Kronecker delta integral evaluates to zero with Simplify but not with numeric inputs
3 replies · 5K views · last reply
DocZaius
kron[m_,n_]:=\!\(
\*SubsuperscriptBox[\(\[Integral]\), \(0\), \(2\)]\(\(Sin[
\*FractionBox[\(n\ \[Pi]\ x\), \(2\)]]\ Sin[
\*FractionBox[\(m\ \[Pi]\ x\), \(2\)]]\) \[DifferentialD]x\)\)
This is the integral over x of sin(n pi x / 2) times sin(m pi x / 2) from 0 to 2. This is one way to define the Kronecker Delta function. Given m and n as integers and not both zero, if m = n then the output is 1, if m ≠ n the output is 0.
Why then is it that when I type:
Simplify[kron[m, n],
Element[m, Integers] && Element[n, Integers]]
that I get zero?
If I do kron[1, 1] I get 1! How can Mathematica say a function is 0 over the integers when I just put in two integers and got a non-zero ouput?
It is certainly not identical to zero right?
When you force Mathematica to simplify expression it is assumed that m and n are not equal. This:
Code:
Assuming[{Element[m, Integers], Element[n, Integers], m == n}, kron[m, n]]
Assuming[{Element[m, Integers], Element[n, Integers], m != n}, kron[m, n]]
gives 1 and 0 respectively!
Thank you for looking into it! I didn't know Mathematica assumed m and n are not equal. Why is Mathematica making that assumption? Given two integers m and n, the possibility that they are equal is always there.
Rather worrisome Mathematica assumption that I will keep in mind from now on! I will have to handhold Mathematica by separately asking it the = and ≠ cases.
When you call Simplify[expression] Mathematica assumes that all symbols in expression have unique values, otherwise not!
