MHB Laplace Transform Help: Solving for Unknown Variables in Electrical Circuits
Sophie1
Evening All
I have had a go at a laplace transform and got stuck.
$$\frac{d^2v}{dt^2}+\frac R L \d v t+\frac 1{LC}v=\frac 1{LC}V_0$$
$$R=12 \Omega, L=0.16H, C=10^{-4}F, V_0=6V, v(0)=0, v'(0)=0$$
so subbing these in i get
$$\mathscr L \left[ \frac {d^2v}{dt^2}+75\d v t+62500 v \right]=\mathscr L[375000]$$
$$S^2X-Sx(0)-x'(0)+75(SX-x(0))+62500v=\frac{375000}{S}$$
subbing $v(0)=0, x'(0)=0$
$$S^2X+75SX+62500X=\frac{375000}{S}$$
$$X(S^2+75S+62500)=\frac{375000}{S}$$
$$X= \frac{375000}{S(S^2+75S+62500)}$$
not I'm stuck as i can't an inverse form to change it back into.
can someone help?
Sophie said:
Evening All
(snip)
Hi Sophie! Welcome to MHB! ;)
Suppose we could write $X$ as:
$$X = \frac A S + \frac {BS + C}{(s+\alpha)^2 + \omega^2}$$
for some yet to be determined $A,B,C,\alpha,\omega$.
Could you then find the inverse transform? (Wondering)
could you give me a pointer of where to begin. I have not used or even see α,ω. With respect to laplace transform.
From wiki:
$$\mathcal L^{-1}\left[\frac{s+\alpha}{(s+\alpha)^2+\omega^2}\right] = e^{-\alpha t} \cos(\omega t) \cdot u(t)$$
So if we can find such constants $\alpha,\omega$ we can find the inverse transform.
And we have that:
$$S^2+75S+62500 = (S+\alpha)^2 + \omega^2$$
so we just need to figure out what these $\alpha,\omega$ are... (Thinking)
Would you be able to confirm that my working out upto the point i asked is correct as I'm not finding the answer. I will carry on trying.
Your working up to:
is correct (disregarding some inconsistencies in $v$, $V$, and $x$ in the intermediate steps).
(Nod)
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
