Laser beam reflected off a plane mirror with angle α = 85°
2 replies · 7K views · last reply
Kalibasa
A laser beam is incident on the left mirror in the figure below, in which α = 85°. Its initial direction is parallel to a line that bisects the mirrors. What is the angle ϕ of the reflected laser beam?
http://www.webassign.net/knight/p23-40.gif"
The law of reflection, where the angle of incidence (measured from the normal, the line perpendicular to the surface) is equal to the angle of reflection
I tried assigning names to all the angles and figuring out which were equal to each other, then trying to do it algebraically. But I don't see any way to do this with only the one angle given...
Here's a helpful hint: Regardless of the shape of a given triangle, the sum of its three angles is always 180o. :wink:
Beyond that, if you want us to help more you'll have to show us your work so far, and your attempt at a solution (i.e. show us how you tried to "do it algebraically," for example).
How I tried to do it algebraically was a long complicated mess, which is why I didn't post it. I finally figured it out, though- my starting angle was 42.5 degrees, that's what I'd missed, and then I was able to calculate each angle as I went around
