Kilometers to Miles Numerology
  • Level: High School
  • Thread starter kuruman
6 replies · 2K views · last reply
Education Advisor
Insights Author
2025 Award
Online unit converter set to Length, showing 7923 Kilometer equals 4923.124 Mile, with the note: for an approximate result, divide the length value by 1.609.
I recently had to convert 7,923 km to miles and used the web converter (see right). It turned out that 7,923 km = 4,923 mi ignoring the decimal change. The matching of the last three digits astonished me and I wondered if there is a systematic way to find additional conversion matches like this and if they exist. I tried a few things with little progress. What do the numbers experts say?
Miles to kilometres, coincidentally, has approximately a Fibonacci relationship. One mile is 1.609km, while the limiting factor for a Fibonacci sequence is ##\frac{1 + \sqrt 5}{2} \approx 1.618##.
1 mile is approximately 2 km
2 miles are approximately 3 km
3 miles are approximately 5km
5 miles are approximately 8 km
8 miles are approximately 13 km
etc.
etc.
It looks like I didn't make my question clear. Here is what I meant to ask:
Find integer values X ,Y, U, W and Z such that
XUWZ km = YUWZ mi (rounded four digit distances)
given the conversion factor 1 km = 0.621371 mi.
I stumbled into one possibility. Are there more 4-digit distances and, if so, how can they be found? My gut feeling is that there are not.
More generally, if the conversion factor is a number between zero and 1, is there a way to find
XUWZ units 1 = YUWZ units 2 (rounded four digit distances)?
I think you could work it out by defining your numbers as polynomial sums. Then your relationship becomes
$$\Sigma ( b_n * 10^n ) = constant * \Sigma( a_n * 10^n )$$
Next add the constraint that the first 3 a values are equal to the first 3 b values
The remaining work is left to the OP
That's the first (brute force) approach I tried without much success. So I thought that there might be a clever shortcut known to experts. If there isn't, I'll try again. Thanks.
I stumbled into one possibility. Are there more 4-digit distances?
The numbers are (km):
2640, 2641, 2642,
5281, 5282, 5283,
7923, 7924
Continuing to 5-digit distances:
10564, 10565,
13205, 13206
(In case it helps.)
Adding 1 km adds 0.621371 mi. The difference is 0.378629. It takes about 2641 km * 0.378629 for the difference to be 1000. Then, the last three digits repeat.
