (IVP) related to a leaking cylindrical barrel. The rate of water leakage is proportional to the square root of the water depth, modeled by the differential equation $\frac{dh}{dt}=-k\sqrt{h}$. Given initial conditions of $h(0)=29$ cm and $h(3)=25$ cm, the constant of proportionality $k$ is determined as $k=\frac{2(\sqrt{29}-5)}{3}$. The time until the barrel is empty is calculated as $t(0)=\frac{3\sqrt{29}}{\sqrt{29}-5}$, leading to the final answer of $\frac{15}{\sqrt{29}-5}$ minutes from the current time.
  • Understanding of differential equations, specifically separable equations.
  • Familiarity with calculus concepts such as integration and initial value problems (IVPs).
  • Knowledge of the geometric properties of cylinders and volume calculations.
  • Ability to manipulate algebraic expressions and solve for constants.
  • Study the method of solving separable differential equations in greater detail.
  • Explore applications of initial value problems in real-world scenarios, such as fluid dynamics.
  • Learn about the implications of proportionality constants in differential equations.
  • Investigate numerical methods for approximating solutions to differential equations when analytical solutions are complex.
Students and professionals in mathematics, particularly those studying calculus and differential equations, as well as engineers and scientists dealing with fluid dynamics and related fields.
MarkFL
MHB
Here is the question:
Calculus question on differential equations?
Water in a barrel (upright cylinder) is leaking out at a rate proportional to the square root of the depth of the water. If the water level was 29 cm 3 minutes ago, and is at 25 cm now, how many more minutes (from now) will it take for the barrel to be empty? Please help :)
Here is a link to the question:
Calculus question on differential equations? - Yahoo! Answers
I have posted a link there to this topic so the OP may find my response.
Hello Kavina,
Let $V(t)$ be the volume in $\text{cm}^3$ of water in the cylindrical barrel at time $t$ in minutes, and $h$ be the depth in $\text{cm}$ of the water in the barrel.
We are given:
$\displaystyle \frac{dV}{dt}=-k\sqrt{h}$ where $0<k$ in the constant of proportionality.
The formula for the volume of a cylinder is:
$\displaystyle V=\pi r^2h$
Differentiating this with respect to time (and observing that $\pi r^2$ will remain constant) we find:
$\displaystyle \frac{dV}{dt}=\pi r^2\frac{dh}{dt}$
Now, equating the two expressions for $\displaystyle \frac{dV}{dt}$ we have:
$\displaystyle \pi r^2\frac{dh}{dt}=-k\sqrt{h}$
$\displaystyle \frac{dh}{dt}=-\frac{k}{\pi r^2}\sqrt{h}$
Now, we may redefine the constant of proportionality and write the IVP:
$\displaystyle \frac{dh}{dt}=-k\sqrt{h}$ where $h(0)=29,\,h(3)=25$.
The ODE associated with the IVP is separable:
$\displaystyle h^{-\frac{1}{2}}\,dh=-k\,dt$
Integrate:
$\displaystyle \int h^{-\frac{1}{2}}\,dh=-k\int\,dt$
$\displaystyle 2h^{\frac{1}{2}}=-kt+C$
Use initial conditions to find parameter $C$
$\displaystyle 2(29)^{\frac{1}{2}}=-k(0)+C$
$\displaystyle C=2\sqrt{29}$
and so we have:
$\displaystyle 2h^{\frac{1}{2}}=-kt+2\sqrt{29}$
Now, use other given point to determine the constant of proportionality $k$:
$\displaystyle 2(25)^{\frac{1}{2}}=-k(3)+2\sqrt{29}$
$\displaystyle k=\frac{2(\sqrt{29}-5)}{3}$
Hence, we may write:
$\displaystyle t=\frac{3(\sqrt{29}-\sqrt{h})}{\sqrt{29}-5}$
Now, to find when the barrel will be empty, we may let $h=0$ and we find:
$\displaystyle t(0)=\frac{3\sqrt{29}}{\sqrt{29}-5}$
Since "now" is given to be $t=3$ we must subtract 3 from this to find the answer to the question:
$\displaystyle \frac{3\sqrt{29}}{\sqrt{29}-5}-3=\frac{3\sqrt{29}-3(\sqrt{29}-5)}{\sqrt{29}-5}=\frac{15}{\sqrt{29}-5}$
