Lagrange multipliers with canceling variables in constrained optimization
7 replies · 3K views · last reply
ElijahRockers
f(x,y) = y2-x2, g(x,y) = x2/4 +y2=9
[itex]\nabla f = \lambda \nabla g[/itex]
[itex]-2x = \lambda \frac{x}{2}[/itex]
[itex]2y = 2\lambda y[/itex]
[itex]\frac{1}{4} x^2 + y^2 = 9[/itex]
I arrived at the three equations above. So according to the first equation, lambda can equal -4. According to the second equation, it can equal 1. After this, I am algebraically lost. The x's and y's cancel themselves out from the first two equations. What does this mean?
−2x=λx/2 means EITHER λ=(-4) OR x=0. You have to check both options.
If x ± 0 then λ = -4, so in the second equation you must have y = 0.
RGV
Ray Vickson said:
If x ± 0 then λ = 4, so in the second equation you must have y = 0.
RGV
What are you talking about?
I had the typo λ = 4 instead of the correct λ = -4, but that still implies we need y = 0 to satisfy the second equation (which would be 2y = -8y).
RGV
Ok, well a lambda of -4 makes the other equation untrue. So lambda can not be -4 then, right?
Yes, it can. lambda can be -4 if y is zero.
Duh, ok, I think I got it. Thanks again.
