LaTeX not showing in preview mode
  • Context: LaTeX
  • Thread starter Thread starter OlderDan
13 replies · 910 views
Homework Helper
I guess I'd better leave one message here so I don't keep creating new threads. I can't see any LaTeX in preview mode, so I need a place to actually post a message to see if the code is good. I will add and delete messages to this thread for that purpose.
You're not alone. There's been that LaTeX problem here for a few months now...speaking of which: long time, no see! Welcome back.
Thanks. I got real busy there for some time. I may be here in spurts. Don't know for sure.
Now I can't even get the thing to display when I post the message grrrrrrrrrrrr!
Adding a title
Why not just leave the final equations here, as examples for other people to learn from? At least if you're testing some new technique; you can add a title or note describing it, if you get it to work.
Or can you add a title to a previously-posted message? Let's see... Aha, you can, if you "Go Advanced" when editing.
I could do that. The ones that have worked have been posted in context. The stuff I was doing here was just checking the LaTeX, so it had no discussion to go with it.
Here's the one I was working on last night that I could not get to view even here. Let's see if it works
[tex] c \tau ' = \sqrt {l^2 \sin ^2 \theta + \left( {\frac{{l\cos \theta }}{\gamma } - v\tau '} \right)^2 }[/tex]
[tex] c^2 \tau '^2 = l^2 \left( {1 - \cos ^2 \theta } \right) + \frac{{l^2 \cos ^2 \theta }}{{\gamma ^2 }} - 2\frac{{l\cos \theta }}{\gamma }v\tau ' + v^2 \tau '^2[/tex]
[tex] c^2 \tau '^2 = l^2 \left( {1 - \cos ^2 \theta + \frac{{\cos ^2 \theta }}{{\gamma ^2 }}} \right) - 2\frac{{l\cos \theta }}{\gamma }v\tau ' + v^2 \tau '^2[/tex]
[tex] 0 = \left( {c^2 - v^2 } \right)\tau '^2 + 2\frac{{l\cos \theta }}{\gamma }v\tau ' - l^2 \left( {1 - \cos ^2 \theta \left( {1 - \frac{1}{{\gamma ^2 }}} \right)} \right)[/tex]
[tex] 0 = \left( {1 - \beta ^2 } \right)c^2 \tau '^2 + 2\frac{{l\cos \theta }}{\gamma }\beta c\tau ' - l^2 \left( {1 - \beta ^2 \cos ^2 \theta } \right)[/tex]
[tex] 0 = \frac{{c^2 \tau '^2 }}{{\gamma ^2 }} + 2l\beta \cos \theta \frac{{c\tau '}}{\gamma } - l^2 \left( {1 - \beta ^2 \cos ^2 \theta } \right)[/tex]
[tex] \frac{{c\tau '}}{\gamma } = \frac{{ - 2l\beta \cos \theta \pm \sqrt {\left( {2l\beta \cos \theta } \right)^2 + 4l^2 \left( {1 - \beta ^2 \cos ^2 \theta } \right)} }}{2}[/tex]
[tex] \frac{{c\tau '}}{\gamma } = - l\beta \cos \theta \pm l\sqrt {\beta ^2 \cos ^2 \theta + 1 - \beta ^2 \cos ^2 \theta }[/tex]
[tex] \frac{{c\tau '}}{\gamma } = - l\beta \cos \theta \pm l = l - l\beta \cos \theta = l\left( {1 - \beta \cos \theta } \right)[/tex]
[tex] \tau ' = \left( {1 - \beta \cos \theta } \right)\gamma \frac{l}{c}[/tex]
OK I think I can make this work now.
[tex]\ddot{\psi} + \omega_0 ^2 \psi = 0[/tex]
kcirick said:
Well, the question says specifically to use the Lagrange Equation. My problem is I don't know what to integrate and what I'm integrating over. Also, I'm assuming I have to use either one of these relations:
[tex]\Gamma\left(p\right)=\int^{\infty}_{0}x^{p-1}e^{-x}dx[/tex]
or
[tex]\Gamma\left(p+1\right) = p\Gamma\left(p\right)[/tex]
I think there is another form that will help you. See
http://mathworld.wolfram.com/GammaFunction.html
equation (5)
or
http://numbers.computation.free.fr/Constants/Miscellaneous/gammaFunction.html
equation (1)
Your equation
[tex]\frac{d}{dt}m\dot{x}=-\frac{m}{2x}[/tex]
can be integrated by separating variables
[tex]\frac{dv}{dt}=-\frac{1}{2x}[/tex]
[tex]\frac{dv}{dx}\frac{dx}{dt}=v\frac{dv}{dx}=-\frac{1}{2x}[/tex]
[tex]vdv =-\frac{dx}{2x}[/tex]
[itex]\Gamma\left(\frac{1}{2}\right)[/itex]
[tex]ma = \frac{m}{L}g\left[ {y - \left( {L - y} \right)} \right] = mg\left( {\frac{{2y - L}}{L}} \right)[/tex]
[tex]a = g\left( {\frac{{2y - L}}{L}} \right)[/tex]
[tex]v\frac{{dv}}{{dy}} = g\left( {\frac{{2y - L}}{L}} \right)[/tex]
[tex]vdv = g\left( {\frac{{2y}}{L} - 1} \right)dy[/tex]
[tex]\frac{{v^2 }}{2} = g\left( {\frac{{y^2 }}{L} - y} \right) + C[/tex]
[tex]C = g\left( {y_o - \frac{{y_o ^2 }}{L}} \right)[/tex] where [itex]v[/itex] is zero at [itex]y_o[/itex]
[tex]v^2 = 2g\left( {\frac{{y^2 }}{L} - y + y_o - \frac{{y_o ^2 }}{L}} \right)[/tex] for any [itex]y[/itex] starting from rest at [itex]y_o[/itex]
[tex]v^2 = 2g\left( {\frac{{y^2 }}{L} - y + \frac{L}{4}} \right)[/tex] if [itex]y_o = \frac{L}{2}[/itex]
[tex]v_L ^2 = 2g\left( {y_o - \frac{{y_o ^2 }}{L}} \right) = 2gy_o \left( {1 - \frac{{y_o }}{L}} \right)[/tex] when [itex]y = L[/itex]
[tex]v_{\max } ^2 = g\frac{L}{2}[/tex] when [itex]y_o = \frac{L}{2}[/itex] and [itex]y = L[/itex]
Doc Al said:
You guys realize that we have an existing thread dedicated to practicing Latex? https://www.physicsforums.com/showthread.php?t=8997"
Yes, welcome back OlderDan!
I didn't realize that other area was available for this sort of thing. I can do things over there if that is preferred.
Greg has since, locked the LaTeX typesetting thread. It was recommended in the thread, to delete our work after getting our LaTeX formatted. But a lot of folks left their work posted. Actually after seeing some of the more exotic (1, 2, and 3 ) LaTeX posts, I am glad those were left. Greg recommends using this http://at.org/~cola/tex2img/index.php from now on, to practise typesetting.
Hmmm. The converter didn't work for me. Gave me an error for this:
[tex]\gamma^2 = \pi R^2 \Xi[/tex]
Did you tick the "math mode" box at the bottom left? It didn't work for me until i noticed that!
Hah! That fixed it. Thanks cristo!
