Last two digits mod 100 problem
  • Thread starter timetraveller123
28 replies · 8K views · last reply
timetraveller123
Equation x = 19 raised to the power 17 raised to the power 15 raised to the power ... raised to the power 3 raised to the power 1, with the tower of exponents continuing via an ellipsis.
the question requires you to find the last two digits of x
φ(n) = n * (Σ (1 - 1/p) ) where p are the distinct prime factors of n the totient function
gcd(a ,n) = 1
aφ(n)≡ 1 mod n
typically this kind on question i would solve it like say
1940 ≡ 1 mod(100)
but here the exponent is not a simple multiple of 40 or near multiples of 40 then how am i supposed to do this
What is the order of evaluation, right to left or left to right? Either way, the problem could be solved with a program that uses repeated squaring to raise a number to a power modulo 100.
um this is olympaid question with no calculator
While studying the repetition period of the powers is a possible method, it can still get rather tedious (especially if you need to do it by hand in a time limited situation).
Another method is to try considering ##19 = (20-1)## and performing a binomial expansion of the expression. The modulo arithmetic kills off most of the terms in the expansion.
[Subsequent hint is to next decompose ##17 = \left(15 + 2 \right)##.]
Fightfish said:
try considering 19=(20−1)
Yes, that's what I was hinting at in post #4.
Also, I suggest a convenient notation will make the writing out easier. I wrote @19=19@17, etc., and used % for modulo. Thus, the question is expressed as @19%100 (@ takes precedence over %).
Ah okay, I was wondering whether you meant that or to look for the repetition cycles (the latter of which I actually tried, and its, well, not that bad I guess).
Fair enough.
@haruspex
19k mod 100 oscillates between 9 and 1 depending on whether k is odd or even respectively
vishnu 73 said:
@haruspex
No, that would be mod 10. Use @Fightfish's stronger hint, the binomial expansion of (20-1)k.
well
202 ≡ 0 mod 100
subsequently for n ≥2
20n ≡0 mod 100
then only the last two terms in the binomial expansion survive
(20 -1)k mod 100= k (20) (-1)k-1 + (-1)k mod 100
since k is odd here
19k ≡ 20k -1 mod 100
then how to proceed if this is correct
Starting with the first power, k=17, that is, 1917=20*17-1 mod 100. Now raise it to the 15th power. (hint: 17=20-3).
No. It is 19(17(15..., not ((1917)15...)
vishnu 73 said:
well
202 ≡ 0 mod 100
20n ≡0 mod 100
since k is odd here
Right, so using my notation we have @19%100=(20@17-1)%100=20@17%100-1 (yes?).
Can you take the 20 out as a factor, i.e. write 20k mod 100 (=20@17%100) as 20(some expression)?
[tex]17^{15^{13^{11^{9^{7^{5^{3^{1}}}}}}}}=17^M[/tex], the right side is 19 on some power of 17.
You got ##19^k=20k-1##. For k=17, ##19^k=20*17-1##. Following @haruspex's hint write 17=20-3 , so 1917=20*(20-3) - 1 = - 61 mod 100 or 39 mod 100. Raise 39 mod 100 to the 17th power again, and again, and find the period of the repetition cycle.
sorry for the late reply in overseas
19@17 ≡ 20@17 -1 mod 100
isn't 20@17 mod 100 ≡0
then isn't 20@17 -1 mod 100 ≡ -1
what is happening?
can some one explain to me because i kind of don't understand what i myself am doing
this means when 19k is divided by 100 you get 20k -1 as remainder
but 20 k -1 can be bigger than hundred itself
so once again taking mod 100
since k = @17 bigger than 2
202≡ 0 mod 100
20k -1 mod 100 ≡ -1 mod 100
i am doing something terribly wrong what is it? point out to me?
No. Perhaps my notation is too confusing. 20@17 stands for 20 times @17, i.e. 20 times 171513..., not 20@17.
202≡ 0 mod 100
Power is not product. If k is odd, 203=0 mod 100, but 20*3=60 mod 100, 20*5=0 mod 100, 20*7 =40 mod 100...
oh you sorry i got confused with power and product there i reworked tell me if this correct thanks
so
19@17 ≡ 20 @17 -1 mod 100
20@17 -1 mod 100 = 20@(20-3) -1 mod 100
20@(20-3) - 1 = 20 * (20 -3)m -1 where m is a positive integer
so every term but the last term in the binomial is killed because it has at least a 202 term in it the remaining modulo congruence can be written as
20*(-3)@15 -1 mod 100
now since 20 * k mod 100 has a repetition of 5 we only need to consider (-3)@15 mod 5
this is a cycle of
-3 , 4 ,-2 , 1 or 2,4,3,1
now we need to find @15 mod 4 = 15@13 mod 4 = (16 - 1)@13 mod 4 ≡ (-1) @13 mod 4
now since @13 is odd it gives a remainder of -1 or 3
so @15 mod4 ≡ 3
so 20(3) -1 to give a final remainder of 59 mod 100
is this correct?
well this is the given method while the answer is the same i don't get the method can someone explain to me
let a = @17 and b = @15 . since @13 is odd b = -1 mod 16
then considering the totient function
φ(100) = 40 φ(40) = 16
by euler theorem:
a= 17b ≡ 17-1 ≡ 33 mod 40
then 19a ≡ 1933 ≡ 59 mod 100
i understand little bit
why 17-1 ≡ 33 mod 40
then
why is 19a ≡ 1933 mod 40
Because 17##\times##33≡ 1 mod 40.
Mod 100, not mod 40.
This is easily shown using 19=20-1. I would first reduce the preceding statement to a≡3 mod 5.
haruspex said:
Because 17××\times33≡ 1 mod 40.
is it about multiplicative inverses
i am afraid i still don't understand
Yes.
The expression has been reduced to 1917-1 mod 100.
We have 17-1 ≡ 33 mod 40, but we do not need all that detail. It is enough that 17-1 ≡ 3 mod 5.
so it comes down to 195k+3 mod 100 ≡ (20-1)5k+3 mod 100 ≡ 20(5k+3)-1 ≡ 59.
now i get it thanks for the help
just a quick proving could you help? thanks.so writing as polynomial
\begin{equation}
p(x) = \sum_{i =0}^{n}{a_i x^i}
\end{equation}
then by the given equation
a0 =1999
and
\begin{equation}
0 = \sum_{i =1}^{n}{a_i }
\end{equation}
rewriting it
p(x) = a_n \sum_{i = 1}^{n}{\frac{a_i}{a_n} x^i} + \frac{1999}{a_n}
now i hope to be able to prove using contradiction
how can i do it?
  • Printed textbook problem 5.4.14: Let p(x) be a polynomial with integer coefficients satisfying p(0) = p(1) = 1999. Show that p has no integer zeros.
\begin{equation}
\end{equation}
a0 =1999
and
\begin{equation}
\end{equation}
rewriting it
how can i do it?
Please post as a new thread - forum rules.
